How to Calculate Forces on an Electron at the Equator?
The discussion focuses on calculating the gravitational, electric, and magnetic forces acting on an electron at the Earth's equator. The gravitational force can be simplified using the formula F = mg, where g is approximately 9.81 m/s², rather than using the universal gravitation formula. For the electric force, the appropriate formula is F = qE, where E is the electric field strength of 100 N/C. The magnetic force is calculated using F = qv x B, with B being the magnetic field strength of 50.0 µT. The right-hand rule is confirmed as the method for determining the direction of the magnetic force.
  • Understanding of classical mechanics, specifically gravitational force calculations
  • Familiarity with electric fields and the formula F = qE
  • Knowledge of magnetic fields and the formula F = qv x B
  • Proficiency in applying the right-hand rule for vector cross products
  • Study gravitational force calculations using F = mg in various contexts
  • Explore electric field concepts and applications of F = qE in different scenarios
  • Investigate magnetic force calculations and the implications of the right-hand rule
  • Learn about the behavior of charged particles in electromagnetic fields
Students and professionals in physics, particularly those studying electromagnetism and mechanics, as well as educators seeking to clarify concepts related to forces acting on charged particles.
Pepsi24chevy
Here reads the problem. the equator, near the surface of the Earth, the magnetic field is approximately 50.0 µT northward, and the electric field is about 100 N/C downward in fair weather. Find the gravitational, electric, and magnetic forces on an electron in this environment, assuming the electron has an instantaneous velocity of 7.70 x10^6 m/s directed to the east.
Now for gravitational do i set it up by: (G * m1 * m2) / (d2)? If so what would i use for the distance.
For electric force i assume i set it up by: kq/r^2 ?
And then for magnetic forces i assume i set it up by: qvxB?
Also for the directions, would i use the right hand rule for each one?
Any suggests towards the right way of doing this would be appreciated. Thanks
For the gravitational force, if you were to use F=\frac{Gm_1m_2}{r^2}, then r would be the radius of the earth. However, this is unnecesary since around the surface of the Earth the terms \frac{Gm_1}{r^2} are nearly constant and given by g \approx 9.81m/s^2, so the force is just mg.
For the electric force, \vec{F}=q\vec{E} would be more appropriate.
Fort the magnetic force you have it right. The right hand rule is the way to find the direction of the magnetic force.
