Gravity/acceleration equivalent?
  • Level: Graduate
  • Thread starter Thread starter ubavontuba
    Equivalent
86 replies · 19K views
I probably just don't understand the context...
I was under the impression that there were time effects from gravitation alone and that there were well known in regards to muon decay. The SR effects are there and are exactly as predicted, but any GR time effects that one might incorrectly intuitively assume should be there are not.
Basically it comes down to that a gravitational field has depth whereas acceleration really only has intensity. This seems like a difference to me. Not a difference that changes anything fundamental, just simply a difference.
Because you can use something like this test to measure your depth in a gravitational field, it is distinguishable from acceleration. Hence my assertion that the whole elevator test fails and equivelency is approximate, not exact.
I'm trying my best to understand what you might have thought I was saying but I can't see any other way to interpret it. It's as simple as saying there are time effects that occur in gravitation that simply do not in acceleration. Is that not an inequivalence or am I missing something fundamental?
Unless these time effects from gravity would be observable in an arbitrarily small region of spacetime, this cannot count as a violation of the equivalence principle. For example, gravitational time dilation effects that depend on different clocks being at substantially different distances from the source of the gravitational field couldn't be reproduced in such a small neighborhood, so they wouldn't qualify.
Also, you might find this answer from the Physics FAQ on John Baez's site helpful:
Does a clock's acceleration affect its timing rate?
And actually, I guess I was wrong that gravitational time dilation effects from being at different heights in the gravitational field can't be explained using the equivalence principle, because in one section of this answer they write:
But what about the Equivalence Principle?
Sometimes people say "But if a clock's rate isn't affected by its acceleration, doesn't that mean the Equivalence Principle comes out wrong? If the Equivalence Principle says that a gravitational field is akin to acceleration, shouldn't that imply that a clock isn't affected by a gravitational field, even though the textbooks say it is?"
No, the Equivalence Principle is fine. Again, the confusion here is the same sort of thing as above where we spoke about the wind chill factor. Let's try to see what is happening. Imagine we have a rocket with no fuel. It sits on the launch pad with two occupants, a couple of astronauts who can't see outside and who believe that they are accelerating at 1 g in deep space, far from any gravity.
One of the astronauts sits at the base of the rocket, with the other at its top, and they both send a light beam to each other. Now, general relativity tells us that light loses energy as it climbs up a gravitational field, so we know that the top astronaut will see a redshifted signal. Likewise, the bottom astronaut will see a blueshifted signal, because the light coming down has fallen down the gravitational field and gained some energy en route.
How do the astronauts describe what is going on? They believe they're accelerating in deep space. The top astronaut reasons "By the time the light from the bottom astronaut reaches me, I'll have picked up some speed, so that I'll be receding from the light at a higher rate than previously as I receive it. So it should be redshifted--and yes, so it is!" The bottom astronaut reasons very similarly: "By the time the light from the top astronaut reaches me, I'll have picked up some speed, so that I'll be approaching the light at a higher rate than previously as I receive it. So it should be blueshifted--and yes, so it is!"
As you can see, they both got the right answer, care of the Equivalence Principle. But their analysis only used their speed, not their acceleration as such. So just like our wind chill factor above, applying the Equivalence Principle to the case of the rocket doesn't depend on acceleration per se, but it does depend on the result of acceleration: changing speeds!
edit: on second thought, is light redshifted because of a change in the strength of a gravitational field, or would it be redshifted even in a constant-gravity field? If the latter, then my comment about not worrying about effects that depend on different gravitational strengths at different distances from the source could still be right.
Ok. Yeah, I see what you are saying.
Acceleration causes no time dilation is the point that the experiment proved. Gravity does. While that doesn't specifically fit with the thought experiment's criteria because of the need to communicate at a distance, there's still a difference between acceleration and gravity.
I guess the communication with a GPS satellite or some such was just kinda happening in my head without me noticing I glossed over that requirement.
