General principle of turbomachinery: true also for rocket turbopumps?
  • Thread starter Thread starter RobertGC
RobertGC
TL;DR
Discussion of an approach to high reusability of rocket engines.
A rule of thumb of aircraft engineers is every 10% increase in the power level engines are run at corresponds to a 50% decrease in engine lifetime. This is a general phenomenon of turbomachinery. Then it is likely it also holds for rocket turbopumps.
Then quite key is the rule also holds in reverse, every decrease in power level by 10% can result in doubling the lifetime of the engine. Then by running the engine at 0.9^5 = 0.60 power level can result in 2^5 = 32 times longer lifetime. For a rocket engine, this would bring the rocket engine lifetime into the range of jet engines of over a thousand reuses. It is notable as well that rocket engines can commonly be safely run at the reduced thrust level of 60%, i.e., this is within the safe throttlebility range.
So has this been tested in rocket turbopumps?
RobertGC said:
TL;DR: Discussion of an approach to high reusability of rocket engines.
It probably has been done, e.g., Space Shuttle Main Engine. One would have to query the team at NASA Stennis Space Center. I believe the SSME power head was disassembled and rebuilt after each flight for inspection, but it's been years since I looked into those details.
A Defining Era: NASA Stennis and Space Shuttle Main Engine Testing​
https://www.nasa.gov/centers-and-facilities/stennis/a-defining-era-ssme/#hds-sidebar-nav-3
SPACE SHUTTLE MAIN ENGINE TESTING: T PLUS 30 YEARS AND COUNTING​
https://www.nasa.gov/news-release/space-shuttle-main-engine-testing-t-plus-30-years-and-counting/
Since the first test on May 19, 1975, the NASA/contractor team at SSC has conducted more than 2,200 tests on SSMEs, including the ones that helped propel Space Shuttle Discovery on STS-114, NASA’s Return to Flight mission.
A total of 10 tests were conducted in the first two months to help establish fuel preburner, oxygen preburner and main combustion chamber ignition. Three years later, test teams at SSC were firing the Main Propulsion Test Article: the three-engine cluster that helps propel the Space Shuttle into orbit. On Jan. 21, 2004, SSC celebrated 1 million seconds of successful SSME engine firings, both in testing and flight operations. This milestone is a testament to the employees and to the engine itself, which has never experienced a major anomaly.
“The unmatched reliability and durability of the SSME serves as an enormous credit to the NASA/contractor teams that have manufactured and tested the engine for three decades,” said Ronnie Rigney, SSME Project Manager at SSC. “They’ve done an extraordinary job.”
There have been 114 missions since the first Space Shuttle took flight from Kennedy Space Center (KSC) on April 12, 1981, all powered by SSMEs tested at SSC.
History of Space Shuttle Main Engine Turbopump Bearing Testing at the Marshall Space Flight Center
https://llis.nasa.gov/lessons/24006...rd Gisbon et al released NTRS 20100023061.pdf
How NASA Tested the Space Shuttle: Ground Testing, Avionics, and Data Acquisition Explained​
https://dewesoft.com/blog/how-nasa-tested-space-shuttle
Summary of Results from Space Shuttle Main Engine Off-Nominal Testing
https://ntrs.nasa.gov/api/citations/20120001440/downloads/20120001440.pdf
SPACE SHUTTLE MAIN ENGINE THE FIRST TEN YEARS
https://gandalfddi.z19.web.core.win...ine The First Ten Years - Robert E. Biggs.pdf
Next-Generation RS-25 Engines for the NASA Space Launch System
https://ntrs.nasa.gov/api/citations/20170008958/downloads/20170008958.pdf
NASA, Aerojet Rocketdyne plan busy RS-25 test schedule for 2021​
https://www.nasaspaceflight.com/2020/12/nasa-aerojet-plan-busy-2021-test-schedule/
SSME to RS-25: Challenges of Adapting a Heritage Engine to a New Vehicle Architecture
6TH EUROPEAN CONFERENCE FOR AERONAUTICS AND SPACE SCIENCES (EUCASS) (2015)
https://ntrs.nasa.gov/api/citations/20150016499/downloads/20150016499.pdf
The RS-25 is pump-fed staged-combustion rocket engine burning liquid oxygen (LOX) and liquid hydrogen (LH2) to produce 2279 kN of vacuum thrust. Primary components involve two low-pressure turbopumps feeding into two
high-pressure turbopumps supplying propellants to the combustion devices, including two preburners, the main combustion chamber and nozzle. The preburners are independently controlled to provide variable thust and mixture ratio. In addition, the system was designed to be reusable, providing a certified service life of 55 starts and 27,000 seconds. The fuel-rich staged combustion cycle provides high performance, making it an attractive candidate in many vehicle trades for the SLS and prior conceptual vehicle studies
I do not know the programs for Space X or Blue Origin, and the details may be proprietary.
In reality, this doesn't work so well. To lift a given mass of rocket/payload while using only 60% (3/5) thrust will require engines that are 5/3 more powerful, and - in the best case - proportionally more massive. The challenge is to make up the additonal 2/5 of power without the corresponding increase in mass - i.e. more efficient, next gen tech.
Unlike jets, mass is still at a premium, over and above reusability.
* I think. I am no aerospace engineer.
its always been a dream of mine to visit the stars and now that I'm old enough and in a levels i wanted to send a bit of myself to space in a rocked like a hair or something but I've ran into some problems and came here to ask for your opinions on what fuel i should use and what material i should use the the shell of rocket as am only in first year a levels so any suggestions would be much appreciated and the fuel will take up about 90 percent mass and launch the rocket about 830Km the maths...
  • · Replies 45 ·
11K
9K
  • · Replies 46 ·
15K
11K
  • · Replies 21 ·
9K
