Why Does Fire Not Travel Backwards in a Gas Hose During Ignition?
  • Context: Undergrad
  • Thread starter Thread starter Lacplesis
    Explosion Gas Tank
The discussion centers on the phenomenon of fire propagation in gas hoses during ignition. It is established that fire does not travel backwards into the hose due to the pressure of the gas or fluid exiting the hose, which prevents the flame from moving inward. Additionally, the lack of sufficient oxygen within the hose contributes to this effect, as combustion requires an adequate oxygen supply. The conversation also touches on the potential risks associated with dripping fuel, which could create conditions for an explosion if the right amount of fumes accumulates.
  • Understanding of combustion principles
  • Knowledge of gas dynamics
  • Familiarity with pressure and fluid mechanics
  • Basic concepts of fire safety
  • Research the principles of combustion and flame propagation
  • Study gas dynamics in pressurized systems
  • Learn about fire safety measures in handling flammable liquids
  • Examine case studies of gas explosions and their causes
This discussion is beneficial for safety engineers, fire prevention specialists, and anyone involved in the handling of flammable gases and liquids.
Lacplesis
Hi , a simple question arose in my head , why is that every time I have seen a hose attached to a gas tank being set on fire the fire always burns out of the end of he hose but the fire never travels backwards inside the hose back to the tank to explode it.
the same I suppose happens to a gasoline pumps hose which you normally stick in your cars fuel tank , i assume if you would lite it on fire and hold it open the fireball would never travel back inwards into the hose.
Why is this so? is it because there is pressure and fluid/gas coming out so fire cannot get in or also because in the hose there is very little oxygen so the flame cannot go back more so it stays at the end of the hose where the fluid/gas stream meets fresh air (oxygen) ?
what happens when the pressure of the gasoline or gas ends up and the hose begins to drip could the flame catch backwards inside the hose then ? and travel to the tank and if there would be the right amount of fumes make it explode then ?
this has been shown many times in movies both correctly and incorrectly so i wonder.
thanks.
Science news on Phys.org
Oxygen.
12K
11K