JesseM said:
It's not fantasizing new laws of physics, it's simply subtracting out GR and imagining a universe where SR holds exactly. That's what the equivalence principle is all about, that locally a freefalling frame in GR is exactly like an inertial frame in SR.
Sure, but This isn't how Einstein wrote it in that paper I referenced. However, he dismissed the framework that is accelerating as being unimportant. I suspect he imagined it as being quite fixed in its trajectory in all dimensions. That is, it couldn't be steered, nor would it suffer acceleration differentials, like from jumping up and down (another test method I hadn't mentioned).
However, if the accelerating framework was thusly fixed and it had less mass than the Earth, I can still think of an experiment that would determine acceleration versus gravity.
In any case, you could always imagine the crane had thrusters or something so that it would be just as resistant to sideways acceleration as a crane sitting on the earth. And if you keep the box above the Earth in a way that does not allow its movements to push or pull on the earth--say, by rockets attached to the bottom of the box--then you don't have to worry about the inertia of the earth. But if the box is attached to the Earth in such a way that momentum applied to the box internally (by punching the wall, say) is dispersed into the earth, then it's no good to imagine a situation in space where the momentum is dispersed into a mass much less resistant to acceleration than the earth, these are non-equivalent physical situations just as much as if you imagine the box accelerated from the bottom through space but held up from the top on earth.
Even with lateral thrusters, I could still tell. However, if you isolate the room like in your free-floating rocket powered box, I don't think I could tell.
Truly isolating the room is the key. By "hanging" the room I'm sure he was attempting a form of isolation, but it still isn't true isolation.
Interestingly, Einstein's concept remains sound even though the thought experiment as he'd written it, fails under certain test conditions.
Well, as you say, I think he was just talking about what an observer would detect in a steadily accelerating box in that paper. And I think a mathematical statement of the equivalence principle would probably just be in terms of the equivalence between freefalling and inertial frames (though I'm not sure of this), but physicists writing for a popular audience will often treat this and the sitting still in a gravitational field/accelerating in empty space thought-experiment as interchangeable. This is probably because, as I said earlier, the second one does follow directly from the first one if you impose the appropriate restrictions.
You're saying that even if the box's motion cannot be affected from the inside, you think you could tell? How?
I'm pretty sure you couldn't, not if the lateral thrusters were programmed to make sure the parts of the structure on the boundary of the inertial observer's imaginary box responded in exactly the same way to motions of the physical box as the same structures would respond as they would on earth.
Besides this, if we assume any motions of the box only impart significant motion to the cable (swaying, for example), while the crane holding the cable is affected in a negligible way (perhaps the cable could be connected to the crane by a frictionless ball bearing), then we wouldn't even need thrusters to insure there was no difference between what is experienced when the crane is sitting on Earth vs. when it's being accelerated at 1G.
There is no gravity in an inertial frame, therefore there is no gravitational time dilation. All time dilation is due to velocity.
(I am ignoring, for the moment, the gravity of the Earth itself, which is a minor effect in this problem that's constant both for the muon in motion and the muon at rest, so not only is it small, it cancels itself out.)
If one works the problem in the coordinate system of the muon, one does have to take into account gravitational time dilation (or equivalently, a non-Minkowskian metric).
But in an inertial frame, the metric is always Minkowskian, and there is never any gravitational time dilation.
The sci.physics.faq entry that Jesse quoted earlier should also go into this.
Mike2 said:
What may be of interest is how the Unruh affect applied to accelerating frames of reference might be applied to small regions of space at a fixed distance from a gravitating body.
Good point; however, the effect is generally considered equivalent; and can be considered equivalent to Hawking radiation at the extreme, although there are some differences.
See:
http://www.emis.ams.org/journals/LRG/Articles/lrr-2001-6/node3.html
Creator:biggrin:
I was referring to the case where the room still hangs and swings freely, but the accelerating frame from which it hangs self-compensates. If you want the room to be still too, then let's compare it to a room that is fixed on the earth. In this case, I could tell (comparing apples with apples, you know).
This is basically as I've stated above. However you are missing a crucial difference here. I could tell.
