Undergrad Understanding Geodesic Parametrization on a Sphere
This discussion focuses on the geodesic parametrization on a unit sphere using canonical spherical coordinates, specifically the parameters ##\theta## and ##\phi##. The differential length element is defined as $$dl = \sqrt{\dot{\theta}^2 + \sin^2(\theta) \dot{\phi}^2}$$, and the geodesic is derived by extremizing the integral $$\int_{\lambda_0}^{\lambda_f} \sqrt{\dot{\theta}^2 + \sin^2(\theta) \dot{\phi}^2} d\lambda$$ using the Euler-Lagrange equations. The discussion highlights the distinction between extremizing the Lagrangian ##L = \sqrt{\dot{\theta}^2 + \sin^2(\theta) \dot{\phi}^2}## and ##L' = L^2##, emphasizing that the latter imposes additional constraints leading to an affinely parametrized geodesic.
  • Understanding of spherical coordinates and their applications in differential geometry
  • Familiarity with the Euler-Lagrange equations in the context of classical mechanics
  • Knowledge of geodesics and their mathematical formulation
  • Basic grasp of variational principles in physics
  • Study the derivation of geodesic equations from the Lagrangian perspective
  • Explore the implications of affinely parametrized geodesics in differential geometry
  • Learn about the role of curvature in geodesic paths on different surfaces
  • Investigate the relationship between Lagrangian mechanics and general relativity
Mathematicians, physicists, and students studying differential geometry, particularly those interested in the applications of Lagrangian mechanics to geodesics on curved surfaces.
Jufa
Let us consider a sphere of a unit radius . Therefore, by choosing the canonical spherical coordinates ##\theta## and ##\phi## we have, for the differential length element:
$$dl = \sqrt{\dot{\theta}^2+sin^2(\theta)\dot{\phi}^2} $$
In order to find the geodesic we need to extremize the following:
$$ \int_{\lambda_0}^{\lambda_f} {\sqrt{\dot{\theta}^2+sin^2(\theta)\dot{\phi}^2}} d\lambda $$
We can do it so by imposing the Euler-Lagrange equations for the lagrangian ## L = \sqrt{\dot{\theta}^2+sin^2(\theta)\dot{\phi}^2} ## or equivalently, for the lagrangian ## L' = L^2 ##. These equations for L' look like:
$$ \ddot{\theta} +sin(\theta)cos(\theta)\dot{\phi}^2 = 0 $$
$$ \ddot{\phi}+ cot(\theta) \dot{\phi}\dot{\theta}=0 $$
I am pretty sure that I am right until here.
What does not make sense to me is the following:
Suppose you choose a curve in which ## \theta = \pi/2## i.e. both its first and second derivative vanish.
Then we get the following condition:
$$ \ddot{\phi} = 0 $$
But why does that happen? Once we have fixed the angle ## \theta## we have also fixed the curve (geodesic) and the only condition on ##\phi(\lambda)## should be that it is continuous and injective (i.e., it does not make ##\phi## go back and forth).
For example, the parametrization ##\phi(\lambda) = \frac{\lambda^2}{2\pi}## (which does not have a null second derivative) from ##\lambda_0 = 0## to ##\lambda_f =2 \pi## should be as valid as the parametrization ##\phi(\lambda) = \lambda## from ##\lambda_0 = 0## to ## \lambda_f = 2\pi ##.Thanks in advance.
To extremise with Lagrangian ##L## is not equivalent to extremising with ##L^2##. If you use ##L^2## it is the same as using ##L## with the additional requirement that ##L## is constant and doing so will therefore give you an affinely parametrised geodesic - ie, a geodesic with a constant length tangent. This coincides with the geodesic concept introduced by a connection.
Great answer. Many thanks.
It's worth going through the exercise. In general, if ##L## is a "lagrangian" of the form:
##L = \sqrt{g_{ij} \dfrac{dx^i}{d\lambda} \dfrac{dx^j}{d\lambda}}##
then extremizing the action gives:
##\dfrac{d}{d\lambda} (g_{i j} \dfrac{dx^j}{d\lambda}) - \dfrac{1}{2} (\dfrac{\partial}{\partial x^i} g_{kj}) \dfrac{dx^k}{d\lambda} \dfrac{dx^j}{d\lambda} = g_{ij} \dfrac{dx^j}{d\lambda} \dfrac{\frac{dL}{d\lambda}}{L}##
The additional requirement that ##L## is unchanging as a function of ##\lambda## gives the usual form of the geodesic equation.
