Graph of f:[0,1]->R compact <=> f continuous
The discussion revolves around proving that a function f: [0,1] -> R is continuous if its image f([0,1]) is compact. One participant initially confuses the concepts of the graph of f and its image, leading to confusion in their proof approach. Key points include the properties of compactness and the implications of R being Hausdorff. The clarification that the graph of f is a subset of [0,1] × R, distinct from the image of f, significantly shifts the focus of the proof. Understanding this distinction is crucial for correctly demonstrating the continuity of f.
dumbQuestion
I know this proof is probably super easy but I'm really stuck. I don't want someone to solve it for me, I just want a hint.
One way is trivial:
suppose f continuous.
[0,1] compact and the continuous image of a compact space is compact so f([0,1]) is compact
Now the other direction...
here's some basic facts i have to work with:
1) R is metrizable
2) R is hausdorf
3) R is regular
4) R is normal
5) f([0,1]) is compact (by assumption) (so it follows that every open cover has a finite subcover)
6) f([0,1]) is closed (follows from 5 because R is Hausdorf and compact subset of Hausdorf space is closed)
7) R is NOT compact, but it's connected
8) [0,1] is connected and compact (every open cover has finite subcover, and no separate of [0,1])
I don't know, everything I try I Just get no where. Can someone give a hint on how/where to start? In showing f is continuous should I try the approach 1) pre-image under f of every open set U in f([0,1]) is open in [0,1] ? 2) pre-image under f of every closed set U in f([0,1]) is closed in [0,1] ? 3) maybe try a contradiction? Assume f is not continuous, which means there exists an open set U in f([0,1]) such that it's pre image is not open, etc.
So let ##G(f) = \{(x,f(x))~\vert~x\in [0,1]\}##. Maybe you can start by proving that ##[0,1]## and ##G(f)## are homeomorphic?
dumbQuestion, your thread title says graph but in your main body it seems you are trying to show that if ##f([0,1])## is compact then ##f## is continuous but this is the image of ##f##, not the graph of ##f##, and it isn't true in general. Consider for example ##f:[0,1] \rightarrow \mathbb{R}## given by ##f(x) = 0, 0 \leq x\leq \frac{1}{2}## and ##f(x) = 1, \frac{1}{2} < x\leq 1##. The image of this is ##\{0,1\}## which is compact but the function isn't continuous. So are you sure you aren't supposed to actually look at the graph of ##f##?
oh yes, I am supposed to look at the graph of f. I guess I was just mistaking the graph of f for the image of f. I guess I'm not seein gthe distinction between the graph and image.
The graph of ##f## is by definition a subset of ##[0,1]\times \mathbb{R}##. While the image is a subset of ##\mathbb{R}##. They are two very different different things.
oh i see. ok this will change things entirely. thank you so much for pointing this out
We all know the definition of n-dimensional topological manifold uses open sets and homeomorphisms onto the image as open set in ##\mathbb R^n##. It should be possible to reformulate the definition of n-dimensional topological manifold using closed sets on the manifold's topology and on ##\mathbb R^n## ? I'm positive for this. Perhaps the definition of smooth manifold would be problematic, though.
16K
