What is the Effect of Gravity on Einstein's Train in Special Relativity?
  • Context: Undergrad
  • Thread starter Thread starter SlowThinker
    Gravity Train
The discussion centers on the effects of gravity on light behavior in a train moving at relativistic speeds, specifically analyzing the "stationary preferred" and "passenger preferred" views. The "stationary preferred" perspective is confirmed as correct, indicating that light sent from the center of the train car will hit the back wall at a higher point than the front wall due to the effects of gravity and time dilation. The conversation also touches on the implications of gravity creating a preferred reference frame and the complexities of calculating trajectories of dropped objects in such a scenario.
  • Understanding of Special Relativity concepts, particularly time dilation and simultaneity.
  • Familiarity with the Equivalence Principle in General Relativity.
  • Basic knowledge of light behavior in gravitational fields.
  • Ability to interpret and analyze thought experiments in physics.
  • Study the implications of the Equivalence Principle in various frames of reference.
  • Explore the Lens-Thirring effect and its relevance to gravity and motion.
  • Learn about the mathematical formulation of geodesics in General Relativity.
  • Investigate the relationship between relativistic speeds and gravitational effects on mass and density.
Physicists, students of relativity, and anyone interested in the interplay between gravity and relativistic motion, particularly in thought experiments involving light and reference frames.
SlowThinker
I'm still having difficulty with the fully mathematical approach to GR (via metric and tensors), so I'm making thought experiments to get a feel for some issues.
Let's have a train moving at relativistic speed on a flat planet (so that the train goes straight). Also the gravity is supposed to be constant, say g.
The passengers set up an experiment, in which light is sent from the center of a train car horizontally forward and backward and they measure the height where it hits the walls.
There is a view which I call "stationary preferred", in which the light will be seen to fall with acceleration g by a stationary observer. So the light will hit the back wall at nearly the original height, but it will hit the front wall a good bit lower - since it takes much more time to reach the front wall.
Another view is "passenger preferred", in which the light hits the walls nearly at the original height, same on back and front wall. It seems both views cannot be correct, and the "passenger preferred" is incorrect.
Some questions:
1. Is the "stationary preferred" view correct?
2. Does gravity create a preferred reference frame? Did I rediscover the Lens-Thirring effect?
3. If a passenger drops something, will it fall with acceleration g as viewed by a stationary observer? This would mean that a passenger would feel her weight increased \gamma-times. But some physicists say that the weight of objects in Einstein's train is not changed (http://arxiv.org/abs/physics/0504110 page 6).
4. I realize that objects dropped in the train will not fall perfectly vertically, since they would eventually exceed the speed of light for a stationary observer. Is there a simple way to compute the trajectory?
(4) seems to be similar to the case of a particle in a uniform electric field...
SlowThinker said:
There is a view which I call "stationary preferred", in which the light will be seen to fall with acceleration ##g## by a stationary observer. So the light will hit the back wall at nearly the original height, but it will hit the front wall a good bit lower - since it takes much more time to reach the front wall.
Ok so far.
No, it doesn't, because in this frame, the "gravitational field" is not the same as in the stationary frame, due to the relativity of simultaneity. Try analyzing this experiment in a rocket in flat spacetime that is accelerating upward with acceleration ##g## but has a sideways velocity as well; by the equivalence principle, this should be the same as the train moving horizontally on a flat planet.
Some questions:
Yes.
I guess it does.
You are right, paper is wrong. Consider a long circular train wrapping around a planet. That train has an increased rest mass when it has some internal motion, like spinning around its center of mass. Load more mass on a train - suspension springs compress - suspension springs = scale.
The projectile follows a geodesic. Let me consult Wikipedia about geodesic ... oh it's complicated.
No, it works like this: I stand still and watch a transparent accelerating rocket, inside of which the experiment of sending light beams to the walls is conducted. The light beams hit the walls at the same altitude. Now I start to accelerate orthogonally to the rocket acceleration. This causes the rocket wall that is farthest away from me to gain lead compared to other walls, in my frame. Light beams still hit the same spots on the walls.
