Free fall acceleration flowerpot problem
The flowerpot free fall problem involves calculating the distance from the windowsill to the top of a window, given a fall time of 0.420 seconds and a window height of 1.90 meters. Using the equations of motion, particularly x(t) = x(0) + v(0)t + 1/2at^2, and applying a consistent sign convention, the correct distance is determined to be approximately 0.31 meters. The initial velocity (v(0)) is calculated as -2.46 m/s, leading to the final distance calculation of h = -0.308 m, which is rounded to 0.31 m for clarity.
  • Understanding of kinematic equations in physics
  • Knowledge of free fall acceleration (9.80 m/s²)
  • Ability to apply consistent sign conventions in physics problems
  • Familiarity with solving quadratic equations
  • Study kinematic equations in-depth, focusing on free fall scenarios
  • Learn about the implications of sign conventions in physics problems
  • Practice solving problems involving quadratic equations
  • Explore real-world applications of free fall acceleration in engineering
Students studying physics, educators teaching kinematics, and anyone interested in understanding motion under gravity without air resistance.
COCoNuT
A flowerpot falls off a windowsill and falls past the window below. You may ignore air resistance. It takes time 0.420 s to pass this window, which is of height 1.90 m.
Question- How far is the top of the window below the windowsill from which the flowerpot fell? Take the free fall acceleration to be 9.80m/s^2 .
given:
t = 0.420s
h = 1.90m
using the position formula
x(t) - x(0) = v(0)(0.42) - 4.9(0.42)^2
1.9 = v(0)(0.42) - 4.9(0.42)^2
v(0) = 6.59m/s
vf^2 - v(0)^2 = 2gh <--- now using this formula...
(6.582)^2 - 0 -2(-9.8)h
h = (6.582)^2/(9.8^2)
h = 2.21m
my answer is 2.21m, but it's wrong. i know I am close, can someone help?
Let u be the distance between the windowsill and the top of the window. If you set the windowsill at y=0, then use the formula y=y_0-v_0t-\frac{1}{2}gt^2. We have y0=0 by our reference point and v0=0 since the flowerpot falls. Therefore:
y=-\frac{1}{2}gt^2
-1.9-u=-\frac{1}{2}gt^2
u=\frac{1}{2}gt^2-1.9
consistent sign convention!
v(0) = 6.59m/s
Your thinking is correct, but you are not using a consistent sign convention. Since you are taking the acceleration to be -9.8 m/s^2, that means you chose down as negative, up as positive. But you weren't consistent. x(t) - x(0) = -1.9 (since the change in position is negative), which makes the equation:
-1.9 = v(0)(0.42) - 4.9(0.42)^2; solve this one for v(0). (And realize that v(0) will, of course, be negative!)
Of course, you need to plug in the new, correct value for v(0). But use that same sign convention. Note that a is negative, so h will turn out to be negative. Which makes sense in your sign convention, since the top of the window is below the starting point.
FYI: No one says you must choose down to be negative. You could call down positive, in which case a = +9.8 m/s^2, etc. Just be consistent and you'll do fine.
If the flowerpot is just falling from rest and not being thrown or propelled downwards, then v0 will equal zero.
Using the equations in my first post, I get 1.03m as the distance between the sill and the window.
CellCoree said:
yea i did use that equation,
solved for v and plugged it into
vf^2 - v(0)^2 = 2gh
dont know why i get a different answer
i even used your formula and get -2.764
My bad. I had the wrong signs in there. Since I set y=0 at the windowsill, all values should be negative. Therefore, if -y is the distance to the bottom of the window from the windowsill, it should be broken up into -u-1.9 where u is defined as before. Therefore, -u-1.9=-\frac{1}{2}gt^2. I made the chages to the above equations as well.
CellCoree said:
-1.9 = v(0)(0.42) - 4.9(0.42)^2 after solving this for v(0) i get -2.46m/s
(-2.46)^2 =2(-9.8)h
h = -.308m
does that look right? seems incorrect to me
Looks good to me. Be sure to reword it so you answer the exact question that was in the original problem. The question asked "How far is the top of the window below the windowsill from which the flowerpot fell?"--so I would say the answer is 0.31 m.
  • · Replies 16 ·
  • · Replies 25 ·
37K
