Transforming PDE to ODE: How Can We Subsitute Correctly?
  • Thread starter Thread starter thepioneerm
    Ode Pde Research
This discussion focuses on the transformation of Partial Differential Equations (PDEs) to Ordinary Differential Equations (ODEs) using similarity transformations. Participants emphasize the importance of applying the chain rule for partial differentiation to derive the necessary equations. Specifically, the transformation involves evaluating partial derivatives and substituting new variables, leading to the cancellation of terms and simplification of the equations. The conversation highlights the need for a clear understanding of the relationships between variables and the proper application of mathematical techniques to achieve the desired results.
  • Understanding of similarity transformations in differential equations
  • Proficiency in applying the chain rule for partial differentiation
  • Familiarity with the notation and concepts of PDEs and ODEs
  • Ability to manipulate and evaluate partial derivatives
  • Study the application of similarity transformations in differential equations
  • Learn how to effectively apply the chain rule for multiple variables
  • Explore the derivation of ODEs from PDEs through specific examples
  • Practice using TeX for formatting mathematical equations in discussions
Mathematicians, physicists, and engineering students who are working on transforming PDEs to ODEs, as well as educators teaching advanced calculus and differential equations.
thepioneerm
From PDE to ODE ?! + research
In the attached research, What are the steps that we work to transform the equation (1) to (8)
(1) and (8)
I know that they used similarity transformations but I do not know how to do it by myself (how to substitute correctly) ...
can you help me to I understand the steps ... then I will do the others In the same way.
Thanks
Do you know how to apply the chain rule for partial differentiation? Try going to Wikipedia and searching on "chain rule", and reading the section on several variables. Then I think if you apply this to the research paper you attached you will see how they arrived at the equations. Basically, they chose a new set of variables so that after applying the chain rule and collecting terms, many terms canceled and the original set of PDEs was converted into a set of ODEs.
Thank you for this hint...I will try it :) and read:
http://en.wikipedia.org/wiki/Chain_rule
https://www.physicsforums.com/library.php?do=view_item&itemid=353
Q: How do I choose the appropriate similarity transformations to a particular system?!​
please ... help me ... just the first term in eq(1)
I try but failed :(
Show us your calculations on the first term in Equation 1. Learn how to use TeX so you can type it in.
I will try :(
is it right that u is in 3 variables : x and Fi Dash and M ?
please ... Is this true?! I took the second term in eq(1)
\partial w / \partial z
= ( \partial w / \partial \varphi ) . ( \partial \varphi / \partial \eta ) . ( \partial \eta / \partial z )
= (- \sqrt{b\nu} ) . ( \grave{\varphi} ) .( \sqrt{b/\nu} )
= -b \grave{\varphi}​
I think this is correct. Now if you look at the first term in equation 1, you see:
\frac{\partial{u}}{\partial{x}} = b \phi'(\eta)
so the two terms cancel and equation 1 is automatically satisfied. Keep going!
Thanks ...I appreciate it
but how do I get the equation (8) ?!
and
Yes, you need to consider u to be a function of x, \phi', and M. You need to evaluate all of the partial derviatives, like you did for
\frac{\partial{w}}{\partial{z}}
and plug these into equations 2-5, and you should come out with equations 8-12.
ok, but eq (1) say:
\frac{\partial{u}}{\partial{x}} + ( \partial w / \partial z) =0
so, I have evaluate all of the partial derviatives but How can I have eq (8) :( I do not understand !
Equation 8 comes from equation 2. Since u has a term proportional to \phi', when you evaluate
\frac{\partial^2{u}}{\partial{z^2}} , you will get a term in \phi''' . Do you see?
ok ... I will try :)
Thank you
  • · Replies 36 ·
