Give a 2x2 matrix with Det(A)=+/-1 that is not orthogonal.
  • Thread starter Thread starter pyroknife
    Matrix Orthogonal
The discussion focuses on identifying a 2x2 matrix with a determinant of ±1 that is not orthogonal. A valid example provided is the matrix [[2, 1], [1, 1]], which satisfies the determinant condition while having non-zero off-diagonal elements. The participants clarify that the ± symbol indicates either condition can be satisfied independently, not simultaneously. Additionally, they confirm the correctness of the determinant properties related to the inverse and transpose of matrices.
  • Understanding of matrix operations, including determinants and inverses.
  • Familiarity with orthogonal matrices and their properties.
  • Knowledge of linear algebra concepts, particularly in 2x2 matrices.
  • Ability to manipulate and solve matrix equations.
  • Explore the properties of orthogonal matrices in detail.
  • Learn about the implications of determinants in linear transformations.
  • Investigate examples of non-orthogonal matrices with determinants of ±1.
  • Study the relationship between matrix inverses and transposes in linear algebra.
Students and professionals in mathematics, particularly those studying linear algebra, matrix theory, and anyone involved in computational mathematics or engineering applications requiring matrix manipulation.
pyroknife
I attached the problem.
I only need help with part b), I provided part a) just to remind you guys what a orthogonal matrix was.
The only 2x2 matrix I can think of with a determinant of + or - 1 is something like
√1 0
0 1
The determinant of this would be √1 = + or - 1
The second part asks me to show that this matrix is not orthogonal thus A^-1≠A^T
A^T=
√1 0
0 1
To calculate A^-1 I set up the 2x2 matrix with the identify matrix on the right and reduce so the left becomes the I matrix.
√1 0 1 0
0 1 0 1
1 0 1/√1 0
0 1 0 1
But when I do this I get A^-1 =
1/√1 0
0 1
Is this still considered = to A^T =
√1 0
0 1
√1 is 1. Try thinking of matrices with nonzero off-diagonal elements.
A 2x2 orthogonal matrix must satisfy:
<br /> \left(\begin{array}{cc}<br /> a &amp; b \\<br /> <br /> c &amp; d<br /> \end{array} \right) \cdot \left(\begin{array}{cc}<br /> a &amp; c \\<br /> <br /> b &amp; d<br /> \end{array}\right) = \left(\begin{array}{cc}<br /> a^2 + b^2 &amp; a \, c + b \, d \\<br /> <br /> a \, c + b \, d &amp; c^2 + d^2<br /> \end{array}\right) = \left(\begin{array}{cc}<br /> 1 &amp; 0 \\<br /> <br /> 0 &amp; 1<br /> \end{array}\right)<br />
You can simply make it non-orthogonal if you make the off-diagonal element to be non-zero, for example:
<br /> a \, c + b \, d = 1<br />
Now, the determinant is:
<br /> a \, d - b \, c = \pm1<br />
Solve these two equations for a, and b, for example, and you will get a two-parameter family of matrices that are non-orthogonal, but with determinant ±1.
You can write down a lot of simple examples without thinking half that hard.
I'm not sure if I misinterpreted this problem when it says Det(A)=±1, does that mean the + and - have to be both satisfied?
or can I have a matrix that's simply
2 1
1 1
yes, you and I can. Please unquote the solution.
2 1
1 1
yes.
Oh will, I guess I was thinking too hard. Usually when they give ±, I assume that both conditions have to be met.
Can someone verify if I proved part a right? I'm second guessing myself.
Det(A^-1)=Det(A^t)
Since Det(A^t)=Det(A)
Det(A)=Det(A^-1)
Det(A^-1)=1/Det(A)
Thus
Det(A)=1/Det(A)
(Det(A))^2=1
Det(A)=±1
Det(A^-1)=Det(A^t)
Det(A)=Det(A^-1)
Det(A^-1)=1/Det(A)
Thus
Det(A)=1/Det(A)
(Det(A))^2=1
Det(A)=±1
yes, it is correct.
The \pm operator is called plus or minus, not plus and minus :-p
and imposing the conditions
<br /> x = 1 \wedge x = -1<br />
leads to a contradiction
<br /> 1 = -1<br />
so, that interpretation doesn't make sense.
  • · Replies 32 ·
  • · Replies 69 ·
9K