(The synchronized motion of walls in one frame is a non-synchronized motion of walls in another frame)
Now the case with gravity: A transparent train and I are standing on the surface of a planet and inside the train the experiment of sending light beams to the walls is conducted. The light beams hit the walls at the same altitude. Now I start to accelerate orthogonally to the gravitational acceleration. This does not cause the train wall that is farthest away from me to gain lead compared to other walls, in my frame. Light beams do not hit the same spots on the walls.
I think you've misunderstood the problem (or how to apply the equivalence principle to the problem). The question asks about a train moving at constant speed through a gravitational field that is perpendicular to the direction of movement. Acceleration enters into the picture only if when you solve the problem by applying the equivalence principle, and in that case the acceleration you consider is parallel to the direction of the field, not perpendicular.
Would the value of g be the same in both reference frames ? I am thinking that, if I move on a geodesic on the surface of a planet ( i.e. approximately a great circle ) at relativistic speeds, the circumference of that planet should appear length-contracted to me. On the other hand, the total rest mass of the planet should remain the same, so the density of the planet as calculated by me should increase the faster I go in my train. What am I missing ?
0) To me it's clear that gravity in the train is something like \gamma g. Although things don't fall "down".
1) Circumference is length-contracted, but the radius of the planet is not. The tracks are going down very fast, and you need a strong centripetal force to stay at them. The centrigufal force beats gravity even at very low speeds (about 0.00001 c on Earth).
2) Perhaps the length contraction can be seen as the source of increased gravity in the train: more mass under the train is squashed into smaller length, making its gravity stronger. But confirming this would require "getting hands dirty" with actual math :confused:
That is what I was wondering, but my intuition tells me that this can't be right, because it would mean we can increase g without bound by just going closer and closer to c. Besides, the source of gravity is not mass density alone but the full energy-momentum tensor, which as a geometric object is of course invariant between frames. I think the reasoning of increased density leads to greater g in the train is a Newtonian one that doesn't really apply in this relativistic situation; the other components of the energy-momentum tensor have to be taken into account also.
EDIT : The above is actually silly, since we are dealing with the situation outside the planet in vacuum, so the energy-momentum tensor vanishes there ! Please ignore. Just having one of those days ?:)
Well is there not enough accelerating and moving happening? And still the light hits the same spots of the walls. Some acceleration may be there because it is very easy to see what effect motion has when there is first motionlessness.
Or could a train moving inside an accelerating rocket be a different thing than a rocket that is accelerating and moving sideways? Hmm.. Oh dear, yes it is, because the rocket floor keeps the train aligned with the floor.
So, when the train is accelerating along the floor it feels the floor tilting. When the train moves along the floor, does it have to use energy to keep the velocity constant on the tilted floor? Hmm ... No because if the floor is tilted then the rocket nozzles are equally tilted and 'gravity' is perpendicular to the floor. When the train accelerates, the whole rocket turns according to the train, that's how it is, probably.
That's the problem. The gravitational field creates a preferred frame of reference. You moving on the surface of the planet with a standing train, is not the same as you standing and train moving.
I don't think so, both parts. I'm pretty sure the train would keep its speed without using engines. That's the interesting part: things fall down and back, but passengers would stand vertically.
Since nobody has taken up my suggestion in post #2, I'll do it myself. This is a scenario where, as we will see, it's important to actually do the math, instead of making heuristic guesses, because what happens is somewhat counterintuitive.
So we have a "rocket" which is accelerating in some specific direction, which we'll call the ##x## direction, with proper acceleration ##g## (more precisely, this is the proper acceleration of an observer at rest at the bottom of the rocket, but we can consider the rocket's height to be small enough that ##g## is constant everywhere inside it). This rocket is very wide in one of the transverse directions, which we'll call the ##y## direction, and we have a train moving inside the rocket in that direction (the ##y## direction) with speed ##v## as measured by an observer at rest in the rocket, and rest length ##L##. At some instant, a pair of light beams is emitted by a source moving with the train, in the ##+y## and ##-y## directions. The question is, what is the motion of these beams?
Let's first look at things in an inertial frame in which the rocket is momentarily at rest at the instant the light beams are emitted; this instant will be ##T = 0## (we will use capital letters for coordinates in this frame to avoid confusion). In this frame, we can assign coordinates as follows: the bottom of the rocket is at ##X = 1 / g## at ##T = 0##; the light source is at ##X = 1 / g + \delta## at ##T = 0##; and the beams are emitted in the ##\pm Y## direction. The train's speed is ##v## in this frame (since the rocket is momentarily at rest in the frame), and the length of the train in this frame is ##L / \gamma = L \sqrt{1 - v^2}##. In this frame, the backward-moving light beam will take time ##L \sqrt{(1 - v)/(1 + v)}## to hit the back end of the train, and the forward-moving light beam will take time ##L \sqrt{(1 + v)/(1 - v)}## to hit the front end of the train. The bottom of the rocket moves a distance ##\frac{1}{2} g T^2## in time ##T##, provided ##T## is small enough (we are assuming it is, i.e., that the height ##\delta## of the light source and the rest length ##L## of the train are small enough), so the distances moved will be ##\frac{1}{2} g L (1 - v)/(1 + v)## and ##\frac{1}{2} g L (1 + v)/(1 - v)##, and the height above the bottom of the rocket at which the two light beams strike will therefore be ##\delta## minus these two distances. Obviously this final height will be smaller for the forward-moving beam than for the backward-moving beam.
Translating the above into Rindler coordinates, which correspond to the "stationary" frame, is simply a matter of reinterpreting the heights ##\delta - \frac{1}{2} g L (1 - v)/(1 + v)## and ##\delta - \frac{1}{2} g L (1 + v)/(1 - v)## as the ##x## coordinates (lower case ##x## since we are now talking about Rindler coordinates) of the light beams at the instant they strike the back and front ends of the train, respectively. That is, instead of the bottom of the rocket accelerating in the ##+ X## direction at ##g##, we now have the light beams accelerating in the ##- x## direction at ##g##. Everything else is the same, since we have ##t = T## to a good enough approximation for the duration of the light beams' travel.
The question now is, how do we translate all this into the rest frame of the train? Let's first try to translate into an inertial frame moving at ##v## in the ##Y## direction relative to the inertial frame we used above. The events of interest have the following coordinates in the original inertial frame:
Light beams emitted: ##T = 0##, ##X = \delta##, ##Y = 0##. Bottom of rocket at this instant (directly below light source): ##T = 0##, ##X = 0##, ##Y = 0##. (This event is the common origin of both frames.)
Back light beam hits back of train: ##T = L \sqrt{(1 - v)/(1 + v)}##, ##X = \delta##, ##Y = - L \sqrt{(1 - v)/(1 + v)}##. Bottom of rocket at this instant (directly below back of train): ##T = L \sqrt{(1 - v)/(1 + v)}##, ##X = \frac{1}{2} g L (1 - v)/(1 + v)##, ##Y = - L \sqrt{(1 - v)/(1 + v)}##.
Front light beam hits front of train: ##T = L \sqrt{(1 + v)/(1 - v)}##, ##X = \delta##, ##Y = L \sqrt{(1 + v)/(1 - v)}##. Bottom of rocket at this instant (directly below front of train): ##T = L \sqrt{(1 + v)/(1 - v)}##, ##X = \frac{1}{2} g L (1 + v)/(1 - v)##, ##Y = L \sqrt{(1 + v)/(1 - v)}##.
We now simply do a Lorentz transformation at speed ##v## in the ##Y## direction, to obtain:
Light beams emitted: ##T' = 0##, ##X' = \delta##, ##Y' = 0##. Bottom of rocket at this instant (directly below light source): ##T' = 0##, ##X' = 0##, ##Y' = 0##. (This event is the common origin of both frames.)
Back light beam hits back of train: ##T' = L##, ##X' = \delta##, ##Y' = - L##. Bottom of rocket at this instant (directly below back of train): ##T' = L##, ##X' = \frac{1}{2} g L (1 - v)/(1 + v)##, ##Y' = - L##.
