Frequency Problem: Find the Answer with 16 Pulses Every 4 Seconds
  • Thread starter Thread starter Misr
    Frequency
The frequency of a vibrating source producing 16 pulses every 4 seconds is calculated as 4 Hertz (Hz). This is derived from the formula frequency = n/t, where n is the number of pulses and t is the time in seconds. Each pulse is considered a discrete event, and thus the frequency is determined by the total number of pulses divided by the time interval. The confusion arises from misinterpreting pulses as waves; however, in this context, pulses are the correct measure for frequency.
  • Understanding of basic frequency concepts and calculations
  • Familiarity with the formula frequency = n/t
  • Knowledge of units of measurement, specifically Hertz (Hz)
  • Basic understanding of wave and pulse distinctions in physics
  • Study the relationship between pulses and waves in wave mechanics
  • Learn about different units of frequency and their applications
  • Explore practical examples of frequency calculations in various contexts
  • Investigate the implications of frequency in signal processing and communications
Students in physics, educators teaching wave mechanics, and anyone interested in understanding frequency calculations in practical scenarios.
Misr
a vibrating source makes 16 pulses every 4 seconds
find the frequency
frequency=n/t
pulse is half a wave
if we consider a pulse as half a wave then the source produces 8 waves
then frequency=8/4=2 hertz
but that's not the right answer
according to the textbook:
frequency=16/4=4 Hz
I'm completely confused can u explain the right answer?
Thanks in advance!
find the frequency
frequency=n/t
frequency=16/4=4 Hz
Thanks in advance!
You are reading too much into this.
Frequency is measure in cycles or pulses per second - unit Hertz.
If you are given a different time unit, you convert.
Frequency of a motor that spins at 1200 times per minute - divide by 60 = 20 hertz
Speeding motorists are picked up at the rate of 30 per hour = (1/120) Hz
Your example 16 pulses in 4 seconds. How do you convert to Hz?
according to you 16/4 = 4 Hz right?
according to you frequency is how often something repeats itself
If so then It doesn't matter if it makes 16 pulses or 16 waves :(
We could talk about the frequency of the pulses, the frequency of the waves, the frequency of the traffic , the frequency of the sound, the frequency of the radio transmitter - it really doesn't matter. This problem was about the frequency of the pulses.
Frequency simply means how often (per sec) an occurrence happens over a given duration of time. For this case the occurrence is the pulse. So the question is how often or how many pulses are observed every second.
Just ignore the idea that a pulse is half wave, I'm not sure with that. A pulse is a sudden spike/burst of signal, so they are discrete and not continuous (wave). It may be given that way but not for this one.
Yeah,I suppose I got it
Thanks very much
but isn't hz equivalent to cycles/second? not pulses / sec ??
Hertz is just "per second" its unit is even s-1
It is how many of the things you are looking at there are per second.
Are you looking at pulses, are you looking at waves, are you looking at revolutions of a motor, are you looking at swings of a pendulum, are you looking at traffic flow.
Once a frequency gets below 1, we tend not to use frequency, so traffic flow is unlikely to have a Hz value associated with it.
