Stargazing Gravity anomaly during solar eclipse.
During a solar eclipse, some studies suggest a decrease in gravitational pull, attributed to the moon's position between the Earth and the sun, which may slightly reduce the sun's tidal acceleration. This phenomenon raises questions about why similar effects are not observed during a new moon. The discussion highlights the lack of consensus and understanding regarding these gravitational anomalies, with some participants expressing skepticism about the validity of the claims. The potential for gravitational waves from the sun interacting with the moon is also mentioned, though this idea lacks empirical support. Overall, the gravitational anomaly during solar eclipses remains an open and debated topic in the scientific community.
diabolic
Hi all,
http://www.newscientist.com/article...best-chance-to-look-for-gravity-anomaly.html"
the link given above elucidates that the gravity falls during the solar eclipse. I could not understand the logic. Can some one help me in understating the reason for this? why such discrepancy happens only during the solar eclipse why not during the new moon…. If duing the solar eclipse gravity falls then will there be an increase in gravity duing lunar eclipse?
Astronomy news on Phys.org
diabolic said:
Hi all,
In the article I saw no answers to your questions. The article gives me the impression that there aren't really any guesses yet as to why there would be such an anomaly. It looks like a good experiment, though. The rumors of such an anomaly do need to be resolved first, before anybody starts working hard theorizing why there would be an anomaly.
Well I never told that there is an answer for the anomalies…. This paper just tells that the there is anomalies. I wanted to know why? as it is against my conventional thinking as I see g=Me/r^2
This leaves me that g should be constant and should not vary with eclipse.
Are you sure that that formula is correct? I've never come across one like that, the closest I've seen is, g=(mG)/r^{2}.
Well even I meant the same….
I wanted to write gravity is proportional to mass of Earth and inversely proportional to square of its radius.
This looks more like a Force formula
F=\frac{GM_{e}M_{o}}{R^2}
G is universal constant
Me = Mass of earth
Mo = Mass of object
R = Distance BETWEEN both objects as measured from centre to centre
The GPE equation is similar only its referenced differently. So it is all negative and it is divided by just the distance between objects not the squared distance.
You have a small force vector from the moon's gravity. You should experience nearly the same effect if the moon was nearly in the same direction of the sun from earth, but not necessarily eclipsing.
This wouldn't explain the phenomena in the article though. You should just be a bit lighter that day.
How much lighter?
One of the article claims it is less by ~8x10^-8 cm/s^2 ; but it will not match up right? Or have I missed some thing…..
I don't know what the numbers are on this - it's just a thought. Is it possible that the sun's gravitational waves are rippling around the moon resulting in positive and negative wave reinforcement such that it is only strong enough to be observable when you are directly behind the moon with respect to the sun and at just the right distance from the moon?
This includes at least four suppositions without any support by data.
Could you elaborate on what makes this a wrong idea? I really would like to know where I'm not thinking correctly.
The gravitational pull of a chunk of mass in china makes it's way through the Earth just fine to exert it's gravitational force on you. I wouldn't expect the moon to act any differently.
diabolic said:
How much lighter?
F=ma=GMm/r^2
gmoon = GM/r^2
G = grav constant
M = Moon mass
r = radius of moon's orbit minus Earth's radius. I'll plug and chug
I get 3.8 EE-5 ms^-2, so that's about the same as the number above. They might have used perigee vs apogee.
That's about 4 millionth's of g.
So basically nothing.
http://arxiv.org/abs/gr-qc/0408023"
I doubt the answer is so straight forward. Please look at some of the conventional explanations of anomalous observations during solar eclipses.
If u think that force of moon has changed the gravity on Earth why is that gravity did not increase during lunar eclipse?
Without having read the article, is the measured error induced by wishful thinking diminutive to systemic error?
-but perhaps my question should reside in the social science folder.
Its an old wives tale, nothing gravitationally exceptional occurs during an eclipse. The paper you cite is . . . suspect.
which website are u talking about….. arxiv.org? I use to think it is a good site…..
BTW here is one more paper on this issue
http://adsabs.harvard.edu/abs/2003PhRvD..67b2002V"
this also some there is some discrepancy
diabolic said:
Hi all,
I believe one suspected cause of the anomaly is due to a reduction in the sun's tidal acceleraton (which is typically on the order of 50 microgals for the sun and 100 microgals for the moon) if the moon slightly attenuates the sun's gravity as the moon comes between the observer and the sun. Tidal acceleration would peak when the sun and moon are overhead, but tidal acceleration might slightly dip compared to that normally expected, and net gravity pull towards Earth's center would increase. During a new moon, without an eclipse, the moon does not come between the sun and observer.
NASA has been looking into this, but with apparently nothing firm to report.
http://science.nasa.gov/newhome/headlines/ast06aug99_1.htm
The references in the arxiv article may also be useful. See UnnM01. The NASA reference is also in 0408023.
At this time, the anomaly is an open issue.
51K
