Generating Images with CNN: Why is the Size Not Increasing in Each Layer?
  • Topic: Python
  • Thread starter Thread starter BRN
    Images
3 replies · 2K views
BRN
Hello everybody,
I have this problem:
starting from a vector of 100 random values, I have to generate an image of size 128x128x3 using a model consisting of a fully completely layer and 5 layer deconv.
This is my model
Python:
def generator_model(noise_dim):
    n_layers = 5
    k_w, k_h = [8, 8]
    input_dim = (noise_dim,)
    i_w, i_h, i_d = [8, 8, 1024] # starting filters
    strides = (1, 1)
    weight_initializer = None
    model = tf.keras.Sequential()
    model.add(tf.keras.layers.Dense(i_w * i_h * i_d, input_shape = input_dim, kernel_initializer = weight_initializer))
    model.add(tf.keras.layers.BatchNormalization())
    model.add(tf.keras.layers.ReLU())
    model.add(tf.keras.layers.Reshape((i_w, i_h, i_d)))
    for i in range(n_layers - 1):
        print(k_w, k_h)
        model.add(tf.keras.layers.Conv2DTranspose(i_d, (k_w, k_h), strides, padding = 'same', use_bias = False))
        i_d = int(i_d / 2)
        k_w = int(k_w * 2)
        k_h = int(k_h * 2)
    k_w = i_d
    k_h = i_d
    model.add(tf.keras.layers.Conv2DTranspose(3, (k_w, k_h), strides, padding = 'same', use_bias = False))
    return model
Why do I always get an 8x8x3 image without having an increase in size in each layer?
Thank's
Ok, I have the solution.
The size of the outputs of a CNN "conv" is given by the equation
$$o=\left ( \frac{i - k + 2p}{s} \right )+1$$
but, as in my case, for a transpose convolution "deconv" the size of the outputs is
$$o=s\left (i -1 \right )+ k - 2p$$
Then, with stride ##s=2##, the correct code is this
Python:
    n_layers = 4
    k_w, k_h = [16, 16] # starting kernel size
    strides = (2, 2)
    i_d = int(i_d / 2)
#        print(i_d, k_w, k_h)
        i_d = int(i_d / 2)
        k_w = int(k_w * 2)
        k_h = int(k_h * 2)
    return model
And this solves my problem :smile:
Great!
In the future, it would be helpful to readers to expand acronyms such as CNN, which might not be generally known. I'm assuming it has something to do with neural networks, but that's only a guess.
Hello and thanks!
You're right, CNN means Convolutional Neural Network.
Next time I will write the acronyms explicitly :smile:
