Gravitation and velocity problem
The discussion revolves around a problem related to gravitation and velocity, specifically involving energy conservation equations in the context of an object falling towards Earth. Participants are examining the relationships between kinetic energy, potential energy, and additional energy terms.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss various equations related to energy conservation, including the use of gravitational potential energy and kinetic energy. There are attempts to clarify the correct application of these equations, particularly in the context of circular orbits versus falling objects.
The discussion has evolved with participants sharing their attempts and results. Some have noted discrepancies between their answers and the given solution, prompting questions about unit consistency and the correct interpretation of the equations. A few participants have successfully derived answers close to the expected result, indicating productive exploration of the problem.
There are mentions of specific values and units that need careful consideration, such as distinguishing between altitude and radial distance. Additionally, the problem includes a heat energy term, which some participants are trying to incorporate into their calculations.
canicon25
2ΔEk=-ΔEp
-Gm1m2(1/r1-1/r2)-Q=mv2
plug in given values solve for v.
my answer is 5.35x106m/s
given answer is 2100m/s
canicon25 said:
Any ideas?
Watch your units, be careful to distinguish between altitude and radial distance, and most important of all, show your work. There's no way to tell you where you went wrong if you don't show your work.
BTW, the given answer is correct.
its 400000m not 400m
1600v2=-G(1600)(5.98E24)/(6.38E6+400000) - (-G)(1600)(5.98E24)/ (6.38E6+100000) - 8.3E8
v=1407 m/s
still not getting the correct solution.
Showing your work does not mean spewing out an equation without units and without justification. What are the relevant equations?
i am stumped. i tried using
ΔEk+Q=-(0.5)ΔEp
where Ek= 0.5mv2
and Ep= -GMm/r
Q is heat energy. Given in problem.
why do you have a 0.5 in the energy conservation equation?
upon further reading i found that
ΔEk+Q=-0.5ΔEP for CIRCULAR ORBITS ONLY
am i correct in assuming that
ΔEk+Q=ΔEp would apply for a object falling to Earth
so i tried it and did get correct answer
0.5mv2+Q=-GMm(1/r1-1/r2)
r1=radius Earth + 400000km
r2=radius Earth + 100000km
when i solve for v i get 2133 m/s
I got 2096 m/s ≈ 2100 m/s
I think you've done it right, but there might be some rounding error, which means your answer isn't exactly the same as the given answer. good job!
  • · Replies 42 ·
