General solution to 2nd order ODE
6 replies · 5K views
forty
Find the general solution of the ordinary differential equation.
y'' - 7y'+ 6y = 2e^(3t) + te^(t)
First i found GS(H) by lettings y = e^(cx)
and got GS(H) = Ae^(6t) + Be^(t)
i then found PS(IH) y'' - 7y'+ 6y = 2e^(3t) by letting y = ae^(3t)
and got PS(IH) = -(1/3)e^(3t)
Now my problem
I am trying to find the other PS(IH) y'' - 7y'+ 6y = te^(t)
do i do this by letting y = (a+bt)e^(t) ??
Now my problem
Normally, you would try that but since et is already a solution to the homogeneous equation, this will not work. (Surely you have already tried and discovered that?) The standard step for this situation is to multiply by t: try y= (at+ bt2et.
you say try y= (at+ bt2et.
is that bracket suppose to be there? I am not sure if that's (at+bt^2)e^t or at+b(t^2).e^t
I used y = (at+bt^2)e^t
y' = (at+bt^2)e^t + (a+2bt)e^t
y'' = (at+bt^2)e^t + (a+2bt)e^t + (a+2bt)e^t + 2be^t
i substituted those in and equated coefficients and got the result a = o and b = 1/10
have i done this right ?
I didn't get that. For me, neither a nor b is zero. Why don't you check this by substituting it into the modified DE to see if it satifies the equation?
= (at+ bt^2)e^t+ 2(a+ 2bt)e^t+ 2be^t
You want y'' - 7y'+ 6y = 2e^(3t) + te^(t) and you've already done the "2e^(3t)" part.
y'' = (at+ bt^2)e^t+ 2(a+ 2bt)e^t+ 2be^t
-7y'= -7(at+bt^2)e^t - 7(a+ 2bt)e^t
+6y= 6(at+ bt^2)e^t
so y"- 7y'+ 6y= -5(a+ 2bt)e^t+ 2be^t= (-5a+ 2b)e^t+ -10bte^t= te^t. Equating "like coefficients, -10b= 1 so b= -1/10, not 1/10.