I'm not clear on what you mean here. Do you mean the room swings freely on Earth and in the accelerating frame, but the accelerating framework's motion is fixed (self-compensates to maintain constant and straight acceleration)? In this case, I could still tell.
As you've suggested, the popular version that Albert Einstein wrote versus the theory, aren't necessarily quite the same. It appears to me that equivalence is still a perfectly valid concept in free-fall reference frames. It also seems valid in conditions that properly isolate the room in accelerating frames. He just failed to properly isolate the imaginary room.
I just find it very interesting that the master's own work in his own hand can be challenged succesfully (especially by a goof like me). Am I the first to realize this? Can anyone find any prior references?
By "accelerating frame", do you mean the actual physical structure it's hanging from, or do you mean the accelerating reference frame? I know what it would mean for the structure to self-compensate, but not for a reference frame to self-compensate.
But if the room is fixed, how could you tell? Just to be clear, by "fixed" I mean it's impossible to move the room at all relative to the Earth (including swinging it back and forth), and it's impossible to change the rate of acceleration of the room in space.
Yes, in both cases I'm assuming the physical framework that the cable holding the room is attached to cannot be moved, but the room/cable can still swing around.
I'm pretty confident that you couldn't. If you think you could, how would you do it?
I wouldn't really regard this as a mistake on Einstein's part because the description seems to assume that the rate of acceleration of the room in space is constant (ie no swinging, which would involve changing sideways acceleration). From the paper you referenced:
To the middle of the lid of the chest is fixed externally a hook with rope attached, and now a “being” (what kind of a being is immaterial to us) begins pulling at this with a constant force. The chest together with the observer then begin to move “upwards” with a uniformly accelerated motion.
And likewise, it is assumed that the chest would be at rest in the gravitational field:
Just then, however, he discovers the hook in the middle of the lid of the chest and the rope which is attached to it, and he consequently comes to the conclusion that the chest is suspended at rest in the gravitational field.
He's saying that with these conditions, all experiments in the room will give the same results in the two situations; his description doesn't really say anything one way or another about experiments which change the basic conditions of his thought-experiment (and nowhere does he make any blanket statement like 'there is no experiment the man can do to determine whether he is really being pulled at an accelerating rate in empty space or hanging from a rope in a gravitational field').
First, I want to reitterate again that this is not meant to be a serious consideration in regards to equivalency, but rather this is meant to be a fun exercise in creative thinking.
Yes. I generally try to use "framework" to differentiate, but forgot in this case. Einstein's "being" seems to imply a thinking entity to me, so I prefer not to use it.
Please note Einstein states: "and now a “being” (what kind of a being is immaterial to us) begins pulling at this with a constant force."
Please note the term "constant force," not "steady rate."
Therefore, in his ball dropping analogy, he analyzes the consequences incorrectly. If the dropped ball were of sufficient mass, the observer would notice a momentary "increase" in gravity (acceleration) as the ball is released (since it is momentarily dettached from the total mass and therefore the "constant force" will work just as hard to accelerate less mass), and there would be a subsequent decrease in gravity (deceleration) when the ball hits the floor.
In fact, the changes in kinetic energy might cause the ball to apparently bounce higher than it fell! (relative to the observer in the room)
So, it looks to me like Einstein played pretty loose with the rules. That is that he made statements that just aren't entirely true to demonstrate his points. Weird, isn't it? Maybe he just had trouble with English?
Again, am I the first person to notice this? I can't find any prior references. Has anyone else had any luck?
Oh ye of little faith! Do you not remember how you thought I couldn't tell in the first place? Why do you doubt me now? (with apologies to my fellow Christians).o:)
Seriously, if we consider that the known laws of physics still apply to all structures (except for the impossible constant acceleration at a steady rate regardles of motion in the room)... I could tell.
Yeah, but this statement kind of implies it:
"Relying on his knowledge of the gravitational field (as it was discussed in the preceding section), the man in the chest will thus come to the conclusion that he and the chest are in a gravitational field which is constant with regard to time."