Front light beam hits front of train: ##T' = L##, ##X' = \delta##, ##Y' = L##. Bottom of rocket at this instant (directly below front of train): ##T' = L##, ##X' = \frac{1}{2} g L (1 + v)/(1 - v)##, ##Y' = L##.
Notice that the ##X'## coordinates are the same in this frame as the ##X## coordinates were in the original inertial frame, so the height differences are unchanged; the backward-moving beam still hits higher above the bottom of the rocket than the forward-moving beam. And this is true even though, in this frame, both beams hit at the same time! How is this possible?
To see what we missed, let's look at the events describing the points on the bottom of the rocket that will be directly below the back and front of the train when the light beams hit those ends of the train, at the instant the light is emitted. In the original inertial frame, these events are:
Bottom of rocket below back of train: ##T = 0##, ##X = 0##, ##Y = - L \sqrt{(1 - v)/(1 + v)}##.
Bottom of rocket below front of train: ##T = 0##, ##X = 0##, ##Y = L \sqrt{(1 + v)/(1 - v)}##.
Now we transform these events into the new inertial frame, moving at ##v## in the ##Y## direction:
Bottom of rocket below back of train: ##T' = v L / (1 + v)##, ##X' = 0##, ##Y' = - L / (1 + v)##.
Bottom of rocket below front of train: ##T' = - v L / (1 - v)##, ##X' = 0##, ##Y' = L / (1 - v)##.
Now we see what is happening: in the train frame, the rocket is "tilted" in the ##Y'## direction--the rocket below the back end of the train is at ##X' = 0## at a later time than the rocket below the front end of the train. So when the light beams hit the ends of the train (which happens at both ends at ##T' = L## in this frame), the bottom of the rocket at the back end is at a lower ##X'## coordinate, and hence the beam hits at a higher height above the bottom of the rocket.
Translating this into the actual rest frame of the train should again be simple: we just reinterpret acceleration of the rocket in the ##+ X## direction as acceleration of the light beams in the ##- x## direction. Everything else stays the same, including the above conclusion that the backward-moving beam hits at a higher height above the bottom of the rocket.
Very impressive, Peter, but I have to say ... you have WAYYY to much spare time on your hands :-p
Yes, I'm really looking forward to working through Peter's calcs (as I find this puzzle intriguing). But I have to put it off until I've got enough time to sit down and really concentrate on it.
The math (and effort :wideeyed:) is impressive indeed, and seems to be correct. However, I'm still having trouble interpreting it, and can't quite agree with your conclusion.
First, it's clear that there is some kind of tilt or rotation even before the last part, in the part I quoted. The last paragraph, transforming simultaneous events in one frame into another frame, is meaningless.
Anyway, I can't accept the resolution that the train is running uphill, and that's why light hits the front wall lower. The passengers are sending light parallel to the floor, even if the train was rotated or even tilted.
Further, let's consider a ball on a horizontal table in the train. We'll view it from the only reasonable frame (the one you started with), where the train is moving, and the rocket accelerating. The ball or table is never accelerated in any direction other than +X, so there's no reason it would ever fall from the table. So the gravity points "down", even if things may fall in funny ways.
Same reasoning applies to the question whether the train would slow down. Sometimes I think it should, but the argument with a ball on table looks correct.
In other words, your intuition is leading you to a different conclusion from the math. That's why I put the warning at the beginning of my post that the conclusion would be counterintuitive. Unfortunately, that doesn't make it wrong; one of the first lessons everyone who studies relativity has to learn is that if your intuitions conflict with the theory, your intuitions are wrong and need to be retrained.
You mean, because the two ##X'## coordinates are different? Yes, that in itself is enough to confirm that, contrary to intuition, the backward-moving light beam does hit the train higher above the bottom of the rocket than the forward-moving light beam does. See below.
Why? What's wrong with doing a simple Lorentz transformation? That's all I did.
