General Formula For Reflection Direction
The discussion revolves around finding a general formula for the direction of reflection of a particle colliding with a wall, considering both horizontal and vertical tangents. Participants explore the relationship between the incidence angle and the reflection angle in different scenarios.
  • Exploratory, Technical explanation, Debate/contested
  • One participant presents a scenario where a particle collides with a wall at 32°, reflecting at different angles depending on whether the wall is horizontal or vertical.
  • Another participant suggests that the reflected angle can be calculated using the formula C = B - A, where A is the incoming angle and B is the angle normal to the wall.
  • A different participant proposes a general formula for reflection direction as C = 180 + 2B - A, clarifying the roles of A and B in this context.
  • One participant corrects their previous formula to C = 2B - A, acknowledging the relationship between normal and tangent angles.
  • Another participant expresses gratitude for the discussion, indicating it was helpful for their understanding.
Participants do not reach a consensus on a single formula for reflection direction, as different formulas are proposed and corrections are made throughout the discussion.
The discussion includes varying interpretations of the angles involved and the relationships between them, which may depend on specific definitions or assumptions about the wall's orientation.
VeryBadAtMath
An Example Scenario:
A particle moves at 32° and collides with a wall. This wall is rectangular in nature, which means that there is both horizontal and vertical sides.
On a horizontal tangent, it would work like this (sorry for ugly, not-to-scale diagrams):
[PLAIN]http://img198.imageshack.us/img198/7808/questionsc.jpg
(reflects at 148°)
However, on a vertical tangent it would reflect like this:
[PLAIN]http://img808.imageshack.us/img808/2064/question2.png
(reflects at 328°)
This means that:
  • On horizontal tangent: reflectionDirection = 180-incidenceDirection
  • On vertical tangent: reflectionDirection = 360-incidenceDirection
It's lame to have two different formulas, so is there a general formula for the reflectionDirection that works with both vertical and horizontal tangents? It's fine if it uses radians instead of degrees.
Mathematics news on Phys.org
If the incoming angle is A, and B is an angle normal to the wall, then the reflected angle C is given by C = B - A.
Thanks, but that was not what I was looking for.
In case someone else needs to know, the general formula is:
C = 180+2B-A
Where A is the direction of incidence, B is the direction of tangent (0 if horizontal, 90 if vertical) and C is the direction of reflection.
Well the normal and tangent angles are 90 degrees different, so it all works.
Also, I meant C = 2B - A in my last post, sorry.
Thanks a lot for this conversation. I was searching for this...
11K
19K