Also, you had earlier made this statement yourself and even referenced some papers in regards to it. And note how even the experiment he does explain is analyzed incorrectly (as I stated above).
As the man in the box must obviously move about to perform the observations Einstein mentions, wouldn't the box tend to sway? "Relying on his knowledge of the gravitational field," wouldn't a lack of normal swaying tell the observer that he shouldn't be too quick to jump to Einstein's conclusion?
See:
Creator:biggrin:
Has anyone studied what happens near gravitating bodies as the Unruh/Hawking effect adds an energy density to the surrounding space associated with the temperature - that since this added energy density adds an additional small equivalent mass density, then this would result in further gravitation, resulting in further Unruh/Hawking temperature, then energy density, then mass density, which would add further temperature, then energy, then mass, which would be iterated to infinity. How would such a process converge? Could this account for dark matter effects?
Okay, so the point is here that he's actually receeding from the frame that the emitter was in at the moment of emission. No problem.
Where I'm having a problem is that the top astronaut should be experiencing time faster than the bottom one if they are truly in a gravitational field. If they are actually just accelerating in deep space he is not. That is proven by the muon test.
This means that if the bottom astronaut fires a pulse at the beginning of a muons life and one at the end, and the top astronaut measures a muon's life in his location. After factoring out SR considerations, it would be possible for the top astronaut to determine whether or not he is in a gravitational field or just accelerating.
Accelerating: Lifetime the Same.
Gravitational field: Bottom Muon lifetime > Top Muon Lifetime.
That´s not true.
Ich said:
That´s not true.
Umm. Okay. Mind giving some detail/qualification? Which part?
Can you explain how your answer relates to the experiments I cited earlier?
I read from the link Jesse posted and it was interesting but it didn't seem completely relevant to the context.
Unfortunately I don't entirely follow what you are saying about taking gravitational time dilation into account above. We factor out anything wrt the Earth's gravity because it is equal at rest and in the storage ring where it is accelerated.
The result of the experiment is that the muons decayed at the same rate under many thousand Gs of acceleration as they did in the lab frame. If acceleration and gravity are equivalent, the lifetime of the muons should have been greatly extended from the perspective of the lab frame. They were not.
Apposingly it is well known that Muons decay faster in outer space and clocks run faster in outer space when viewed from the same lab frame (assuming it is inertial for simplicity)
So, what exactly do you mean?
As an aside: The truth of the matter is that there is no such thing as a truly inertial frame because time would pass instantly (or not at all) without the presense of any gravitational field. Time contraction/dilation (crap! which word is right?) would be infinite. Time cannot exist without gravity so far as I understand it. (and have read einstein's comments to the same)
The only gravity present in the Earth's frame is the Earth's gravity, which we both agree is irrelevant.
What is present in the Earth frame that makes the muons accelerate is not gravity, but a centripetal force. So the simple answer is that there is no gravitational time dilation in the Earth's frame, because there is no gravity there!
I.e. it is an electromagnetic force, NOT a gravitational force, that accelerates the muons radially. In order for there to be gravitational time dilation, there must be a gravitational force on the muon's. But there is no such force (except the negligible downwards force of Earth's gravity).
I don't know exactly where you got this idea, but it's totally wrong :-(. Clocks can exist just fine without gravity.
But you're ignoring the next sentence, which I highlighted: 'The chest together with the observer then begin to move “upwards” with a uniformly accelerated motion.' I would say this is part of the conditions of the thought-experiment he is describing, if you do something to cause the motion to no longer be 'uniformly accelerated' then you're describing a different thought-experiment.
I'm actually pretty confident you couldn't, just by considering the point of view of a freefalling/inertial observer who draws an imaginary box around himself and observes the cable and smaller physical box as it passes through his imaginary box. If the structure the cable is attached to is not affected by the motions of the box/cable, then both the inertial and freefalling observer will see the point of attachment of the cable to the structure to be accelerating towards the ceiling at a constant rate. Therefore, the only thing which could vary between the inertial and freefalling observer is the cable and small box, which can be assumed to lie totally within his imaginary box for some small time-interval. So, it seems to me that the freefalling/inertial version of the equivalence principle, which you said before you don't dispute, would demand that there be no difference in how the box and cable behave in response to identical actions by the gnome in the box.
