Fundamental Frequency and Musical Harmonics
The discussion confirms that the 3rd harmonic of a fundamental frequency of 15Hz is indeed 45Hz. This is derived using the formula f_n = n * f, where f_n represents the n-th harmonic and f is the fundamental frequency. The 3rd harmonic is calculated as three times the fundamental frequency, thus 15Hz x 3 equals 45Hz. The explanation emphasizes the role of harmonics in enriching sound complexity.
  • Understanding of fundamental frequency and harmonics
  • Familiarity with the formula f_n = n * f
  • Basic knowledge of sound wave properties
  • Concept of musical pitch perception
  • Research the relationship between harmonics and musical timbre
  • Explore the effects of different fundamental frequencies on harmonic series
  • Learn about Fourier analysis in sound synthesis
  • Investigate applications of harmonics in musical instrument design
Musicians, audio engineers, sound designers, and students studying acoustics or music theory will benefit from this discussion.
helpmeplease
Ok, I was given a question in homework and was never told the right answer.
If the Fundamental Frequency = 15Hz, the 3rd Harmonic = ?
I estimated it at 45Hz because of an example
The example was;
Harm 1 = 100 x 1 = 100Hz
Harm 2 = 100 x 2 = 200Hz
Harm 3 = 100 x 3 = 300Hz
If so, the third Harm is 3:1, Ergo, if Harm 1. WAS 15Hz, you'd use the 3:1 which was applied on the example and discover it was 45Hz.
Am I correct in saying this or is it something different?
It's good. The formula is
f_n=nf
where f_n is the n-th harmonic and f is the natural frequency, aka first harmonic.
Your estimation of 45Hz for the 3rd harmonic is correct. The fundamental frequency is the lowest and most basic frequency in a sound, and it is the frequency that we perceive as the pitch of a musical note. The 3rd harmonic is three times the fundamental frequency, so in this case, it would be 45Hz (15Hz x 3). This is because the 3rd harmonic is the third multiple of the fundamental frequency, and each multiple adds another layer of complexity to the sound, creating a richer and more complex tone. So, you are correct in saying that the 3rd harmonic would be 45Hz in this scenario. Keep up the good work in your homework!
10K
  • · Replies 37 ·
