Graduate Solve GHY Boundary Term Problem for Calculations
The discussion centers on the challenges of incorporating the Gibbons-Hawking-York (GHY) boundary term into the Einstein-Hilbert action for a specific calculation. The original poster encountered discrepancies between their results and those in a referenced paper, leading to confusion about the extrinsic curvature calculations. They detailed their method for calculating the trace of the extrinsic curvature and the application of Stokes' theorem, but struggled with the correct formulation of the inverse metric. After receiving feedback, they identified an error in their metric calculation, realizing the correct term should be ##r^2\Omega## rather than ##2r^2\Omega##. The poster concluded that their calculations were now correct, resolving their initial concerns.
Zitter
Hi everybody ! In one of my papers I need to add Gibbons-Hawking-York boundary term in order to calculate everything properly. I found a paper (https://www.sciencedirect.com/science/article/pii/S0370269316306530 ) in which authors included this term into the action. My problem is: I tried to calculate this term as a practice work, but I didn't obtain the same result as authors of paper. There is no point in posting my result, because my formula is much bigger than compact form from paper. I checked my hand-made calculations in Mathematica and they are the same, so probably there is a problem at the beginning of my thinking. Could somebody tell where is the error ?
1) Firstly, I calculated the trace of extrinsic curvature ##K=-\frac{1}{\sqrt{-g}}\partial_{\mu} (\sqrt{-g} n^{\mu})##, where ##n_{\mu}## is the unit vector normal to the boundary. The hyper-surface boundary is given by ##r=R_0##, where ##R_0## is constant. I obtained ##n_t=0,\ n_r=\sqrt{\frac{B}{A}},\ n_{\varphi}=0## and ##n^t=0,\ n^r=\sqrt{\frac{A}{B}},n^{\varphi}=0 ##.
2) In order to add GHY term into Einstein-Hilbert action I used Stokes theorem to change "surface" integral into "volume" integral. One can rewrite ##K## as ## \bar{K}^{\mu}n_{\mu}##, where ##\bar{K}^{\mu}## is vector ##(\bar{K}^t,\bar{K}^r,\bar{K}^{\varphi})=(0,\sqrt{\frac{A}{B}}K,0)##. By using Stokes theorem expression ##d^2x \sqrt{-h} K## is replaced by ##d^3x \sqrt{-g} \bar{K}^{\mu}_{;\mu}##, where ##\bar{K}^{\mu}_{;\mu}## is divergence of ##\bar{K}^{\mu}## vector.
3) Now, inside action integral we have ##\sqrt{-g}\left(\frac{1}{2\kappa}(R-2\Lambda)+\frac{1}{\kappa}\bar{K}^{\mu}_{;\mu}\right) ## plus ##\sigma##-model part.
Is this reasoning correct ? Thank you in advance for any help. Few months ago I changed my field of study from QM to GR and I have gaps in knowledge, which of course I try to reduce as hard as possible.
Are you want to check extrinsic curvature of the formula (4) in the paper of Harms and Stern? Dis you calculate the inverse metric ##g^{\mu\nu}##? can you post it?
Yes. I want to calculate ##K## by using ansatz on metric given by formula (4) in the paper. The inverse metric I calculated is
$$\begin{pmatrix}
-\frac{1}{A+3r^2\Omega^2 }& 0 & \frac{2\Omega}{A+3r^2 \Omega^2} \\
0 & \frac{A}{B} & 0 \\
\frac{2 \Omega}{A+3r^2 \Omega^2} & 0 & \frac{A-r^2\Omega^2}{r^2A+3r^4 \Omega^2}
\end{pmatrix}$$
$$\begin{pmatrix}
\end{pmatrix}$$
The metic ##g_{\mu\nu}## can be written as
\left[
\begin{array}{ccc}
-A+r^2\Omega^2 & 0 &0\\
0&\frac{B}{A} & r^2\Omega\\
0&r^2\Omega&r^2
\end{array} \right]
Am I right?
The ##r^2\Omega## term should be in positions (1,3) and (3,1), but thanks to you I found error in my calculations. I forgot that it should be ##r^2\Omega## and not ##2r^2\Omega## :D. Now everything is ok and calculations are correct .
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 50 ·
  • · Replies 18 ·