Anyway, if you think I'm wrong, don't be coy--what's your experiment?
I don't think it implies it too strongly, in any case--he's still talking about what the man will include in the experiment as he describes it, which includes the idea that the chest is moving with a "uniformly accelerated motion".
The papers I referenced in post #6 only defined the equivalence principle in terms of the freefalling/inertial equivalence, though. Also, in your initial post you also suggested it was part of the conditions of the experiment that the room was 'being pulled under a constant 1g acceleration'--so if you allow experiments which cause the room to no longer accelerate at 1g, you're changing the conditions of the experiment. Finally, when you asked for qualifications I did say that I was justifying the at-rest-in-a-gravitational-field/accelerating-in-space equivalence in terms of the freefalling/inertial equivalence, using the "box-inside-a-larger-box" argument that I've been using frequently, in post #10. If you have a structure holding up the smaller box which cannot fit inside the freefalling/inertial observer's small imaginary box, and this structure would behave differently on Earth vs. when accelerating in space, this argument breaks down.
I'm not saying you haven't hit on an interesting point though, what you show is that one needs to be careful about exactly how one states the equivalence between the observer at rest in a gravitational field and the observer accelerating in empty space. I'm sure you could find some authors who have not been careful enough, but I don't think Einstein is really guilty of this sort of mistake here.
Well, you can always make the idealization that the man's mass is very small compared to the mass of the chest. Anyway, it's a thought-experiment, so I think you're allowed to ignore practical complications like this.
Aside from the fact that Einstein specified the box should be accelerating at a "uniform" rate, there would be swaying in space if you performed the same experiment that led to swaying on earth. What makes you think there wouldn't be? Conservation of sideways momentum should hold just as well in space as on Earth (in both cases there is no external force being applied in the sideways direction), so if I jump sideways inside the chest, the chest itself will have to temporarily move a bit in the opposite direction to conserve total sideways momentum. Of course, as soon as I land on the floor again the swaying should stop, but this would be true on Earth too if you were in a vacuum and the structure holding the cable was fixed and not able to move on its own.
I don't know that I understand your point. "Its a chemical-reaction force that accelerates a rocket, not a gravitational one." In the end I really don't care what force accelerated something not under the influnce of gravity. But what I am saying may be obvious to your or something I guess. All I'm saying is that if you are in a rocketship in deep space being accelerated by rocket boosters as apposed to being in a rocketship sitting on the ground being accelerated by gravity. There is a testable difference and therefore gravity and accelleration are not equivalent.
Heh, well I got it from well known public Einstein quotes in which he states that time cannot exist without mass and gravity. So in effect, yes a physical clock would create a gravitational field but then it wouldn't be in a truly inertial frame anymore would it? I can go find the qoutes if you like...
You're still missing the point :-(.
If you are in an accelerating rocketship
YOU ARE IN A NON-INERTIAL FRAME!
I'd make this blink if I could :-).
I.e when you are in a rocketship AND you adopt coordinates that accelerate along with the rocketship, you 'see' gravity, and you also 'see' gravitational time dilation.
If you are in an accelerating rocketship and you do NOT adopt accelerating coordinates (ie you use inertial coordinates), you do NOT 'see' any gravity, and you also do NOT 'see' any gravitational time dilation.
Because the Earth frame is effectively an inertial frame for the muon experiment, there is no gravitational time dilation in that frame. At least not in the sense you mean.
I have no additional comment to make on your other idea about time & gravity - I'll stand by my original comment, though.
Why would the Earth frame be considered effectively inertial? In the presence of gravity, isn't it only a freefall frame that can be considered equivalent to an inertial frame, while a frame at rest in the gravitational field is equivalent to an accelerating frame? Or are you just saying it's effectively inertial because Earth's gravity is weak enough that gravitational time dilation effects would be negligible compared to velocity-based time dilation effects in this experiment?