However, as I said above, the calculation prior to that, showing the two different ##X'## coordinates for the bottom of the rocket underneath the back and front of the train, is already sufficient to show that your intuition, that in the "train frame", the two light beams should hit at the same height, is wrong. And it's already obvious that intuition has to be wrong somewhere, because the "stationary frame" and the "train frame", according to intuition, give different answers for direct observables--how far above the bottom of the rocket each light beam hits. The only question is, which intuition is wrong--the "stationary frame" intuition (that the backward-moving light beam hits higher) or the "train frame" intuition (that both beams hit at the same height). I am simply showing that it's the latter intuition that's wrong.
Huh? That's impossible; the floor is accelerating upward. More precisely: the floor is accelerating upward in the ##X## direction, and the light is moving in the ##Y## direction, in the original inertial frame (the one in which the rocket is momentarily at rest at ##T = 0##). That means that, at an instant of time in that inertial frame, both light beams are the same distance from the floor of the rocket. (This may be what you were trying to say by saying "parallel to the floor", but it's very important to be precise, as you'll see in a moment.)
Now: since the train is moving in the ##Y## direction in the original inertial frame, then when we transform to an inertial frame in which the train is at rest (more precisely, it's momentarily at rest at ##T' = 0##--it is accelerating in the ##X'## direction, but we're assuming the acceleration is small enough that we can approximate things using the inertial "train frame"), we will find that it is impossible, in the new frame, for the light beams to be the same distance from the floor of the rocket (except at the instant ##T' = 0## when the beams are emitted). This is an obvious consequence of relativity of simultaneity: events which are spatially separated cannot be simultaneous in two different frames. Since we know by hypothesis that events at which the two light beams are at the same distance from the floor of the rocket are simultaneous in the original inertial frame, such events cannot be simultaneous in the new inertial frame (the "train frame"). That is the missing piece we need to understand why the backward-moving light beam hits higher in the train frame.
Yes, that's correct. But it's irrelevant to my argument. I am not saying that gravity in the train frame points in a different direction. In fact, if you look at my calculations, I am making use of the fact that the acceleration in the train frame is in the ##X'## direction only.
Once again, the key point has to do with relativity of simultaneity; that's where the counterintuitive feature comes in. There is nothing counterintuitive about the direction of gravity in this scenario; if you are focusing on that, you are missing the point.
Thanks Peter, perhaps you missed this sentence in my very first post.
And yes, I'm trying to improve my intuition.
If we return to the original questions,
the answers to 1-3 would be Yes, and to 4 "no easy way"?
To clear the last few points,
What is simultaneous in the stationary frame, has no meaning for the passengers. That's why "meaningless". I am not saying it is wrong or anything like that.
Actually the key word was "sending". What happens after, is the point of this discussion.
Sorry if I sound like nit-pick, but I spent 3 hours choosing the right words for those 12 lines :rolleyes:
I understand that you said that in the OP, but when you say you "can't agree" with my conclusion, that's tantamount to not agreeing with your own statement in the OP.
The answers to 1 and 3 are yes. The answer to 2 is "sort of" and "no" (since 2 is really two questions). Gravity does not create a "preferred frame", but it does break spatial isotropy--the direction of the gravitational field is different from the directions perpendicular to the field. The Lense-Thirring effect is due to the rotation of the central gravitating body, not transverse motion of the test object; we are ignoring the Earth's rotation here (certainly there is no rotation in my flat spacetime scenario with the accelerating rocket).
As for question 4, what does "perfectly vertically" mean? Does it mean with respect to the train, or with respect to the stationary observer? Objects dropped from rest relative to the train do fall perfectly vertically relative to the train; they don't relative to the stationary observer (since they have the train's horizontal velocity relative to that observer).
Also, I'm not sure what you meant by "eventually exceed the speed of light" in the previous post you quoted. We have not analyzed the long-term motion of any of these objects; we have only done an analysis in a single momentarily comoving inertial frame. We have to restrict the analysis that way if we want it to apply to the case of a train moving horizontally on a flat planet, since the equivalence principle only applies in a single local inertial frame.
Obviously on a real planet, objects dropped from the train will not fall indefinitely; even if the objects are idealized as not interacting with the planet's substance, they will eventually fall through it and come out the other side, and at that point they will be accelerating in the opposite direction. (Also, of course, a real planet is not flat but spherical, so the train's path will curve.) We can't use a flat spacetime model to approximate any of this behavior; we would have to use a full-blown curved spacetime model. At that point, I would hope we would all agree that our unaided intuition is inadequate to the task, and we would have to take the time to grind through the math. :wink:
I don't know what you mean by this. The fact that events that are simultaneous in the stationary frame cannot be simultaneous in the train frame is a fact for both stationary observers and train passengers. If the train passengers know that a certain pair of events--such as, say, the events of both light beams (backward and forward moving) being at a certain distance ##X## above the rocket's floor--are simultaneous in the stationary frame, then those train passengers know that those two events cannot be simultaneous in the train frame. That means the light beams cannot be at the same distance above the rocket's floor at the same time in the train frame. So facts about simultaneity of events in the stationary frame can certainly be used to deduce facts about the simultaneity (or lack thereof) of events in the train frame. That is what my argument does.
In other words, you meant the words "parallel to the floor" to only apply at the instant the beams are emitted? Sure, I already assumed that: the beams are emitted in the ##Y## direction, which is also the ##Y'## direction. But that, in itself, says nothing about their respective heights above the rocket floor at any other instant other than the instant they are both emitted.
I understood your conclusion as if you're suggesting that the floor of the train looks tilted to passengers, and that's why there is difference between front and back wall. And I could not agree with that.
If a ball is dropped in a tall train, its horizontal speed (Y) would stay constant, while the vertical speed (X) would increase. Even if X is limited by the speed of light, ##\sqrt{Y^2+X^2}## would exceed ##c## long before ##X## would, since ##Y## is already close to ##c##. So, a dropped object will lose some ##Y## speed and lag behind the train. The difference will be small at first, but increase as the vertical speed gets higher. If the train is moving fast enough, it might be noticable even at a low height.
In fact I was hoping to eventually extend the experiment to unlimited height. I'm trying to understand why a black hole has a horizon, while a homogeneous gravitational field can be infinitely deep.
If someone could translate our results into the GR formalism, it would be awesome, but perhaps worth an Insight article rather than a forum post. I can't quite imagine how someone would use a metric to derive these results, much less finding the metric.
"Parallel to the floor" also describes direction, not just the height (that is understood to be the same for both rays). As in, X is constant to first order in Y.
Then how else would you interpret the math? The math gives an unequivocal answer, but how to describe it in English is a different question. I'm not suggesting that the "tilted" description in English is "right"; I'm saying that the math is right, and offering the "tilted" description in English as a way of (heuristically) understanding why the math works out the way it does. But there may be other ways of understanding it.
SlowThinker said:
If a ball is dropped in a tall train, its horizontal speed (Y) would stay constant, while the vertical speed (X) would increase. Even if X is limited by the speed of light, ##\sqrt{Y^2+X^2}## would exceed c long before X would, since Y is already close to c. So, a dropped object will lose some Y speed and lag behind the train.
No, that's not what will happen, because your argument about ##\sqrt{Y^2 + X^2}## applies just as much to the train as to the dropped object; if one "lags", the other will "lag" by the same amount.
Actually, what will happen is that the proper acceleration in the ##X## direction will require a larger force to be exerted by the rocket's engine than it would if the train were not present inside the rocket; the force required will go to infinity at some ##X## velocity less than ##c##, instead of at ##X## velocity equal to ##c## as it would if the train were not present. So the "lag" will actually be in the rocket itself.
A "homogeneous gravitational field" can't be infinitely deep. It has a horizon, just as a black hole does. The horizon in the flat spacetime case is called the Rindler horizon.
It describes the direction the light emitter is pointing, which is the ##Y## direction. But that in no way prevents the two light beams from being at different distances from the floor at the same instant in the train frame.
Part of the problem here, to me, is that you are trying to reason with English words instead of math. You can't do that; English words are too imprecise. That's why we use math in physics: to make sure we are stating things precisely, so that we know exactly what observations we are predicting.
Yes, this is true in the sense that ##Y## is equal to ##T## for a light beam, and ##X## is a quadratic function of ##T##. But we already know that ##T## changes by enough for the variation in ##X## to be visible (because, by hypothesis, we can observe the "bending" of the light beams), so the fact that that variation is quadratic doesn't affect any of the conclusions.
To me, it looks as if the gravity works in a funny way. Such as when you're in a centrifuge, you feel the "gravity" pointing "down", but when you stand up, you get pushed to the side; and when you move hands, it feels strange. But when you don't move, everything is fine.
We agreed that the floor is perpendicular to the gravity, just like it would be in a centrifuge.
You surely must be wrong here. Do you agree that if I jump out of the train and out of the rocket as well, then from my perspective, my Y-position will eventually start to get ahead of the train?
The passenger perspective is more difficult to figure out, but I'm pretty sure that the same reasoning applies, and the passengers would feel getting ahead of me.
Probably you meant "if the train were not moving"? But this can't be right either. Surely the rocket can accelerate like any other object, and only feel trouble reaching ##c##, not ##\sqrt{c^2 - X^2}##. There is only one invariant speed.
:eek: I should have asked this question in the beginning, instead of trying to figure out time dilation in a deep field using a relativistic train :oops:
You are right in a sense. I'd prefer to use pictures instead of math (or before math), but drawing pictures on a computer is not easy. That, and it also seems like heavy math is needed to arrive at simple results.
I can read other's math (unless they start pulling new symbols out of thin air), but writing my own often leads to a dead end.
If the light was sent in opposite directions, but at an angle, it would still fit all your definitions so far:
1) the starting height is the same
2) close to start, it's close to starting height
3) it's a part of a parabola
but it's also important the the light starts horizontally. But I agree that your computations used a ray that does start horizontally, so the conclusions hold.
Remember that "gravity" in relativity is not a force; it's just the geometry of spacetime. Yes, the geometry of spacetime can have counterintuitive properties. But, as I've said before, that just means your intuitions need to be retrained.
Don't guess. Do the math. Or at least do the analysis. See below.
No. Look at things in the inertial frame in which the rocket is momentarily at rest at the instant you jump. At that instant, you jump out of the train and the rocket, which means you start following an inertial worldline whose ##Y## velocity, in this frame, is the same as that of the train. Since your worldline is inertial, its ##Y## velocity cannot change; since the train's ##Y## velocity is also constant, your ##Y## position will always be the same as the train's, in this frame.
To see how things look in your rest frame, just boost by velocity ##v## in the ##Y## direction; this puts you in the instantaneous "train frame", the inertial frame in which the train is momentarily at rest at the instant you jump out. In this frame, neither you nor the train have any ##Y## velocity at the instant you jump; and since the train is accelerating in the ##X## direction, its ##Y## velocity doesn't change (and of course yours doesn't because you are at rest in this frame). So in this frame also, you and the train will always have the same ##Y## position.
Please, stop guessing and do the math, or at least the analysis. You are confusing yourself by guessing based on your intuition, instead of actually doing the analysis and looking at the conclusions it leads you to.
It's not the rocket we're talking about, it's the train; since the train is contained in the rocket, accelerating the rocket means accelerating the train. If we consider an idealized rocket that is infinitely wide, and an idealized train that is infinitely long, then the limiting factor is the train's speed, not the rocket's; the train's speed will always be larger than the rocket's (because the train has an extra component of velocity in the ##Y## direction), so if the train's speed is limited to ##c##, the rocket's speed must be limited to less than ##c##, as seen from a fixed inertial frame. This is your own argument; I have just restated it to make the conclusion clearer.
As for the rocket, remember that neither its speed nor the train's speed will ever reach ##c##, so we can always boost to an inertial frame in which the rocket is momentarily at rest and the train is moving at velocity ##v## in the ##Y## direction. In this frame, of course the rocket can accelerate. So it's not that the rocket stops accelerating; it's just that, viewed from a fixed inertial frame, the rocket's speed can't asymptote to ##c##, because the train is contained inside the rocket, so the train's speed constrains the rocket's speed in that fixed inertial frame.
This could be done, yes, but it would be a different scenario from the one I analyzed and that we have been discussing. Change the scenario and of course you can change the observables. But you can't specify one scenario and then reason as though it were a different scenario.
