Function expansion in Cartesian and spherical tensors
  • Context: Graduate
  • Thread starter Thread starter Malamala
The discussion focuses on the function expansion of the integral $$V(\mathbf{R}) = \int_0^\infty f(\mathbf{r})/|\mathbf{R}-\mathbf{r}|d^3\mathbf{r}$$ in Cartesian and spherical tensors. The first referenced paper claims that the ##l=3## term in the Cartesian expansion is reducible and can be expressed as a sum of a rank 1 irreducible tensor and a rank 3 irreducible tensor. In contrast, the second paper indicates that the ##l=3## term in the Legendre polynomial expansion is already an irreducible tensor of rank 3, lacking a rank 1 component. This discrepancy raises questions about the equivalence of terms across the two expansions and the representation of regions defined by r>R and r PREREQUISITES
  • Understanding of Cartesian and spherical tensor representations
  • Familiarity with Legendre polynomials and their properties
  • Knowledge of integral calculus in three dimensions
  • Basic concepts of irreducible tensor decomposition
  • Study the properties of irreducible tensors in quantum mechanics
  • Learn about the application of Legendre polynomials in physics
  • Explore the mathematical foundations of tensor calculus
  • Investigate the implications of tensor expansion in electromagnetic theory
Physicists, mathematicians, and researchers working in fields involving tensor analysis, particularly those focusing on quantum mechanics and electromagnetic theory.
Malamala
Hello! My question stems from reading several physics papers (here are two relevant ones: https://journals.aps.org/prc/abstract/10.1103/PhysRevC.56.2820 and https://journals.aps.org/pra/abstract/10.1103/PhysRevA.65.032113). I will simplify the problem for the purpose of this question. Basically, I have an integral of the form:
In the first paper above (eq. A2) they expand the ##1/|\mathbf{R}-\mathbf{r}|## term in cartesian tensors and they claim that the ##l=3## term is an reducible tensor (in terms of spherical tensors), which can be written as the sum of a rank 1 irreducible tensor and a rank 3 tensor irreducible tensor.
In the second paper, they do the expansion in terms of Legendre polynomials (eq. 7), using:
$$1/|\mathbf{R}-\mathbf{r}| = \sum_l\frac{r_<^l}{r_>^{l+1}}P_l(\cos\theta)$$
If I understand it correctly, in this case, the ##l=3## term is already an irreducible tensor of rank 3 (without any rank 1 tensor component). My questions are:
1. Why the terms for a give l are not the same between the 2 expansions? I assumed that they are only written in 2 different frames (i.e. they have a different form when written down), but it seems like the terms for the same l are not the same. Does this mean that the l=1 term in the Legendre expansion is equal to the l=1 term in the Cartesian expansion PLUS the extra rank 1 tensor coming from the l=1 term in the Cartesian expansion? Can there be other l>3 terms in the cartesian expansion that also contain rank 1 tensors?
2. In the Legendre expansion we have a clear separation between r>R and r<R. Where is this hidden in the Cartesian expansion?
If we expand a function as \sum_{n=0}^\infty a_nx^n and also as \sum_{n=0}^\infty b_n P_n(x), do we expect a_n \equiv b_n for each n?
Because P_n is a polynomial of order n, expanding both expressions to n = N will get all terms of order x^N or lower, but the coefficients will in general be different. If we replace P_n by its definition in terms of powers of x, then the two expressions should simplify to the same result.
The same principle applies here.
  • · Replies 38 ·
  • · Replies 30 ·
