Given a wave function, predict the result
3 replies · 2K views
spacetimedude
The wave function of a particle is known to have the form $$u(r,\theta,\phi)=AR(r)f(\theta)\cos(2\phi)$$ where ##f## is an unknown function of ##\theta##. What can be predicted about the results of measuring
(a) the z-component of angular momentum;
(b) the square of the angular momentum?
##cos(2\phi)={exp(2i\phi)+exp(-2i\phi)}/2##
Also, I know the spherical harmonics and the corresponding eigenvalues.
The solutions are:
a) ##L_z=+/- 2## with equal probability.
b) ##l\geq 2## but nothing can be said if we don't know ##f(\theta)##
where l denotes the angular momentum quantum number.
For the first one, I am trying to make sense of what the physical interpretation of the two exponential functions is in the wave function. Why is ##L_z=+/- 2##? Is u a linear combination of two states, ##exp(2i\phi)## and ##exp(-2i\phi)## and do the value -2 and 2 indicate the angular momentum? If I act some operator to u, do we only consider one of the exponential state? I am a bit rusty with the meaning of a wave function.
The second one, I just know that $$\hat{L^2} |l,m>=\hbar^2 l(l+1)|l,m>$$.
Thanks in advance.
Can't you write u as a linear combination?
No, they represent the eigenvalues of the ##\hat{L}_z## operator, which correspond to the projection of the angular momentum on the z axis.
No, you would have to act on the full wave function. But you don't actually need to do that, as the probability of measuring the system in a given ##|l, m \rangle## is
\langle l, m | u \rangle
and you need to figure out for which ##|l ,m \rangle## the result would be something other than 0.
Since the ##|l ,m \rangle## are spherical harmonics, it would probably help for you to look at a table of spherical harmonic functions to familiarize yourself with their form in terms of l and m.
Yes, by expanding the two exponential terms. But I thought $$u(r,\theta,\phi)=AR(r)f(\theta)\exp(2i\phi)/2+AR(r)f(\theta)\exp(-2i\phi)/2$$ represents just one of all the possible state. Or is each term in the right hand side representing a different state (is this the superposition?)? I don't see how one term vanish while the other one stays when the wave function collapses.
And thank you. I understand the rest.
EDIT: Sorry, I still don't see why Lz=+/- 2. They come from reading the exponential terms, correct? How are they the eigenvalues of Lz?
Lets start with
The angular momentum operators in spherical coordinates are
\hat{L}_z = -i \hbar \frac{\partial}{\partial \phi} \\
\hat{L}^2 = - \hbar^2 \left[ \frac{1}{\sin \theta}\frac{\partial}{\partial \theta} \left( \sin \theta \frac{\partial}{\partial \theta} \right) + \frac{1}{\sin^2 \theta} \frac{\partial^2}{\partial \phi^2} \right]
So it is obvious that for ##\hat{L}_z##, one needs only look at the ##\phi## part of the wave function. The eigenstates of ##\hat{L}_z## are ##e^{i m \phi} / \sqrt{2\pi}## (with ##m## an integer). One can make use of the orthogonality property
\frac{1}{2\pi} \int_0^{2 \pi} e^{-i m' \phi} e^{i m \phi} d\phi = \delta_{m,m'}
So you you make a measurement of ##\hat{L}_z##, after the measurement the wave function will be in an eigenstate of ##\hat{L}_z##, so the ##\phi## part will be ##e^{i m \phi}##. To see which value of ##m## are possible, you make use of the orthogonality property, and thus the only possibilities will be ##m=2## or ##m=-2##.
spacetimedude said:
But I thought
This is the state of the system before measurement. It represents a single state, but it is a superposition from the point of view of the eigenstates of ##\hat{L}_z##. In other words, since it is not an eigenstate of ##\hat{L}_z##, it has to be a superposition of those eigenstates.
That's just the way it is. If you measure ##L_z = 2 \hbar##, then you know that after measurement the wave function is ##\propto e^{2i\phi}##.
