Gravitational Time Dilation: Radius & Clock Rate Variation Explained
The discussion centers on the analysis of gravitational time dilation using the Schwarzschild coordinates to understand how clock rates vary with distance from a massive object. The user calculated the radius (r) for two scenarios: when the fast clock ticks 10 times faster than the slow clock (resulting in r = rs × 100/99) and when it ticks 2 times faster (yielding r = rs × 4/3). Contrary to expectations, the latter scenario produced a larger radius, illustrating that clocks tick more slowly at the center of a gravitational field compared to higher altitudes. This highlights the non-intuitive nature of gravitational time dilation.
  • Understanding of gravitational time dilation
  • Familiarity with Schwarzschild coordinates
  • Basic knowledge of general relativity concepts
  • Mathematical skills for manipulating equations
  • Research the implications of gravitational time dilation in astrophysics
  • Study the Schwarzschild radius and its significance in black hole physics
  • Explore the effects of gravitational fields on time perception in GPS technology
  • Learn about the experimental verification of general relativity principles
Physicists, astrophysicists, students of general relativity, and anyone interested in the effects of gravity on time measurement.
Zman
(Apologies I posted this initially as a conversation. Not familiar with the format)
I used the ‘gravitational time dilation’ equation to see how the clock rate varies with distance from the center of an object. I got the opposite result to what I was expecting.From Wikipedia;
Gravitational time dilation outside a non-rotating sphere
fc63dfccb6a0a7379475600a65b36b65fb7b88e5
t0 is the proper time between events A and B for a slow-ticking observer within the gravitational field,
tf is the coordinate time between events A and B for a fast-ticking observer at an arbitrarily large distance from the massive object (this assumes the fast-ticking observer is using Schwarzschild coordinates, a coordinate system where a clock at infinite distance from the massive sphere would tick at one second per second of coordinate time, while closer clocks would tick at less than that rate),
r is the radial coordinate of the observer (which is analogous to the classical distance from the center of the object, but is actually a Schwarzschild coordinate),
rs is the Schwarzschild radius.I was interested to find out how the radius r varies with the time ratio t0/ tf for a given mass.
I plugged in t0/ tf = 1/10
This is effectively asking what is r when the fast clock is running 10 times faster than the slow clock.
The answer is r = rs X 100/99Then I asked what is r when the fast clock is running 2 times faster than the slow clock.
I plugged in t0/ tf = ½ expecting a smaller radius
I got the answer r = rs X 4/3 which is a bigger radius than the previous case.Clocks tick more slowly at the center than higher up. The higher up (the greater the radius) the faster a clock ticks relative to the center clock.Looking to clear up my confusion
Yes. Incidentally, the analysis you are doing assumes the clock is hovering (or sitting on a solid surface), not orbiting.
The numbers you give seem consistent with this - the slowest clock is at about 1.01##r_S##, the next fastest is higher up at 1.33##r_S##, and the fastest clock is at infinity.
Edit: so ##r## is the "altitude" of the lower clock. This is being compared to a clock at infinity.
Edit2: ##t_0/t_f=1/2## means that the clock at infinity ticks twice in the time it takes the lower clock to tick once.
Ibix said:
Edit: so r is the "altitude" of the lower clock. This is being compared to a clock at infinity.
Yes, the lower clock running at half the rate of the clock at infinity will have a larger radius than the lower clock running at a tenth the rate of the clock at infinity. Obvious. Though I need to make a note of how to correctly interpret the equation.
Thank you for that.
  • · Replies 54 ·
  • · Replies 27 ·
  • · Replies 103 ·
  • · Replies 88 ·