Actually, I feel that you're taking this out of context. It seems to clearly imply to me that the total mass of the chest and the occupant are accelerating at a unifrom rate as a result of the constant force. Not that the uniform acceleration is constant regardless of the force.
I suppose it should be evident by now that I am anything but coy. I mean how coy could I be if I'm willing to scrutinize Einstein's own works so deliberately?
However, the parameters of this experiment must be clearly understood by both of us, so that I don't accidently claim success (or failure) for the wrong experiment, applied to the wrong conditions. Please specify your conditions, but keep it relevant. That is, the conditions of the box on Earth should match the conditions of the box under acceleration, save for the fact of acceleration. Also, the accelerating framework's physics must be described to a reasonable degree. I.e. does it keep it's uniform rate and latteral conditions with retro rockets? Is it a sort of elevator accelerating in a fixed framework/shaft? If the accelerating framework's properties are ignored (or made to be arbitrarily equivalent to gravity without defined rules), then we can state anything we want and therefore we might as well call it "magic."
As I've said above, I disagree with this interpretation. However, I (by ""Relying on (my) knowledge of the gravitational field") would know that I'm not in gravity, even if Einstein's occupant is unable to make this determination. I'm not saying his occupant is stupid, but... :wink:
That was just my opening setup question to garner interest, but I'm willing to concede this as a parameter so long as it's described how it is achieved (rockets and brakes?). But note; I feel this exceeds Einstein's own given parameters.
You are right about having to be careful in regards to modelling the principle. But I disagree with you in your assertion that Einstein was so careful. In my view, his theory has become widely accepted on its own merits in spite of his explanation (in this context).
I disagree. By ignoring the laws of physics while examining the laws of physics you endanger the outcome as being irrelevant. I think Einstein knew his theory better than he was able to describe it in this context and therefore it's valid on its own merits in spite of his inability to describe it well (in this context).
My point here is that you coudn't swing it like a pendulum since this would disturb the center of mass for the system and would require a reactionary oscillation that isn't available in the accelerating system without unusual consequences.
And I think they are both part of the conditions that he's describing, that the external force is constant and that the acceleration is constant (implying internal forces are considered negligible).
Well, the condition we were discussing was that the box and the cable can move around but the acceleration of the framework the cable is attached to can be considered negligible. You don't really need to introduce retro rockets to achieve this, just consider the limit as the mass of the box and cable becomes negligible compared to the mass of the framework (but keep the mass of the framework constant so you don't have to worry about its increasing mass curving spacetime enought to have a noticeable effect on the experiment).
One other simple solution that occurs to me is to assume the framework itself is capable of sliding without friction on the surface of the earth, so you don't have to worry about any of its sideways momentum being transferred to the Earth and thus the inertia of the Earth isn't relevant to the problem. In this case the acceleration of the framework doesn't need to be negligible, but it will be the same in both the at rest on Earth case and the accelerating in space case.
But Einstein doesn't ever say that there is nothing the occupant could do to determine which is really the case (he could blow a hole in the side of the chest and look outside, for example). Given the conditions he sets, which includes uniform acceleration, any experiment the guy does in the accelerating box could just as easily be explained in terms of a gravitational field, that's the only point he's making.
There is nothing in the quoted text that dignifies being called a "theory", it is simply an illustration of the equivalence of uniform acceleration and uniform gravity, which is part of his theory of general relativity.
There is a big difference between "ignoring the laws of physics" and presenting idealized cases which would be valid approximations in certain limits. For example, it is common in illustrations of mechanics to assume zero friction even though this is impossible to achieve in practice. It is common to assume that gravitation is constant in the neighborhood of the surface of the Earth even though we know that the gravitational pull should be slightly less 2 meters above the surface as 1 meter above the surface. It is common to assume that the orbit of a planet is determined solely by the gravity of the sun, even though the gravity of other planets and distant stars and dust particles in space should have some small effect on a planet's orbit. Here we are dealing with a similar sort of approximation, where the mass of any moving parts in any experiments (such as the mass of a dropped ball) is assumed to be negligible compared to the mass of the chest. If you disagree with the whole practice of making true-in-the-limit approximations of this nature, then you would have to reject basically every illustration of every physics principle in every textbook.
Fair enough, although I disagree.
Well, in the ideal case you can't swing it like a pendulum on Earth either, because without any external sideways force (assume the experiment is done in a vacuum chamber so there's force from the air) the center of mass should not be able to move in a sideways direction. But I suppose even an ordinary pendulum varies in its sideways momentum from the bottom of its arc to the top, and we know we can even change the size of our arcs on a playground swing by pumping our legs, so I guess this isn't very realistic. I'm actually not quite sure what the best explanation for this is, but if you imagine the pendulum swinging on a string which is looped around a rod sticking out of a wall, I think what's probably going on is that some of the pendulum's sideways momentum is being transferred to the rod (through the contact point between the loop of string and the rod) which in turn transfers it to the wall, which doesn't visibly move because its mass is so much larger. But there's no reason this should work much differently for a pendulum attached to a rod and wall which are accelerating in space than for one attached to a rod and a wall which is sitting on Earth (and the slight difference due to the wall being attached to the Earth itself can be eliminated by assuming the framework can slide on the surface Earth without friction, as I suggested earlier...if the framework's mass is much larger than the pendulum's mass, this sliding wouldn't be noticeable anyway).
There is some gravitational time dilation with height on Earth.
This gravitational time dilation is due only to height. It's not important to the muon experiment because 1) the effect is small and 2) all the muons in the ring are at essentially the same height anyway.
If you performed this experiment out in empty space, without gravity, you would get no different results. If you performed it on a rocketship accelerating out in empty space at 1G, the resutls would be the same as well. The non-inertiality of the Earth's frame due to its height (or any of several other small effects) just doesn't matter.
ubavontuba said:
... I (by ""Relying on (my) knowledge of the gravitational field") would know that I'm not in gravity, ...
That's only because your original experimental proceedure used a mere 1/2jigger of brandy.
Had you used the entire bottle of brandy for step #1 there is no way you would have been able to determine from which direction gravity is (or is not) operating.:-p
Creator:biggrin:
Ha, Ha! That's too funny! However, I'd note a certain amount of unusual angular momentum! (Since I'd be flat on my back with the room apparently spinning!)
Sure. This is possible, but the mass of the accelerating framework (AF) would have to be pretty large and therefore it would have its own gravity (messing things up). It doesn't really matter though as the effects I noted would be the same, only smaller (requiring the more accurate, perhaps hypothetical measurements I wrote of earlier).
Naw, that's a bit vague. Even if the AF were fairly massive (like a battleship) the resonance of a swinging mass that could comfortably hold a man would tend to skew its trajectory. Anyways like I said above, the amount of mass it has isn't important since hypothetically the same effects are still observable.
Actually, even in this scenario I could still hypothetically tell. This would simply be a matter of measuring how much I could tilt the apparent gravity by bouncing off the walls, attempting to tip the room. On earth, it would always slide parallel with the the circumference. On a smaller mass, the uneven pressure resonating across the center of mass would cause the whole system to tilt back and forth.
If the AF were rigidly held in its path by some means, I can even think of a hypothetical experiment to detect that.
A swing works on resonance. The first upswing cannot exceed the boundaries of the box, but subsequent swings can get higher and higher. Hypothetically there is a reaction to this transmitted to the earth, but as you noted, the overwhelmingly large mass doesn't seem to care.
Ah but it is still there in a hypothetical context and unless the mass were as big as the earth, it would be different than normal gravity and would therefore be hypothetically detectable. But note, if the mass were as great as the Earth and accelerating at the rate of 1g, our hapless man-in-the box being towed by the mass would be in free-fall!
It wouldn't have to be that large, because as I've pointed out before, Einstein isn't saying that nothing the experimenter can do will reveal a difference between the chest in gravity and the accelerating chest, he just says that when he does typical experiments like dropping objects from his hand, the results will be just like if he were in a gravitational field. If you drop a 100 g ball inside a 1000 kg box, it's a reasonable approximation to treat the change in acceleration of the box as negligible.
First of all, this is just an idealized limit, and since I specified that the mass of the framework was being held constant, it was implied that we are taking the limit as the mass of the man and box are becoming smaller and smaller (imagine using a series of smaller and smaller gnomes in smaller and smaller boxes).
But even if we want to be more practical, the swinging box isn't going to be able to shift the trajectory of the framework in any cumulative way because of conservation of sideways momentum, all it can do is shift the framework back and forth at the same rate the room is swinging back and forth. And how fast do you think the guy in the room is going to be able to get it swinging using resonance? I don't think there'd be any theoretical upper limit, but eventually it'd be going fast enough that the person won't be able to time the motions of his body to match the resonant frequency. If we plug in a number for a plausible maximum velocity of the box at the bottom of its arc, we can figure out the maximum velocity of the framework using conservation of momentum; if we also know the period of the box's swing, we can use this to figure out an upper limit on how far the framework can move back and forth. I would guess that if the box is assumed to have a mass of 200 kg and the framework is assumed to have the mass of a battleship (which according to http://chemistry.umeche.maine.edu/~amar/fall2004/SigFigs.html would be around 1.3 * 10^8 kg), then for a plausible maximum velocity the amount the battleship would move would probably be microscopic.
True, on Earth the framework could only move in a sideways direction, while in space it could also move up and down somewhat (but I'm not so sure if the movement of the pendulum could cause it to rotate at all--suppose the cable holding the pendulum was tied to a rod which was sticking out of the dead center of the framework, how could the pendulum's movements apply any torque to the framework?)...although again, I think this effect would be microscopic if the mass of the framework was large enough.
OK, what measurement would you make in this case?
But see the point I made in the last post about approximations used in all of physics, like the assumption that objects can slide without friction or the assumption that the sun is the only body whose gravitational field affects the orbit of the earth.
JesseM,
As I'm sure you can see, and as I predicted, we are moving steadily away from the parameters of the thought experiment originally proposed by Einstein.
What happens in this case is we start chipping away at the fundamental differences in an attempt to make the experiment fit the theory. We do this by applying restrictions that make the variances smaller and smaller until they become negligble to the point of only being hypothetical on a very small scale. They remain, but they diminish to the point of ambiguity.
This is accomplished by either increasing the AF mass in order to make its inertial properties more earthlike, and/or by increasing the isolation of the room. (Note that I have said that properly isolated, I don't think I could tell.)
Your rocket powered floating room was a good example of proper isolation. However it ironically achieves this by being the same 1g acceleration device as a freely accelerating room, only it happens to be doing it in a 1g gravity field... for no net acceleration! (But it'd require loads of energy).
In the friction free consideration, I could tell by measuring the mass with a kinetic energy experiment. If the AF were sufficiently small, it couldn't absorb a lot of kinetic energy without ringing like a bell. Basically, I need but strike the floor with a sledgehammer. Of course increasing the mass will again diminish this effect, but it is still hypothetically different than gravity unless the mass becomes as large as the Earth (and then of course, you have normal gravity).
See? The fundamental difference between gravity and acceleration that I have been exploiting is that gravity is mass dependent and acceleration is not (acceleration is energy dependent).
This is of course not a profound consideration as I think it's rather obvious. It's just interesting that apparently no one (as far as I know) has put these facts together in the context of Einstein's thought experiment.
If I can think of a difference in the free-fall version I'll be sure to let everyone know, but I wouldn't hold my breath... :smile:
Oh, okay, so you are saying that you observe gravitational time dilation only if you share the same accelerated coordinate system?
How then can we on Earth observe gravitational red shift when observing stars and their light as they pass by massive objects etc. etc? We are not in their coordinate system by any means. All the effects of GR are tied together, how could one be observable from your separate frame without the rest?
