Gas Strut - Damping coeff and spring constant
The discussion revolves around the sizing of a gas strut for a trunk lid opening mechanism, specifically focusing on the determination of damping coefficients and spring constants, which are not typically provided in datasheets. Participants explore methods to estimate these values and discuss the dynamics of gas struts.
  • One participant seeks approximated values for damping coefficients and spring constants, noting the lack of such information in datasheets.
  • Another participant provides a calculation for the spring constant based on specific part numbers and forces, suggesting that the viscous damping coefficient might be relatively high, indicating potential overdamping or slight underdamping.
  • A different participant references a brochure that describes the damping force as effectively constant and independent of velocity, arguing that this complicates the estimation of a viscous damping coefficient.
  • They propose a model of dynamics involving a mass-on-a-spring system with constant friction, discussing the implications for motion and equilibrium positions.
  • One participant shares a mathematical approach involving polytropic processes to derive a damping coefficient, referencing external sources for further information.
Participants express differing views on the nature of damping in gas struts, with some suggesting that the damping force is constant while others explore the implications of variable damping coefficients. No consensus is reached on the exact values or models applicable to gas struts.
Limitations include the lack of specific damping coefficient values in datasheets, the dependence on assumptions about the nature of damping forces, and the unresolved mathematical steps in deriving coefficients from physical parameters.
Maurk
Hello everyone,
I'm an engineering student and I have to "size" a gas strut (i.e. spring+damper) to model a trunk lid opening mechanism.
I have a problem: on every "datasheet" (something like this http://www.strutsdirect.co.uk/components/variable-force-gas-struts.php) only forces and dimensions are written but there's nothing about damping coefficient and spring constant.
So, I would like to ask you if someone could tell me some approximated possible damping coefficient and spring constant values or how to obtain them from a datasheet.
Thanks.
Maurk: Perhaps try here[/color]. E.g., for part number V06AAA0400, s = full stroke = 50 mm, P1 = initial force = 400 N, and P2 = final force = 1.2*P1 = 480 N. Therefore, spring constant is k = (P2 - P1)/s = (480 - 400)/50 = 1.60 N/mm. Therefore, when strut displacement is delta = 25 mm, the strut force would be P = P1 + k*delta = (400 N) + (1.60 N/mm)(25 mm) = 440 N.
I currently suspect the viscous damping coefficient is relatively high, and that the strut is perhaps overdamped (zeta > 1), or only slightly underdamped (zeta > 0.7). But I do not know the damping coefficient. I hope someone else reading this forum can give you a very rough estimate of the viscous damping coefficient (c), or the viscous damping factor (zeta).
This has some information on damping (some of the brochure is in German but the diagrams are labelled in English). See page 7.
http://www.stabilus.com/fileadmin/docs/deutsch/Printmaterial/Prospekte_allgemein/Standardprogramm_2010_niedrig.pdf
The damping force (FR on the diagram) is effectively constant and independent of velocity, so trying to come up with equivalent viscous damping coefficient isn't very useful. A model of the dynamics is like a mass-on-a-spring, with the mass sliding on a table with a constant friction force whose direction is opposite to the velocity of the mass.
When the mass is moving in one direction, the equation of motion is ##Mx'' + Kx = +F## and in the other direction it is ##Mx'' + Kx = -F## where ##F## is a constant force (not proportional to velocity, like a viscous damping force).
The motion is a sequence of undamped half-cycles of simple harmonic motion, with the amplitude of each cycle reducing by a constant amount when the damping force changes direction.
The equations of motion above don't have a unique equilibium position. The mass can stop at any position where ##|Kx| <= F##, i.e. at any position x where that the magnitude of the spring force ##Kx## is less than the "dynamic friction force" ##F##.
For a real gas damper, the system usually "creeps" to the equilibrium position where ##F = 0## after it stops oscillating, but trying to model that final stage of the motion isn't of much practical interest.
I apprecitate your time and effort. Thank you everyone. I will use your suggestions.
p\cdot V^{n}=p_0\cdot V^n_0=constant \\ \frac{p}{p_0}=(\frac{V_0}{V})^n \\ F(s) --&gt; \int_{0}^{F} dF = A \cdot \int_{p0}^{p} dp \\ F=A\cdot p_0 (\frac{p}{p_0}-1) \\ F(s)=A\cdot p_0\cdot ((\frac{h}{h-s})^n -1) \\ c(s)=\frac{dF}{ds} = \frac{A\cdot dp}{ds}=\frac{A^2\cdot dp}{dV}
with some more integration we get
c(s)=\frac{A\cdot p\cdot n}{h-s}
p=pressure
V=volume
h=height of cylinder
s=h-current height of cylinder
A=area of cylinder pushing on the gas
n=polytropic constant
also found this on the german wikipedia
http://de.wikipedia.org/wiki/Gasdruckfeder
i don't know german that well to get anything useful off this but try using google translate maybe it can help.
  • · Replies 21 ·
21K
