Functional equation f(x)=f(x^2)
  • Thread starter cliowa
    Functional
3 replies · 4K views · last reply
cliowa
Hello everybody
I'm given a continuous function f (from the real numbers to the real numbers) which I know obeys the following functional equation:
[tex]f(x)=f(x^{2})[/tex]
How can I proof that this function is constant?
I started out like this: Looking at a number x in [tex][0,1[[/tex] I said to myself that:
[tex]f(x)=f(x^{2})=f(x^{4})=f(x^{16})=...\rightarrow f(0).[/tex].
As this relation holds for all x in [0,1[ (looking at [tex]x^{2^{n}} (n \rightarrow \infty[/tex]), it should be true that f(x)=f(-x)=f(0) (the minus because of symmetry, the square). I can also conclude that f(0)=f(1), for f is continuous. But how do I proceed? I would like to show that this function is constant for all x in the real numbers?
Any help will be appreciated.
Regards...Cliowa
If x is a positive real, you also have [tex]f(x)=f(\sqrt{x})[/tex]. Use this for x>1.
Oh my gosh, I should have gotten that one on my own.
Now it seems clear. Thanks a lot, shmoe.
Best regards
Cliowa
If [tex]f:\mathbb{R}\rightarrow\mathbb{R}[/tex] is a continuous function such that [tex]f(x)=f(x^{2}),\forall x\in\mathbb{R}[/tex], then
i. f is an even function since [tex]f(x)=f(x^{2})\Rightarrow f(-x)=f((-x)^{2})=f(x^{2})=f(x)[/tex]
ii. [tex]f(x)=f(x^{2^{n}}),\forall n\in\mathbb{Z}[/tex] which can be proved inductively, or simply reasoned much as you have above:
for positive integer n,
[tex]f(x)=f(x^{2})=f(x^{4})=f(x^{16})=\cdots =f(x^{2^{n}})[/tex]
and for negative integer n=-k,
[tex]f(x)=f(\sqrt{x})=f(\sqrt{\sqrt{x}})=f(\sqrt{\sqrt{\sqrt{x}}})=\cdots =f(x^{2^{-k}})[/tex]
