Frequencies of standing wave in pipe
The discussion centers on the calculation of the speed of sound in a 0.5m pipe closed at one end, resonating at 600Hz for n=2. Two formulas are presented for determining the resonant frequencies: fn=(2n+1)*V/4L and fn=(2n-1)*V/4L. Both formulas are valid, with the first allowing n to start from 0 and the second from 1. The choice of formula depends on the context provided in class or textbooks.
  • Understanding of standing wave principles
  • Familiarity with harmonic frequencies in closed pipes
  • Knowledge of wave speed calculations
  • Basic algebra for manipulating equations
  • Research the derivation of standing wave equations in closed pipes
  • Learn about the speed of sound in different mediums
  • Explore the concept of harmonics and their applications in acoustics
  • Study the impact of pipe length on resonant frequencies
Students studying physics, particularly those focusing on wave mechanics, acoustics, and sound engineering.
susdu
A speaker is placed near the open end of a 0.5m pipe (closed on the other end).
what is the speed of sound if the pipe resonances at 600Hz for n=2?
fn=(2n+1)*V/4L
Or?
fn=(2n-1)*V/4L
I saw both versions of the formulas above, which one is correct?
Both formulas are correct. The first one assumes that the possible values of n are 0, 1, 2, 3, ... The second formula assumes the values of n are 1, 2, 3, ... So both formulas will produce the same set of resonant frequencies.
However, since the formulas produce a different frequency for the same n, you would need to know which formula the problem wants you to use. It's probably the same formula that was used in class or in your textbook.
Thanks for the clarification!
Well, the bottom version of the formula obviously doesn't work for n = 0, whereas the top one does, so I'm assuming the two versions are just dependent on where you start counting from. They both generate identical harmonics if you let n be 0, 1, 2, 3, ... for the top one and 1, 2, 3, ... for the bottom one.
EDIT: I was sitting there too long with my compose window open while doing something else and got beaten to the punch!
Thanks anyway cepheid.
12K
