- 18
Well, I agree there will always be tiny differences, but they will go to zero in well-defined limits. You didn't really address my point about how virtually all thought-experiments in physics involve such idealizations that would be true in the limit, like objects sliding without friction. Not to mention the fact that the equivalence principle itself, even when stated in terms of freefall/inertial equivalence, depends on taking the limit as the size of the region of spacetime you're looking at goes to zero--for any small but finite-sized room, you will be able to tell the difference by looking at tidal forces. So what's the difference between this and the kind of differences you're talking about, which also disappear in the limit (in this case, the limit as box becomes arbitrarily light compared to the framework)? Would you say it is a problem that tidal forces "remain, but they diminish to the point of ambiguity"?ubavontuba said:JesseM,
As I'm sure you can see, and as I predicted, we are moving steadily away from the parameters of the thought experiment originally proposed by Einstein.
What happens in this case is we start chipping away at the fundamental differences in an attempt to make the experiment fit the theory. We do this by applying restrictions that make the variances smaller and smaller until they become negligble to the point of only being hypothetical on a very small scale. They remain, but they diminish to the point of ambiguity.
Well, my main response is the one above, but at the risk of getting sidetracked from the main issue again, you said you had an experiment that could determine even in the case where the framework had thrusters to compensate for its motions--what if the thrusters were hooked into sensors which could detect waves of movement traveling up the cable, and could anticipate exactly how they would cause the framework to accelerate when they reached the top, so that the firing of the rockets was timed to precisely compensate for this and insure that the framework never accelerates (or never changes its acceleration, in the accelerating-in-space case), not even briefly? In this case it would not ring like a bell or be affected in any other way by the motions of the box and cable.ubavontuba said:In the friction free consideration, I could tell by measuring the mass with a kinetic energy experiment. If the AF were sufficiently small, it couldn't absorb a lot of kinetic energy without ringing like a bell. Basically, I need but strike the floor with a sledgehammer.
