Why Does Frankel Prefer Components on the Right in The Geometry of Physics?
Frankel's preference for placing components to the right of basis vectors in "The Geometry of Physics" is rooted in a desire for clarity and consistency in mathematical notation. This approach aligns with the Einstein summation convention, simplifying expressions by eliminating summation symbols while preserving the interpretation of vectors as column vectors. The discussion highlights that while this notation may be a matter of personal taste, it can lead to confusion, especially when distinguishing between left and right operations in more complex algebraic structures.
  • Understanding of differential forms as introduced in Frankel's "The Geometry of Physics"
  • Familiarity with the Einstein summation convention
  • Basic knowledge of vector spaces and their properties
  • Awareness of the implications of notation in mathematical expressions
  • Explore the implications of the Einstein summation convention in various mathematical contexts
  • Study the differences between left and right operations in algebraic structures
  • Investigate how notation affects clarity in mathematical communication
  • Review examples of vector notation in advanced physics texts for practical applications
Mathematicians, physicists, and students of advanced mathematics who are interested in the nuances of mathematical notation and its impact on understanding complex concepts.
JTC
Good Day
Early on, in Frankel's text "The Geometry of Physics" (in the introductory note on differential forms, in fact, on page 3) he writes:
"We prefer the last expression with the components to the right of the basis vectors."
Well, I do sort of like this notation and after reading a bit of the text (not easy, struggling, but learning), I am perplexed by one issue: Why?
Why does he prefer to write the expression for a vector with the components on the right of the basis vectors? It is different from the way others do it. Is there something specific that is gained?
(And just to stave off any controversy on the text--yes, I know some do not like this text--I am much less interested on whether his preference is bad, and only interested in WHY he prefers it.)
JTC said:
Good Day
I think it's just a matter of taste. Maybe he likes the way it reads: "In direction v go c steps" rather than "Go c steps - huh? where to? - in direction v - see before". E.g. I knew people who actually liked the Polish notation and find the way all others do it confusing.
Are you suggesting by this that in any application of this notation (e.g.: 1) rotation matrices of frames or 2) Hamilton's principle for linked systems or 3) something I am not even aware of yet) that there is no difference in whether it is before or after? Are you saying that there is no case where the notation makes things easier to understand or apply?
I really do like what you wrote, by the way; and it makes sense. And I suppose I can live with it.
But the flippancy with which Frankel says it, unnerves me just a bit.
You must be careful in how you read mathematical notation.
Sometimes its okay to change the order of things and sometimes there's a deeper reason not to.
It varies with the author and the discipline so you need to always be aware of what is what.
Formally ##M \cdot R## and ##R \cdot M## with a module ##M## and a ring ##R## are two different objects. E.g. if we chose some matrix rings here to be ##M## and ##R## we can really get something different. (In https://www.physicsforums.com/threads/noncommutative-artinian-rings.885151/#post-5572046 is an example.)
But if we want to write vectors form ##M=V## in coordinates, and have a (commutative) field ##R=F##, we also can swap left and right in all components, so it makes sense to allow ##\alpha \cdot v = v \cdot \alpha\,##. But technically, one has to chose a side.
I am afraid I do not understand a sufficient amount of algebra to put your response in context. May I implore you to cut to the chase (forgive me for my facetiousness) and explain in a little more common English, what you are saying?
Are you still suggesting it makes no difference except in so far as we "linguistically" understand: "go in this direction, a certain amount?"
I looked at Frankels' notation and don't think its a good idea. He even admits that some may confuse it with partial differentiation.
His reasoning has something to do with getting a 1x1 result and removing the summation symbol kind of like the Einstein summation convention and preserving the notion of v being a column vector.
https://books.google.com/books?id=gXvHCiUlCgUC&pg=PR31&lpg=PR31&dq=frankel+We+prefer+the+last+expression+with+the+components+to+the+right+of+the+basis+vectors.&source=bl&ots=Km9Scq-Vgl&sig=YxycLRxec5l0tObkl1HJbffnMhY&hl=en&sa=X&ved=0ahUKEwif3eyPssDUAhWL64MKHeOwCnAQ6AEILzAB#v=onepage&q=frankel We prefer the last expression with the components to the right of the basis vectors.&f=false
If one has less nicely behaving objects than vector spaces and fields, left and right has to be distinguished, because they might have different properties.
Formally, the need for distinction doesn't go away for vector spaces and fields as scalar domains, and I haven't found (on a very quick search) that the requirement ##\alpha \cdot \vec{v} \stackrel{(*)}{=} \vec{v} \cdot \alpha## for a scalar ##\alpha## had been added to the defining properties of vector spaces. However, they don't produce objects with different properties and can be considered isomorphic (equal). But as long as ##(*)## isn't explicitly required, we have to distinguish the two. On the other hand ##(*)## makes kind of sense, since
\alpha \cdot \vec{v} = \alpha \cdot \begin{bmatrix}v_1 \\ v_2\\ \vdots\end{bmatrix} = \begin{bmatrix} \alpha \cdot v_1 \\\alpha \cdot v_2\\ \vdots\end{bmatrix} = \begin{bmatrix}v_1 \cdot \alpha \\ v_2 \cdot \alpha \\ \vdots\end{bmatrix} = \vec{v} \cdot \alpha
and thus we may identify left and right vector spaces. We must not if we regard things lilke matrices as operating objects.
  • · Replies 70 ·
16K
  • · Replies 16 ·
  • · Replies 16 ·
