Gravitational Forces Question Tricky
6 replies · 4K views · last reply
XcKyle93
Two planets have masses M and m, and the ratio M/m=25. The distance between the planets is R. The Point P, is between the planets as shown (there is no picture though), and the distance between M and P is x. At P, the gravitational forces on an object due to M and m are equal in magnitude. What is x?
F = (G*M*m)/R^2
I am stumped. Can you really figure this out with the info given? I ended up with some quadratic equation: 0 = 25R^2 - 50Rx + 24x^2
F = (G*M*m)/R
Two things -- your equation that you list is not quite right. And the 2nd "m" in the equation is meant to be the mass of an object a distance R away from a mass M. You will need to have three masses listed in your initial equations (the object's mass will cancel out).
Stumped? Looks to me like you figured it out just fine. Now just solve the quadratic!
I accidentally type the inverse square law incorrectly, but I edited my initial post to fix that. Why would I need three masses if the mass of the object cancels out?
Alright, awesome, I was just unsure of myself. Thanks!
My point was that M and m are listed in the problem as the masses of the two planets. That doesn't fit the equation that you wrote.
Perhaps I should have used slightly different variables for the equation that I wrote down; it was meant to be a general formula.
