Gravitational time dilation depth charge
The discussion centers around a hypothetical experiment involving gravitational time dilation near a black hole. Participants explore the implications of firing a capsule towards a black hole, which is intended to detonate after a year according to the clock on a ship parked at a safe distance. The conversation examines the effects of time dilation on the capsule and the synchronization of clocks between the ship and the capsule.
  • Some participants question the initial setup of the experiment, noting inconsistencies regarding the relative positions of the ship and the black hole.
  • There is a discussion about the synchronization of the clocks on the ship and the capsule, with some asserting that synchronization is only possible in flat spacetime.
  • Participants debate whether the capsule can be considered to be "lowered into" the black hole without crossing the event horizon, with differing interpretations of the implications of this action.
  • Some argue that time runs normally inside the capsule, but the rate of time passage differs due to gravitational effects, leading to potential desynchronization with the ship's clock.
  • There are conflicting views on whether the capsule will return after 365 days, with some asserting it will due to the time dilation effects experienced by the capsule.
  • One participant introduces an analogy involving paths of different lengths to illustrate the concept of time and distance in curved spacetime.
Participants express multiple competing views regarding the setup of the experiment, the effects of gravitational time dilation, and the synchronization of clocks. The discussion remains unresolved, with no consensus on several key points.
Limitations include assumptions about the nature of spacetime near the black hole, the definitions of flat spacetime, and the conditions under which the clocks remain synchronized. The discussion also highlights the complexity of gravitational effects on time measurement.
tionis
Hi. A student wishes to test gravitational time dilation near a black hole within her lifetime, so she travels to a location where a black hole is said to reside and parks her ship at distance where she is not affected by the hole's time dilation effects.
She then fires a tethered capsule towards the BH with an explosive inside timed to detonate in exactly three hundred sixty-five days according to the clock in her ship. The capsule will not cross the event horizon, but will remain at a distance such that gravitational time dilation has an effect on it according to the clock back in the ship.
After one year, the student reels the tether in. Will the unexploded capsule still be attached to it? Assume whatever convenient variables, such as the speed of the fired capsule and the time it took to get to the back hole, as well as the time to get it back in the ship to be ideal for such experiment.
Time dilation is relative: it depends on some other observer. Where is the other observer?
If you mean that the student should be in flat space-time, then she cannot be anywhere near the black hole.
Either way, the opening setup is internally inconsistent.
That only makes sense if this timing is in the same reference frame as the clock in her ship.
First you say that the capsule is fired towards the black hole, now you say it "remains at a distance"??
The capsule is maybe lowered into the black hole's gravity?
Is the capsule fired by a signal from it's own clock, initially synchronized with the ship, or is it fired by a signal from the ship's clock?
But it does not seem to matter for the question whether the ship is in curved space-time or not. What you care about is the difference in the clocks.
Hi, Simon. Apologies for not being clear. Yes, the ship is at a distance from the BH in flat-spacetime and the capsule is lowered into it. Then, after a year, it's reeled back inside the ship. The timer is of course synchronized with the ship's clock. What I care about is whether the explosive goes off or not.
It will not have detonated
Yes! That is what I thought, but for the timer inside the capsule, time is running normally all the way to the horizon, so at what time according to my clock does the bomb goes off?
Time is normal inside the capsule, there is just less of it.
As far as when it goes off, that depends on the motion of the capsule. Just specify the worldline and then integrate the spacetime interval over it.
One thing I don't understand is when does it happen. The capsule is ejected/fired/whatever and it's moving with uniform acceleration until it's stopped by the length of the tether which stops it from going further. During this time, both the clock on the ship and the timer in the capsule are in agreement, correct? When do they become desynchronized?
The desynchronization starts the moment that the capsule is lower in the gravity well than the ship. You could imagine the clock in the capsule sends a signal (at the speed of light, just to keep thing simple) up the cable every time it counts off another second. Before we start lowering the capsule, we on the ship will receive one signal every second according to our clock. As soon as we start lowering it, the signals will become more widely spaced so we no longer receive one signal for every second that our clock counts - the capsule clock is running slow compared to our clock so the clocks must fall out of sync.
I see. So if I wait those 365 days, then pull the capsule out of the BH, it will still be there attached to the cable, meaning the capsule experienced less time according to my clock. So based on my time limit of 365 days, there in no way for the capsule not to return, meaning when I reel the tether, I will always get the capsule back because of the time difference?
This is impossible as you state it. If a black hole is present, spacetime is not flat, period. What you could say is that the ship is far enough from the BH that the effects of spacetime curvature are negligible--so, for example, the rocket thrust required for it to hold station at a fixed distance from the hole is too small to observe.
Does the capsule cross the horizon or not? I think you intend not, but I'm not sure because of some things you say in later posts. If it doesn't, then saying the capsule is lowered "into" the hole is misleading; that would imply that it crosses the horizon. If the capsule does cross the horizon, then you can't reel it back in or receive any signals from it after it does, so asking "when" it detonates relative to you is meaningless.
This is impossible. The only way to keep the two clocks synchronized would be for them both to be (a) at rest relative to each other, and (b) in the region of spacetime where the effects of spacetime curvature were negligible. This is certainly not the case for the capsule.
