Graph Sin(2x+6): Is Parent Function the Best Option?
  • Thread starter Thread starter barryj
    Graphing
The discussion centers on graphing the function sin(2x+6) and the best approach to understand its transformations. Participants agree that converting the expression to sin(2(x+3)) clarifies the period as 2π/2 and highlights a horizontal translation of 3 units. The conversation also touches on the importance of understanding phase shifts, with some preferring to start from the parent function sin(x) to apply transformations systematically. The method of decomposing functions to identify shifts and compressions is emphasized as crucial for accurate graphing.
  • Understanding of trigonometric functions, specifically sine functions.
  • Knowledge of function transformations, including horizontal shifts and compressions.
  • Familiarity with the concept of period in trigonometric functions.
  • Basic algebra skills for manipulating expressions.
  • Study the properties of sine functions, focusing on transformations and periodicity.
  • Learn how to apply horizontal and vertical shifts to trigonometric functions.
  • Explore the concept of phase shifts in trigonometric equations.
  • Practice graphing various transformations of sine and absolute value functions.
Students, educators, and anyone interested in mastering graphing techniques for trigonometric functions and understanding function transformations.
barryj
Graph sin(2x+6)
period = 2pi/2, phase shift = 6/2
My question is when I start to graph sin (2x+6) I convert the expression to sin 2(x+3).
My thinking that by doing so I can easily see the period is 2pi/2 and there is a horizontal translation of 3. Some books state that starting with sin(2x+6) the period is 2pi/2 , the same as above, and that there is a phase shift of 6/2. I think it is better to start with a parent function of sin x, then apply horizontal compression and/or shift translations to get the correct graph.
Similarly for an absolute expression |2x-8| I always convert the expression to |2(x-4)| and apply translations.
Comments please?
You should do whatever makes sense to you.
Edit to add: Assuming it's also correct :)
barryj said:
Homework Statement:: Graph sin(2x+6)
Relevant Equations:: period = 2pi/2, phase shift = 6/2
Comments please?
Your strategy is the correct one. Look at compressions/expansions first, then reflections, and finally translations.
Starting from ##y = \sin(x)##, the graph of ##y = \sin(2x)## is a compression by a factor of 2 toward the y-axis. Then ##y = \sin(2(x + 3))## is a translation of the compressed function by 3 units to the left. Similar idea for your absolute value function.
If you decompose your given function in the wrong order, you can sometimes wind up with the wrong result, so it's a good idea to check with a couple of points to make sure you've done things correctly.
At the high school here they are taught to calculate a phase shift of, in this example 6/2. Ultimately it is the same thing but when starting with 2x+6 the translation is not obvious. I guess our school is teaching "new math".
No, not "new math." To get the phase shift of 6/2, they are implicitly decomposing 2x + 6 into 2(x + 6/2) (I guess).
I was just kidding about the "new math". I guess I do not understand why they use the phase shift calculation rather than merely use what they already know about transformations.
Its a variable shift here; different shift for each value of x. If the shift was constant, then it would be , e.g., sin(x+3).
