What is the function to extremise for finding geodesics on a Helicoid?
The function to extremise for finding geodesics on a helicoid is defined as $$f(\rho,\rho')=\sqrt{1+\frac{4\pi^{2}}{h^{2}}\rho^{2}+\left(\frac{d\rho}{dz}\right)^{2}}$$, where ##\rho' = d\rho/dz##. To derive the second derivative form $$\frac{d^{2}\rho}{dz^{2}}=F(\rho,\rho')$$, one must utilize the Euler equation $$\frac{\partial f}{\partial y}-\frac{d}{dx}\left(\frac{\partial f}{\partial y'}\right)$$ instead of the first-integral equation. The discussion clarifies the distinction between these two approaches, emphasizing that the first-integral equation is not merely a special case of the Euler equation but a separate method for solving variational problems.
  • Understanding of variational calculus
  • Familiarity with Euler-Lagrange equations
  • Knowledge of differential equations
  • Basic concepts of differential geometry
  • Study the derivation of the Euler-Lagrange equation in variational calculus
  • Explore the application of the Beltrami identity in one-dimensional problems
  • Investigate the properties of geodesics on different surfaces
  • Learn about the implications of the first-integral equation in variational problems
Mathematicians, physicists, and engineers interested in differential geometry, particularly those studying geodesics and variational principles in calculus of variations.
jayzhao
Given the Cartesian coordinates for a helicoid:
$$x=\rho cos\phi$$
$$y = \rho sin\phi$$
$$z=h\phi/2\pi$$
where ##\rho\in [0,\infty)##, ##\phi\in (-\infty,\infty)##, and h>0.
Set up the variational principle to search for geodesics on the helicoid. Use ##z## as the independent variable and ##\rho(z)## as the unknown function. Find the Euler equation for the ##\rho(z)## and rewrite it in the form
Euler equations:
For ##f(x,y(x),y'(x))##
When ##f(y(x),y'(x))## only:
$$f-\frac{\partial f}{\partial y'}y'=constant$$
I've got that length of a curve on the surface is:
$$L=\int_{-\infty}^{\infty}\sqrt{1+\frac{4\pi^{2}}{h^{2}}\rho^{2}+\left(\frac{d\rho}{dz}\right)^{2}}dx$$
So the function to extremise is:
Where ##\rho'=d\rho /dz##
But I don't know how to get this in the form
since there doesn't seem to be a second derivative in the function anywhere?
jayzhao said:
Relevant Equations:: Euler equations:
$$\frac{\partial f}{\partial y}-\frac{d}{dx}\left(\frac{\partial f}{\partial y'}\right)$$When ##f(y(x),y'(x))## only:$$f-\frac{\partial f}{\partial y'}y'=constant$$
Maybe they want you to use the Euler equation ##\frac{\partial f}{\partial y}-\frac{d}{dx}\left(\frac{\partial f}{\partial y'}\right)## rather than the "first-integral" equation ##f-\frac{\partial f}{\partial y'}y'= \rm {const}##.
Thank you! I think you're right that's what they wanted. I was getting confused because I thought the first integral equation was a "special case" of the Euler equation but it turns out they're two different things.
You can always differentiate the Beltrami identity to recover the Euler-Lagrange form (as long as your problem is one-dimensional).
Likes vanhees71 and PhDeezNutz
  • · Replies 0 ·
  • · Replies 36 ·
