Gravitation, 2 objects of same properties
Gravitation involves objects warping the space around them, causing them to attract each other based on their mass. When two identical objects approach each other, they will merge their warps rather than create a repulsive effect, leading to collision and conglomeration into one body. The merging of their spatial curvatures allows them to orbit around a common center of mass if they have initial velocities. Unlike tectonic plates, the warping of space is more malleable, preventing the formation of a "mountain" of space between them. Additionally, gravitational effects diminish with distance, approaching a flat Minkowski space-time at infinite separation.
Destroxia
Okay so I'm under the understanding that the way gravitation works is that each object warps the space around itself, and essentially objects caught in the warping are "falling" towards the object with the bigger warp in the center.
So my question is, how do objects that are complete clones of each other, that have the same mass and everything, fall towards each other? Wouldn't the space warps almost make a "mountain" of space between the two, like tectonic plates moving towards each other, and the objects would actually end up repulsing each other? Or as they near each other would their warps combine and just form a big bowl which the both of them fall towards each other at the same rate? Also, is there a distance at which gravitation will have a negligible effect? Or is the warping of spacetime seemingly infinite, decreasing it's slope infintessimally?
Thank you for your answer, also please correct me if I have any misconceptions about how gravity and the warping of space works, and if space actually warps the same as if a mass was placed on a fabric?
You have a lot of questions. I will do my best to knock them out one by one.
2 identical objects move differently through each others spatial curvature depending on their initial velocity and position.
2 clones moving toward each other will collide and conglomerate into one body ( truly combining their warps)
2 clones orbiting around each other will orbit around their center of mass.
Now space is a lot more malleable than tectonic plates. Therefore no " mountain " between them can form. The curvatures just merge together. Picture an extremely tough rubber sheet and two equivalent bowling bowls rolling down to the center. Their respective curvatures are merged into the one of a body twice as big. Now the rubber sheet and bowling ball analogy is good but don't over extend it.
1. It doesn't include time
2. It doesn't include the third dimension
3. It is elastic deformation space can bend in a lot more ways without snapping.
Also yes space time asymptotically approaches Minkowski space time as one gets infinitely far away.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 41 ·
  • · Replies 32 ·
14K
  • · Replies 51 ·
