Fubini-Study metric of pure states
  • Context: Undergrad
  • Thread starter Thread starter Alex Cros
    Metric Pure States
The discussion revolves around the derivation of the Fubini-Study metric for pure states in quantum mechanics, specifically the expression for the angle between two state vectors. Participants explore the mathematical formulation and properties of this metric, including its interpretation as a distance measure and its connection to inner products in vector spaces.
  • One participant seeks help deriving the expression for the Fubini-Study metric, starting from the definition of distance between two vectors.
  • Another participant suggests considering the angle between unnormalized vectors and relates this to the dot product in simpler vector spaces.
  • There is confusion regarding the terminology of "length" versus "distance" in the context of the metric, with some participants noting that angles can define a metric.
  • Participants discuss the properties of metrics and whether the derived expression satisfies these properties, including non-negativity and symmetry.
  • One participant proposes a derivation involving the law of cosines in real vector spaces before generalizing to complex spaces.
  • There is a challenge regarding the correctness of a term in a proposed expression for distance, with a suggestion to clarify the formulation of the Fubini-Study metric.
Participants express differing views on the terminology and interpretation of the metric, particularly regarding the use of "length" and "distance." There is no consensus on the best approach to derive the Fubini-Study metric, and multiple perspectives on the derivation process are presented.
Participants note that the derivation involves assumptions about the normalization of vectors and the properties of inner products. The discussion also highlights the potential confusion arising from the terminology used in the context of metrics.
Alex Cros
Hello PF!
I was reading
https://en.wikipedia.org/wiki/Fubini–Study_metric (qm section like always :wink:)
And can't figure out how to derive:
[tex]\gamma (\psi , \phi) = arccos \sqrt{\frac{<\psi|\phi><\phi|\psi>}{<\psi|\psi><\phi|\phi>}}[/tex]
I started with
[tex]\gamma (\psi , \phi) =|| |\psi> - |\phi>||= \sqrt{(<\psi|-<\phi|)(|\psi>-|\phi>)}=...[/tex]
as it is the distance between the two vectors (no?) but don't seem to get anywhere, help!
NB: I assumed there the vectors are normalized + apologies for the dirac notation format.
Many thanks in advance!
Alex Cros said:
I was reading
I started with
That's not what you want. Try thinking in terms of finding the angle between 2 unnormalized vectors. E.g., in a simpler real vector space, what is the dot product of 2 vectors ##u \cdot v## ? Then generalize to a complex vector space.
If they're normalized then the denominator of your 1st expression is 1.
I'm confused by the use of: "length between those two points".
But why then is it called the distance between those two points?
I think I know what you are saying: take the inner product and solve for the angle, then you get the arccos, but in the article I sent it was referred as the length. Moreover the ultimate aim of doing this is to derive the ds element by [itex]|\psi> →|\psi + d \psi>[/itex] and finding the length between them two.
I'm confused by the: "the length between two points"
Because angles between vectors in a vector space satisfy the properties of being a metric.
(You should indeed try and prove this assertion. I'll help you if you get stuck.)
I think I know what you are saying: take the inner product and solve for the angle, then you get the arccos, but in the article I sent it was referred as the length. Moreover the ultimate aim of doing this is to derive the ds element by [itex]|\psi> →|\psi + d \psi>[/itex] and finding the length between them two. I'm confused by the: "the length between two points"
It's just an abuse of terminology. The crucial thing is that it defines a metric. When 2 state vectors are maximally "close" to each other it means the angle between them is 0. When 2 state vectors are maximally different from each other, that corresponds to them being orthogonal. I.e., the angle between them is 90deg.
The ##ds## variant is just a special case of the main formula for when the state vectors are only infinitesimally different from each other, hence the angle between them is very small. I find it a bit misleading to call it ##ds## when it's really a small angle, but this usage is quite common.
Okay I see now what you mean now, yeah I agree it's quite confusing the notation. Either way I would be very grateful if you could give me a hand with this derivation by quicking off with the first steps please!
Thanks beforehand!
Thanks beforehand!
Okay,I think I just proved that (even though its not Fubini-Study metric) [itex]|| |\psi>-|\phi> ||[/itex] is a metric aswell, as it satisfies [itex]d(x,y)≥0 , d(x,y)=0 ↔ x=y, d(x,y)=d(y,x) & d(x,z)...[/itex]etc. is this the case? or have I made a mistake?
The final bit just involves the triangle inequality, applied to norms on a vector space.
Heh, well,... actually, I'll let you "quick off" the first steps, and then I'll help if you get stuck.
Hint: start with the case of a real vector space ([wherein you'll need to know about the (spherical) law of cosines]. When you've done the real case, you can generalize the law of cosines to a complex vector space.
Okay, I first let you know my original attempt to comment on my procedure:
Let [tex]dist(\psi,\phi) = || \psi - \phi || = \sqrt{ < \phi, \phi> + < \psi, \psi> - 2 || < \psi, \phi> ||}[/tex] which is a metric.
now [tex]dl = dist(\psi+d\psi,\phi) = \sqrt{ < \phi, \phi> + < \psi + d\psi, \psi + d\psi> - 2 || < \psi +d\psi, \phi> ||}[/tex]
expanding [tex]dl = \sqrt{ \phi * \phi + \psi * \psi + \psi * d\psi + d\psi* \psi +d\psi*d\psi* - 2||\psi * \phi +d\psi * \phi|| }[/tex]
where [itex]*[/itex] denotes complex conjugate on the left
Alex Cros said:
Let [tex]dist(\psi,\phi) = || \psi - \phi || = \sqrt{ < \phi, \phi> + < \psi, \psi> - 2 || < \psi, \phi> ||}[/tex] which is a metric. [...]
Are you sure about that last term under the square root? Are you sure it's not ##2 Re\langle\phi,\psi\rangle## ?
In any case, I'm reasonably sure that's not the right point to start from if you want an FS metric.
Do you want to derive the finite form of the FS metric (the one in the Wiki page with an arccos, i.e., ##\gamma(\psi,\phi)=\arccos \sqrt{\cdots}##), or do you just want to start with that finite form and derive the corresponding infinitesimal version ##ds^2 = \cdots## ?
  • · Replies 21 ·
