Golf : Advantage of a longer drive ?
  • Context: Undergrad
  • Thread starter Thread starter eldrick
    Drive Golf
The discussion revolves around the theoretical advantages of increasing driving distance in golf, specifically from 300 yards to 310 yards, and how this change might impact performance on the course. Participants explore various aspects of driving distance, including its implications for shot selection, accuracy, and overall strategy in the context of a par-4 hole.
  • One participant suggests that the theoretical improvement in performance could be related to the square root of the ratio of driving distances, indicating a potential advantage of approximately 3.93.
  • Another participant argues that a longer drive allows players to avoid obstacles like bunkers and use lower clubs, which could enhance shot control.
  • It is noted that being closer for approach shots enables the use of shorter clubs, which can generate more backspin and improve accuracy on the green.
  • Some participants mention that hitting longer drives also means that all other clubs can be used with greater distance, potentially affecting overall gameplay.
  • There is a discussion about the variability of shot distance based on swing technique, with some participants questioning the reliability of longer shots if accuracy is compromised.
  • One participant emphasizes that the advantage of longer shots can depend on specific course conditions and the player's ability to adapt their shot type to the situation.
  • Concerns are raised about the increasing technicality of courses as driving distances improve, suggesting that course design may evolve to counteract longer drives.
  • A participant expresses frustration at not receiving a clear answer to the initial question regarding the theoretical advantage of increased driving distance.
Participants express a range of views on the advantages of longer drives, with no consensus reached. Some agree on the potential benefits of increased distance, while others highlight the importance of accuracy and shot selection, leading to a complex discussion with competing perspectives.
The discussion includes various assumptions about player skill levels, swing techniques, and course conditions, which may influence the perceived advantages of longer drives. Additionally, the mathematical reasoning presented is not universally accepted among participants.
eldrick
I'd be interested in some input on a question asked by a friend.
Suppose you are a golf pro & train harder ( weight-training ) & increase your maximum driving ability from 300 yards to 310 yard with same accuracy.
What theoretical advantage is this likely to offer you on the course ?
Say for instance we have a straight par-4 of 500y ( 500y from pin to hole ), with say a circular green of 50y radius with hole in the middle & the guy has increased his driving from 300y to 310y.
For some instinctive reason I think the theoretical improvement is likely to be the square root of the ratio improvement in driving ( because the hole, which is an area, of squared nature, is nearer & I get gut feeling that it's related to a squared function ) e.g.
(300/310)^0.5
Which applied to a par-4 would indicate :
3.93.
I would like some ideas on where to go, because instinct isn't a viable argument.
If you can drive it 310 instead of 300, and a bunker is at 300 yards, you will be able to go over it.
You can use a club lower than you normally would use.
With more power, one can most likely put more draw on their shot if needed.
There are plenty of reasons...
Every 10 or so yards you can get closer for your approach shot allows you to select a shorter club with more back-spin on the green. That's a big deal.
And if you hit your drive longer, you can hit every other club longer.
If you hit a ball with a p wedge harder than you did yesterday, wouldn't the ball just go higher not longer, thus less accuracy?
It depends on the shot. I can hit a wedge 15 yards or 50 yards depending on how I swing.
I COULD make it go higher, or I could make it go a bit further.
then where is the advantage of a longer shot? if it just depends on your swing/shot?
Well if I am 50 yards out, and I can only hit my wedge 40 yards, it means i have to use a 9 iron, where i won't get the same backspin, so it might roll off the green.
if i can hit my wedge 50 yards, i can get better backspin for the same distance, and not have it roll off.
And one is able to avoid/ go over obstacles that previously one would have to lay up on.
A longer shot means you can hit it further (obviously), higher, and with more spin.
There are some cases though where I might be 40 yards out, but I need to hit it low to get under trees, so I might use a 7 iron and just punch it low. it does really depend on the shot, the course, and the conditions on the course.
point taken...what about putting...just kidding, thanx
lol there was actually a guy who used his putter for everything, including driving. don't remember his name though...
This is all very nice chat, but I'm not any closer to an answer.
Forget bunkers, lakes & Bill Murray's gopher ( ! )
I'm just thinking how driving 310 instead of 300 subtends a bigger angle of shot to a straight-ahead 4.25" diameter hole on a 500y straight hole & increased chance of beating par-4 :
The hole appears "bigger"
Actually, now, thinking about it a lot more, it may not be such a hard problem, but I'd like some sober input
Hard question to address, eldrick without knowing your skill level and your propensity to slice or pull shots when trying to drive that last few extra yards.
I was never very consistent with the driver (though I had good moments), but I could manage 200+ yards with the roll with a 5-iron. I'd place the ball back in my stance to de-loft the club and swing normally. I was a LOT more accurate with that iron, and that was a big deal. Putting the ball where you want it in the fairway for your approach is pretty important. Yeah, I could often be much longer with the driver or 3-wood or a longer iron, but it doesn't take too much of an off-target shot to put you in the rough, and cost you an extra stroke or two to compensate.
5-iron was kind of the sweet spot for me. I studied with two guys (co-worker and a friend) who could have turned pro, and they both had the same advice. Use the longest club that you have confidence in and never sacrifice accuracy for a few yards of distance. After about a year, I could shoot pretty reliable Bogey golf, and that's not bad for a newbie who is short and has a bad back.
Getting close is really important if you are a pro. Staying out of trouble is far more important if you are an amateur who wants to improve your score.
BTW, as pros manage to drive longer and longer, course designers move trees, bunker, traps, etc to negate the extra length and make the course more technical.
I'm still not being offered an answer to the question proferred
I 'd like some refuatations to simple 3.93 suggested
  • · Replies 19 ·
12K
  • · Replies 25 ·
  • · Replies 80 ·
69K
31K
