FTIR Machine: Interference of Blackbody Radiation Source
  • Thread starter Thread starter physical101
    Ftir Machine
The discussion centers on the operation of FTIR (Fourier Transform Infrared) spectrometers, specifically regarding the interference of light from a blackbody radiation source. It is established that the infrared source emits a broad spectrum of frequencies, which are split at the beam splitter. Half of these frequencies are retarded, leading to the formation of a resultant wave that passes through the sample and reaches the detector. The interference of the reflected and transmitted beams at the beam splitter is crucial for the functioning of the FTIR machine.
  • Understanding of FTIR spectrometry principles
  • Knowledge of beam splitter functionality
  • Familiarity with blackbody radiation concepts
  • Basic grasp of wave interference phenomena
  • Study the principles of Fourier Transform spectroscopy
  • Learn about the role of beam splitters in optical systems
  • Investigate blackbody radiation and its applications in spectroscopy
  • Explore wave interference and its significance in FTIR analysis
Students and professionals in physics, chemistry, and engineering, particularly those involved in spectroscopy and optical analysis using FTIR machines.
physical101
Hi there sorry to keep bombarding you all with these stupid questions but I just can't picture it in my head. In a FTIR machine when the blackbody radiation source is split at the beam splitter and half the frequencies are retarded before making a resultant wave and passing through the sample and reaching the detector, would I be correct in thinking that all of the frequencies emitted from the blackbody radiation source interfere to produce one resultant wave which is then detected at the detector?
Well FTIR spectrometers have a infrared source(IR), has a broad spectrum, first goes to the beam splitter then 50% is reflected and transmitted. The reflected beam is reflected back by the fix mirror and the transmitted beam is reflected by the moving mirror to the beam splitter. Two beams interfere at the beam splitter then go through the sample.
  • · Replies 29 ·
  • · Replies 21 ·
  • · Replies 18 ·
14K
