Frame drag to accelerate spaceships?
6 replies · 3K views
makc
As far as I understand, a spaceship going around rotating black hole should gain additional acceleration due to frame drag. Right? So, would there be max speed gain, like in gravity assist, or could you accelerate infinitely? Thanks.
Geodesics in the Kerr metric have the usual constants of the motion: energy and angular momentum. A particle falling in from infinity would re-emerge with the same energy it went in with.
is it not the same as with gravity assist, these constraints should apply to spaceship and black hole together?
I guess I'm asking if falling body can borrow some of black hole energy.
More on Forward's scheme -- which I never quite followed. (The original was in "Indistinguishable from Magic", a collection of non-fiction essays.).
The General Relativistic Antigravity Machine consists of a torus of dense mass which is turning inside-out like a smoke ring. A mass with this motion, according to Einstein’s theory, "drags the metric" through the center of the torus. Unidirectional general relativistic forces arise which are equivalent to gravity, and may be used to neutralize planetary surface gravity or as a space propulsion system.
Ok, I guess I really do need some education here. I've seen Forward's device before - in fact I remember a rather long Am J Phys article he wrote - but I never realized before how much I just don't get the point of it. It all comes back to my earlier comment:
This continues to be true in Forward's torus, does it not? It's stationary and axially symmetric. Hence by general principles, a particle traveling along a geodesic will have constant energy and angular momentum. So you can't simply drop a particle through the hole and expect it to be accelerated!
The ergosphere in the Kerr metric only works a benefit if you do something nongeodesic while inside it: either (a) fire your rockets or (b) split in two, as in the Penrose Process. I'd have to say the torus is similar - on a freely falling object the frame dragging has only a temporary effect, and when you emerge from the other side and move away you'll find to your disappointment that nothing has changed. :frown:
