What Is the Orbit of a Planet in a Gravitational Field with This Metric?
  • Thread starter Thread starter quasar987
    Gr Orbit Planet
The discussion focuses on deriving the orbit of a planet in a gravitational field defined by the metric dτ²=(1+α²(x²+y²))dt²-(dx²+dy²+dz²) in the Newtonian limit. Participants calculated the connection coefficients and established four geodesic equations, emphasizing the importance of the proper time parameter. A key conclusion is that in the Newtonian limit, the relationship dt/dτ = 1 simplifies the equations significantly. The weak-field approximation leads to a Newtonian potential of -1/2c²(1 + g₀₀), where g₀₀ = 1 + α²(x²+y²).
  • Understanding of general relativity concepts, particularly geodesic equations.
  • Familiarity with the Levi-Civita connection and its application in curved spacetime.
  • Knowledge of Newtonian physics and gravitational fields.
  • Basic calculus, particularly in solving differential equations.
  • Study the derivation of geodesic equations in general relativity.
  • Learn about the weak-field approximation and its implications in gravitational physics.
  • Explore the relationship between proper time and coordinate time in curved spacetime.
  • Investigate the mathematical formulation of metrics in general relativity, focusing on the Schwarzschild metric.
Students and researchers in physics, particularly those studying general relativity, gravitational fields, and orbital mechanics. This discussion is also beneficial for anyone interested in the mathematical foundations of spacetime metrics.
quasar987
Find the orbit of a planet in a grav. field corresponding to the metric
d\tau^2=(1+\alpha^2(x^2+y^2))dt^2-(dx^2+dy^2+dz^2)
in the Newtonian limit with the initial conditions at t=0, x=R, dx/dt=\beta,0=y=z=dy/dt=dz/dt where alpha and beta are cositive constants.
The Levi-Civita connexion and the geodesic equations
I calculates the connexion coefficients and wrote down the 4 geodesic equations with the proper time as the parameter:
\frac{d^2t}{d\tau^2}+\frac{2\alpha^2x}{(1+\alpha^2(x^2+y^2))} \frac{dt}{d\tau}\frac{dx}{d\tau}+\frac{2\alpha^2y}{(1+\alpha^2(x^2+y^2))}\frac{dt}{d\tau}\frac{dy}{d\tau}=0
\frac{d^2x}{d\tau^2}+\alpha^2x\left(\frac{dt}{d\tau}\right)^2=0
\frac{d^2y}{d\tau^2}+\alpha^2y\left(\frac{dt}{d\tau}\right)^2=0
\frac{d^2z}{d\tau^2}=0
I can solve the 4th equation of course:
z(\tau)=a\tau +b
and if I understand correctly, the Newtonian limit means that
\frac{dx^i}{d\tau}<<\frac{dt}{d\tau}
But I don't see how that can be applied here to simplify the equations.
z(\tau)=a\tau +b
In the Newtonian limit you can set t = tau so \frac{dt}{d \tau} = 1.
And, of course, \frac{d^2t}{d \tau^2} =0.
So the equations become trivial to solve.
Are you sure?
d\tau^2=g_{\mu\nu}dx^{\mu}dx^{\nu}
And here, g_{ii}=-1, g_{00}=1+\alpha^2(x^2+y^2) so
d\tau^2=(g_{00}-(dx/dt)^2-(dy/dt)^2-(dz/dt)^2)dt^2
and in the small speed limit, this only reduces to
d\tau^2\approx g_{00}dt^2
which is not just dtau=dt because g00 is not just 1.
quasar987 said:
Are you sure?
You are right. Sorry, I had misread the spacetime interval and thought that the (1+alpha^2(x^2+y^2)) term went with the spatial part. So you have an expression for dt/dtau to replace in all the equations. Using the chain rule you can also get an expression for the second derivative d^2 t/dtau^2.
Sorry for my mistake.
Use the weak-field approximation, which gives a straight Newtonian potential of -
- \frac{1}{2}c^2( 1 + g_{00})
You can derive this by assuming the
g_{ij} = \eta_{ij} + h_{ij} where \eta is the flat space metric and h
is a small perturbation.
  • · Replies 46 ·
  • · Replies 19 ·
