Gaussian integral with x^2 factor and shifted variable
8 replies · 3K views
TheMightyJ
Basically, i have to find the solution to:
Int( x2 * exp (-(x-w)^2) , x= -infinity.. infinity)
I realize this is connected to Gaussian Integration. So that if i have Int (exp(-x2), x=-infinity ... infinity) the answer is sqrt(Pi)
Also, i have read that there is a trick to solving such an integral.
you would consider F(a) = Int exp( - a * x^2) ( = sqrt(pi/a) ).
and then int dx x^2 exp(-x^2) = - F'(a) for a=1.
i understand this.
Basically, the above is how i have attempted to work a way towards the solution, the trouble i am having is with a substitution i realize i must make at some point. at some point i must have x = x - w
But how do i implement this substitution??
This is my first post here, so hopefully that was somewhat clear and the relevant info is there. Thanks for any help.
I don't know if this is the easiest solution, but you can try u = x - w. The integral splits into three integrals, which can be solved easily.
u = x-w
du = dx
Then, x = u+w, so x^2 = (u+w)^2, and the integral becomes:
[tex]\int (u+w)^2 e^{-u^2}\,du[/tex]
Will give that a try! thank you very much!
Yep, tried it and it worked, brilliant, thank you!
Okay, so there is another question, similar in some ways to the previous one, but i am also having trouble. Mainly I am stuck on where to start!
The integral this time is
Int ( e-(x-w)2 - j*x dx
the limits of integration are again, -infinity to infinity.
obviously there is some sort of gaussian integral stuff going on, but that "-j*x" has thrown me off, how should i deal with this?
just an idea to help me get started would be muchly appreciated, thanks!
You need to complete the square in this case. That is write (x-w)^2+jx as (...)^2+constant.
Obviously. Thank you! really not spotting obvious techniques today. Thanks for the help!
j is not the imaginary number j (or i) right? If it is, that makes matters a little different.
no no, j is just the coefficient of x. Thanks.
