Friction-less wedge physics problem
  • Thread starter Thread starter holyko
    Physics Wedge
A 2.0-kg body on a frictionless wedge inclined at 65.0° remains stationary relative to the wedge due to the wedge's rightward acceleration. The confusion arises from the concept of a body being at rest while the wedge accelerates, which prevents the mass from sliding down. The discussion emphasizes the importance of considering mass in calculations involving acceleration and force. Key forces acting on the body include the normal force from the wedge and gravitational weight. Proper application of net force equations is crucial for solving the problem accurately.
holyko
A 2.0-kg body rests on a frictionless wedge that has an inclination of 65.0° and an acceleration a to the right such that the mass remains stationary relative to the wedge. Find a
This is one of the question i had to do for HW.
Not really asking for an answer but it would be great if you provide one with a semi detail equation
I just don't get how is a body at rest yet accelerating! I probably misinterpret the question and I hope someone will point out where I misunderstood. Thank You
What they mean is that the wedge with the mass on it is being acclerated (along the floor, for example) in a way that the mass does not slide down the wedge as it would if it were stationary. Try using some basic principles. Very interesting problem.
Thx for pointing out my misinterpertation ^_^. Now, the question made more sense.
Ok, I tried doing the question but I got the wrong answer :mad: and this is what I did:
I thought maybe mass doesn't matter in this situation because all object has the same accelartion due to gravity
so i just went acelaration to the right = 9.8 x sin 65 x sin 25
The sin 65 was to find the accelartion for the body sliding down the incline
this acceleration is parallel to the incline
Then i did a bit of geometry to figure out that sin 25 will give me "a" to the right.
so, was i wrong about ignoring the mass or what?
I'm afraid so. :smile:
In any problem concerning acceleration or force, you'd better consider the mass.
Think this way. There are two forces acting on the body: (1) the normal force from the wedge, and (2) the weight. Hint: in the vertical direction, the body does not accelerate; in the horizontal direction, it does. Apply \vec{F_{net}} = m \vec{a}.
  • · Replies 25 ·
10K
