Friction; what does not contribute?
  • Thread starter Thread starter jadiepants
    Friction
The discussion revolves around understanding the factors that do not contribute to friction, specifically in the context of static and kinetic friction. The original poster seeks clarity on why speed and surface area are considered non-contributing factors.
  • Participants explore the definitions and types of friction, questioning the relevance of speed and surface area. Some express confusion about the lack of contribution from these factors and seek further understanding.
Participants are actively discussing the nuances of static and kinetic friction, with some providing insights into the equations that govern these concepts. There is a recognition of the vagueness of the original question, and multiple interpretations are being explored without a clear consensus.
There is mention of homework constraints and the need for clarity before submission, indicating that participants are navigating the requirements of their assignment while seeking deeper understanding.
jadiepants
What two things do not contribute to friction (i.e. what is friction not dependent upon)?
After googling I have read that it is speed and surface area - but they had no explanations.
I don't understand how either of these would not contribute and I don't want to submit my assignment when I don't actually understand it.
The formula that best approximates kinetic surface-to-surface friction is [tex]F_{friction}=\mu_k N[/tex] where [tex]\mu[/tex] is the coefficient of kinetic friction, and [tex]N[/tex] is the magnitude of the normal force between the two surfaces.
That tells me what does contribute, but I need to know what does not contribute.
This is a very vague question though. Look, there are 2 or 3 types of friction which you might encounter in a basic physics class. The first type its called "Static Friction" and the second is called "Kinetic Friction."
In Static Friction the object is not yet moving and therefore it generates more friction.
This can be modeled through the equation:
[tex]\mu[/tex]static Fnormal [tex]\geq[/tex] FSfriction
In Kinetic Friction the object is already moving and therefore there is less friction.
[tex]\mu[/tex]kinetic Fnormal [tex]\geq[/tex] FKfriction
As you can see speed does matter if you are going from V0= 0 m/s to V= nonzero value m/s
But once you start moving speed has nothing to do with the amount of friction
As for surface area... I am not quite sure, but the equations seem to demonstrate no relation between the two.
Thanks for that :) It is pretty vague, my friend suggested I put something silly like 'the colour of the object'
I will put down surface area and speed only when calculating kinetic friction.
Let me clarify the Static Friction and Kinetic Friction... Static Friction is the friction the object needs to overcome to start moving. Kinetic Friction is the friction the system or object encounters while moving.
