Gaussian Wave packet- Griffiths 2.22
The discussion focuses on calculating the expectation value of momentum squared, , for a Gaussian wave packet represented by the wave function psi(x,0)=A*exp(-ax^2). The user is uncertain about the correct integral expression to use for , debating between =Int(|psi|^2*(-1*h^2*d^2/dx^2))dx and =Int(psi*(-1*h^2*d^2/dx^2(psi-conjugate)))dx. The user attempts to evaluate the integrals but encounters complex terms and seeks clarification on the proper method, including the use of complex conjugates and substitution techniques.
  • Understanding of quantum mechanics principles, specifically wave functions and expectation values.
  • Familiarity with Gaussian functions and their properties.
  • Knowledge of calculus, particularly integration techniques involving complex functions.
  • Experience with complex conjugates and their application in quantum mechanics.
  • Study the derivation of expectation values in quantum mechanics, focusing on momentum operators.
  • Learn about Gaussian wave packets and their significance in quantum mechanics.
  • Explore integration techniques for complex functions, including substitution methods.
  • Review the properties of complex conjugates and their role in quantum mechanical calculations.
Students and professionals in quantum mechanics, particularly those studying wave functions and expectation values, as well as physicists working with Gaussian wave packets and complex integrals.
lazyluke
Hi, The problems asks to calculate multiple things for a Gaussian wave packet. Steady state function: psi(x,0)=A*exp(-ax^2).My problem is that I'm stuck at calculating <p^2>.
<p^2>=Int(|psi|^2*(-1*h^2*d^2/dx^2))dx or
<p^2>=Int(psi*(-1*h^2*d^2/dx^2(psi-conjugate)))dx ?
I am not sure if I can use the expression for |psi|^2- which is already defined and I think calculating the second expression will be wrong since it will give us an answer with i and t sine the exponent from complex conjugate of psi will come down or am i wrong?
I know I'm doing something wrong since after i evaluate integrals I get:
<p^2>=4*(2/m)^(1/2)*w^6h^2*(4w^2*(pi/w^6)^(1/2)-2(1/2(pi/w^2)^(1/2)) where w=(a/(1+(2ihat/m)^2)^1/2 which cancels out to 0, somehow I should get ah^2. Now I'm not sure is I should use <p^2>=Int(|psi|^2*(-1*h^2*d^2/dx^2))dx where its a second derivative of |psi|^2 or <p^2>=Int(psi*(-1*h^2*d^2/dx^2(psi-conjugate)))dx where the second derivative is only of the complex conjugate and not the |psi|^2. Or I should not use the w just use the expression defined above? (I thought since w is independent of x it would not matter). Any help will do, just before Sunday evening as its due on Monday morning.
&lt;p^2&gt;=|A|^2 \int \psi^*(-h^2 \frac{d^2}{dx^2} \psi)dx
Is the correct way to evaluate the expectation value.
As for the integral, I believe there is a very cleaver u-sub to (easily) solve this problem.
Sorry just came to me:
Can I use:
<p^2>=m^2*(d^2(<x>^2)/dx^2) or it doesn't work like that?
nvm...<x>=0 :(
Ok, I don't know any U-sub, it will help to know about it anyway- but i understand if you don't want to give me a straight answer to my problem- maybe after monday you can tell me how to do that the "easy way", now I am going through that mess and I am left with something like this:
(1/(1+ib)^(1/2))*(1/(1-ib)^(1/2)) where b=2hat/m and i is imaginary number, do those cancel? I cannot solve this and I tried to use one of those equation solvers on internet and won't do it neither... *the second expression suppose to be a complex conjugate of the first one... please help
Well \int_{\infty}^{\infty} e^{-ax ^2} dx = \frac{\sqrt{\pi}}{\sqrt{a}} = f(a) right?
What's f'(a)?
The function you're trying to integrate looks like:
-2 a h^2 \int_{\infty}^{\infty} -e^{-2 a x^2} + 2 a x^2 e^{-2 a x^2} dx
Which looks sort of like b f(a) + c f'(a) if b and c are just constants, doesn't it?
well... yes... but i solved it using int(exp(-ax^2)dx=(pi/a)^(1/2) and int(x^2*exp(-ax^2)dx=1/2(pi/a^3)^(1/2) which i believe yields the same output... I kind of understand the logic here... thanks for the tip as this will be easier then memorizing the common integrals :]... the only problem now is that i have an answer looking like this:
<p^2>=h^2*a*(1/(1-2ihat/m)^(1/2))*(1/(1b2ihat/m)^(1/2)) and basically my question is:
(1/(1-ib)^(1/2)*(1/(1+ib)^(1/2))=1?
I know this is multiplying a complex number by its complex conjugate but does this case works since the complex number is under a square root? or maybe i defined wrong complex conjugate for this? the original expression is:
(1/(1-(2ihat/m))^1/2))) what is its complex conjugate? what does this reduce to? it seems like it should be 1 since the real part is 1/1 so 1^2=1 but how this works in this case with above expression? I hope you can understand which part I am having a problem with...
  • · Replies 30 ·
