Undergrad Function for line segment configuration between dots
The discussion focuses on determining the number of line segment configurations between a given number of dots, including cases with no connections. For 0 or 1 dot, the configurations are 0 and 1, respectively, while for 2 dots, there are 2 configurations. As the number of dots increases, the number of possible connections grows, with calculations suggesting that for 4 dots, there are 64 configurations and for 5 dots, 1024 configurations. The participants explore a potential formula, arriving at 2^(d(d-1)/2) for d dots, which aligns with graph theory principles. The conversation concludes with the acknowledgment that the formula appears to accurately represent the number of configurations.
Labyrinth
If I have n dots, how many configurations exist for lines that connect them, including no connections?
For example, if I have 0, or 1 dots I believe this should be 0 since no connections are possible (or perhaps I should consider the single dot as having a single connection to itself?) If I have 2 dots, there would be two possibilities, one connection between the two, and zero connections.
To clarify what I mean, for three dots I counted 8: http://i.imgur.com/EHZLcYe.png
For four dots I counted 65, but I could be wrong as I was drawing them and this is error prone: http://imgur.com/Zw0JM0j
The final possibility used 6 lines.
I tried looking through various possibilities and renditions in OEIS, but nothing popped out.
I'm having trouble coming up with a function that returns such an odd sequence as 0,0,2,8,65. I'm hoping that I goofed, because 0,0,2,8,64 looks a lot more palpable.
Surely this function is known? Or something very similar?
Thank you for your time.
Mathematics news on Phys.org
0 dots: Well...
1 dot: There is 1 configuration: no lines.
4 dots: There are 6 possible lines, they all can be present or not (2 options each), for a total of 26=64 options.
Do you see the pattern?
In your image, the "N" pattern has a duplicate: second block, first column third row and second column fourth row.
Likes Labyrinth
mfb said:
0 dots: Well...
I'll just use zero for 0 dots.
0,1,2,8,64..
0,20,21, 23, 26..
I suppose 5 dots would have 8 lines to connect them all, so I should expect 2^8 configurations, if the function is 2^n where n is number of lines to connect all the dots. Now I need a function that gets n from a number of dots.
For two dots it was one line, three dots, 3 lines, four dots, 6 lines, 5 dots, 8 lines, 6 dots, 14 lines.
undefined,0,1,3,6,8,14 Ugh.
Thank goodness!
Why 8? Compared to 4 dots (6 possible edges), you get 4 additional options for an edge - one for each of the original dots. 6+4=10.
Likes Labyrinth
You are correct. I got the number wrong for 6 dots too, sigh. I believe it is 15.
So to make a chart:
dots max lines configurations (assuming 2^(maxlines))
0 undefined 0
1 0 1
2 1 2
3 3 8
4 6 64
5 10 1024
6 15 32768
It's hard to believe that 6 dots would have so many configurations.
So for d dots I get:
2(d/2)(d-1)
For zero dots I get one configuration this way, but oh well. Not all that important.
jim mcnamara said:
I came across that link when looking at this, but I didn't understand it and so wasn't even sure if it fit the problem I was trying to solve. Looking at it more carefully I see that it is quite relevant :-)
Assuming 2(d/2)(d-1) holds, I believe my question has been answered. Thanks for the help.
That is the right formula.
I think that is a natural result. Same as for one dot, "no connections" is the unique configuration.
Likes Labyrinth
  • · Replies 0 ·
  • · Replies 0 ·
