Gravitational Mass of Photons: Passive & Active
The discussion revolves around the gravitational properties of photons, specifically addressing the concepts of passive and active gravitational mass, and whether photons can create their own gravitational fields. The scope includes theoretical considerations from general relativity and the implications of electromagnetic waves on spacetime.
  • Some participants assert that photons have zero rest mass but possess passive gravitational mass, allowing them to respond to gravity.
  • Others argue that the application of Newtonian gravity is inappropriate for objects traveling at or near the speed of light, suggesting the need for general relativity (GR).
  • It is proposed that electromagnetic waves have a non-zero stress-energy tensor, which allows them to distort spacetime and possess their own gravitational field, albeit very weakly.
  • Some participants claim that if photons have passive mass, they must also have active mass, enabling them to curve space.
  • There is a suggestion that parallel light beams do not gravitationally interact, while antiparallel beams would attract each other, with references to time dilation effects on mutual acceleration.
  • One participant requests a reference for the claim that passive gravitational mass equals active gravitational mass, indicating a desire for peer-reviewed sources.
  • Another participant mentions that the gravitational interaction of light beams can be derived from the stress-energy tensor, referencing a discussion in MTW and a paper by Tolman.
Participants express differing views on the gravitational interaction of parallel and antiparallel light beams, with some asserting that parallel beams do not attract while others support the idea of attraction between antiparallel beams. The discussion remains unresolved regarding the implications of gravitational mass for photons.
There are limitations in the discussion regarding the definitions of gravitational mass and the applicability of classical versus relativistic frameworks. The relationship between passive and active gravitational mass is also not fully clarified.
SteveDC
As I understand a photon has zero rest mass (as far as we can tell) but it does have a passive gravitational mass in order for it to be able to respond to gravity.
But I've been shown that passive gravitational mass should be equal to active gravitational mass, and if this is true and photons have active gravitational mass then is it the case that a beam of light will have its own gravitational field? So would two beams of parallel light in an empty Universe (i.e. no gravity from other objects) be drawn to each other?
You have a too classical view of how gravity works. It isunclear what you think gravitational mass means for objects traveling at or close to the speed of light. You cannot apply Newtonian gravity, you need to apply general relativity.
Yes. An EM wave has a non-zero stress-energy tensor, so it will distort spacetime and have its own gravitational field. Note that the effect would be extraordinarily weak.
Applying GR should give the same conclusion though shouldn't it? If photons have passive mass and therefore have active mass they are able to curve space.
To further what @Orodruin and @phyzguy said, in GR mass is not the source of the gravitational field, the stress energy tensor is. Light has energy and momentum so it gravitates, regardless of the fact that it is massless.
The gravitational field of light is called a pp wave spacetime.
I've heard that parallel light beams do not interact with one another gravitationally, but antiparallel beams would attract each other. I think it's possible to guess that anyway from the fact that the mutual acceleration between massive particles traveling at the same speed at very nearly the speed of light in the same direction is time dilated to near zero.
I'd be curious to see where you were shown that passive gravitational mass was equal to active gravitational mass. Do you have a reference? Can it be tracked down to a peer-reviewed paper?
To answer your question, as others have pointed out, parallel beams of light won't attract each other, while anti-parallel beams will attract.
Yes, and this result can be derived from the stress-energy tensor of the light beams. MTW has a brief discussion of this, and (IIRC) refers to a paper by Tolman that was the first publication of the result.
  • · Replies 19 ·
  • · Replies 24 ·
  • · Replies 64 ·
12K
