Gravitational force on a particle due to different type of objects
The gravitational force exerted on a particle by different objects of mass m is analyzed using the shell theorem. A large uniform solid sphere and a large uniform spherical shell exert the same gravitational force on the particle when placed at a distance d from their centers. In contrast, smaller objects, such as a small uniform solid sphere and a small uniform shell, exert a lesser gravitational force due to their reduced size. The ranking of gravitational force from greatest to least is thus the large solid sphere and large shell equally, followed by the small solid sphere and small shell. The distance from the center of the objects is crucial in determining the force exerted on the test particle.
shauns87
A particle is to be placed, in turn, outside four objects, each of mass m: (1) a large uniform
solid sphere, (2) a large uniform spherical shell, (3) a small uniform solid sphere,
and (4) a small uniform shell. In each situation, the distance between the particle and
the center of the object is d. Rank the objects according to the magnitude of the gravitational
force they exert on the particle, greatest first.
F= Gm1m2/r2
As per the shell theorem, a uniform shell of matter attracts a particle that is outside the shell as if all the shell's mass were concentrated at its center. So, as per this theorem, the solid sphere and the shell should exert the same amount of force of the particle. However, a smaller size sphere would exert a lesser force.
In each case, the shell theorem reduces the problem to a point of mass m and since all are of mass m then they all exert the same force a given distance from the center sphere/shell objects.
What can you say about the test particle distance from the objects?
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 34 ·
  • · Replies 16 ·
  • · Replies 28 ·
