Frequency Comparator: Design & PLC Elements in Speed Radar
Frequency comparators can be designed using methods such as bandpass filters for single frequency comparisons or analog spectrum analyzers for multiple frequencies. Digital signal processing (DSP) and Fast Fourier Transform (FFT) techniques can also be employed for detailed frequency analysis of input signals. In speed radar applications, the Doppler shift in the frequency of the return signal is utilized to calculate the speed of moving objects. Additional resources and circuit examples are available for those interested in frequency comparison design. Understanding these components is essential for effective speed radar functionality.
kautilya
does anyone know a frequency comparator is designed?
also what are the elements of programmable logic control in a speed radar?
The function of determining a signal's frequency content can be accomplished several different ways. If you just have a single frequency that you want to compare an input signal's spectrum against, you can use a simple bandpass filter to tell you how large the signal content is at that frequency in the input waveform.
If you want more information about multiple frequencies in the input waveform, you can use an analog spectrum analyzer circuit (mixer + LPF), or you can digitize the waveform, and use digital signal processing (DSP) and/or Fast Fourier Transform (FFT) processing to give you the signal energy at different frequencies.
As to the RADAR gun question, it is using the Doppler shift in frequency of the return signal to calculate the speed of the reflecting object.
http://en.wikipedia.org/wiki/Radar_gun
In addition to Berkeman's answer in paragraph 1, i found the following circuit that highlights a method of achieving frequency comparison.
there is a simple explanation that goes along with it but generally the idea is clear.
http://www.newcircuits.com/circuit.php?id=msr006
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 17 ·