Let me give you another way to think of it.
Consider a piece of paper with two points, A and B, connected by two paths. One path is a straight line and the other path is a semicircle. The straight line is shorter than the semicircle. Distance is normal along the semicircle, meaning that the Pythagorean theorem determines distances just as with any curve. There is just more ordinary distance along the semicircle than there is along the straight line.
Now ask "where is that extra distance located"? Does it make sense to say that the extra distance is at the beginning or the end or middle? No. The path is longer, but it isn't like the additional length is located in a particular part of the semicircle.
Hi, Peter. You're quoting my reply to Simon. In the OP, I said ''parks her ship at distance where she is not affected by the hole's time dilation effects.'' Isn't that region good enough to be called flat spacetime?
Read my OP. You are quoting what I said to Simon in reply to his question ''The capsule is maybe lowered into the black hole's gravity?'' to which I replied ''the capsule is lowered into it.'' Meaning the capsule is lowered into the black holes gravity. I never intended for the capsule to cross the EH.
I don't even think it's possible to keep clocks synchronized in a two-story building, but my point was that the timer inside the capsule departed with its clock synchronized with the one on the ship.
My main concern was to lower the tethered bomb-capsule into a strong gravitational field and test whether there was any chance of it going off before I pulled the cable back. Because of the time dilation effect, it seem I will always get it back unexploded.:smile:
Of course there is a chance for the capsule to detonate before it is pulled back.
Just wait longer... until the clock with the bomb has ticked off 31536000 of it's seconds.
Exactly how long that is by the ship-clock depends on what exactly happened when the capsule was lowered. You can work that out by figuring out what path that is (say, it is winched down at a constant rate, or maybe free-falls till it reaches a specific distance - whatever) and then integrate over the space-time interval for that trajectory.
Note:
the ship does not have to be in flat spacetime for the point of your question to work, and you do not need a black hole (though it kinda helps since you can easily get very large time dilation effects, avoiding the issue of the bomb blowing up as it is being winched in).
Simon Bridge said:
Note:
Hey, that's true. What if I send the capsule flying off at close to c for a year then winch it back at the same speed. Would I still get the same result?
You do the same thing: integrate over the space-time integral for the trajectory.
Do you mean, here, to change from a gravitational time dilation to more of a twin's paradox situation?
Yes. I want to find out in which scenario I get the bomb to explode before it's retrieved. Obviously I could wait until it goes off like you said, but I want to constrain the experiment to the time allotted (365 days) otherwise what is the point. BTW, I don't know how to integrate integrals or what that even means in any rigorous way, but thanks for even suggesting that I could.
Then the only option you have is to set up a scenario where your elapsed time is less than that of the capsule, not more. For example, you could put yourself deep in the gravity well of something like a black hole, and send the capsule out into deep space, far away from the hole, in such a way that if nothing else happened, it would return to you in 365 days by your clock. Then the capsule would explode before it returned.
Yes, indeed. I'm having a tough time visualizing the time frame of the capsule going out of the gravity well, though. If I go by what Nugatory said, then the pulses traveling along the cable as the capsule makes it way out of the well should return to me faster?
I'm not sure why. Just take the original scenario where the capsule was deep in the gravity well and you were way outside it, and reverse that. Now you are the capsule and the capsule is you, so to speak. Obviously your "time frames" will be switched.
Yes. Which means that the 365th pulse from the capsule (if we suppose there is one pulse per day--or the 365*86400th pulse if there is one pulse per second), emitted just before it explodes, will reach you before your own clock has shown 365 days elapsed.
PeterDonis said:
I'm not sure why.
This is what I'm picturing: deep inside the gravity well, but just before I cross the horizon, things don't look normal as they do in flat spacetime or do they? Like for example, starlight is now brighter isn't it? Which mean I can place a visual clock on the capsule and watch with a telescope as its clock starts moving faster than mine? In other words, I can witness the capsule age before my very eyes? Something is wrong with my understanding.
Locally they do; you can't tell by any local measurements that you are hovering close to the horizon. Everything looks the same as a small patch of flat spacetime.
Not brighter, but blueshifted. Its total intensity doesn't change, but its frequency does. However, this isn't a local measurement; the starlight is only blueshifted because it is coming in from very far away.
If you're looking for a way to have the capsule's time run faster, while having everything in the universe still look to you the same as if you were way out in empty space, far from all gravitating bodies, there isn't one.
Yes.
PeterDonis said:
Yes.
Far out.
If you hover you obviously have to be stationary and thus enable proper acceleration, towards the EH the acceleration would go towards infinity. Even when you are free falling you could determine if you pass the EH by observing the Karlhede’s invariant.
That's true, but it still doesn't enable you to distinguish, locally, between being close to the EH and having the same large proper acceleration out in empty space somewhere.
Which involves covariant derivatives of the Riemann tensor and therefore requires measurements that are not local; you have to at least cover a large enough region of spacetime for the Riemann tensor and its derivatives to be observable. (Which is not to say this is not an interesting invariant to consider.)
  • · Replies 25 ·
  • · Replies 58 ·
  • · Replies 58 ·