In other words: we could certainly specify, from the start, a scenario in which the two light beams are sent out in such a way that they both hit their respective ends of the train at the same height above the bottom of the rocket. But for that to happen, the light beams would have to follow different worldlines from the ones I used in my analysis. It would be instructive to set up this scenario and analyze it, but unfortunately I don't have time to do that right now, so for the time being I'll leave it as an exercise. :wink:
Hello
A couple of questions. Would a marble placed on the floor of the train roll towards the back? Would a string attached to a penduluum-like mass hung from the ceiling of the train make an acute angle facing the rear wall, and an obtuse angle facing the front wall, rather than hang straight down?
PeterDonis's analysis seems to suggest the answers to these would be yes, but I may be misinterpreting.
Thanks!
... and another question:
Wouldn't it actually require a y-directed force just to keep this train moving at v in the y-direction?
I ask because if the accelerating rocket's floor were the only force acting on the train, then in order for the train to conserve its momentum in the y-direction as it is accelerated in the x-direction, its velocity in the y direction would decrease, no? So holding the train's y-velocity constant would mean an increase to its y-momentum, which would in turn require a constant infusion of energy, hence a y-directed force on the train, right?
Guess I'm falling for same trap PeterDonis has criticized throughout this thread: I didn't do the analysis or math. I'm just extrapolating this from another staff mentor's answer to my question in the thread I started, "need some help understanding electromagnetics and relativity". The scenario in my question is a little analogous to this one. The field E plays the part of the rocket and the charged particle plays the part of the train.
mairzydoats said:
Hello
Thanks!
Here's my analysis:
The floor and the marbles on the floor recide approximately at the same point in space. If some forces are affecting the marbles, then the same forces are affecting the floor. Floor and marbles move in sync.
On the other hand the floor and the ceiling are forced to move in sync by the walls, except that the walls are Lorentz contracting, so the floor and the ceiling are not co-moving, if observed by an inertial observer. Therefore the ceiling is pulling the floor forwards making the marbles on the floor to roll backwards. The strength of this effect depends on the floor-ceiling mass ratio and floor-ceiling distance.
EDIT: As seen from an inertial frame, the longitudinal motion of the floor slows down as the transverse motion of the floor speeds up. Longitudinal means along the floor's long axis. This is closely related to time dilation.EDIT2: It may be important that as the walls are Lorentz contracting and the floor is moving towards the ceiling, horizontal laser beams shot by one laser gun on the floor and other laser gun on the ceiling will cross each other. This is the effect known as aberration, or relativistic beaming.
No. "Gravity" still points straight down inside the train.
No. Once again, look at things in an inertial frame in which the rocket is instantaneously at rest. The train is moving at ##v## in the ##Y## direction in this frame. It gets accelerated in the ##X## direction, but that doesn't affect its motion in the ##Y## direction at all.
Why do you think that would be the case? The acceleration of the rocket only affects the train's momentum in the ##X## direction, not the ##Y## direction.
Why do you think this is the case?
https://www.physicsforums.com/threa...nding-electromagnetics-and-relativity.835867/ post #2:
"Increasing the momentum in the y direction while keeping the momentum in the x direction fixed will actually decrease the velocity in the x direction"
So I've spent quite a few hours trying to derive the speed of the rocket as viewed by me jumping out of the train, but still can't arrive at anything like x=cosh(t). So I'll just take that for granted. The speed may or might not be ##u=\frac{t}{\sqrt{t^2/c^2+1/g^2}}##, the important thing is that the speed approaches ##c##.
In the rocket, we set up light clock, where the light travels in the same direction as the tracks (perpendicular to acceleration). It has tilted mirrors, so that the light stays in the clock during acceleration.
We know that if the train is running at speed ##v##, and the distance of clock mirrors is ##d##, then everytime the clock bounce, the train went distance ##v\ d/c##, perhaps with a small but constant correction to account for the light following a parabola.
After my jump, as the rocket is gaining speed, the light in the light clock is bouncing more and more parallel with the flight direction, and it takes more and more time to bounce. So it takes more and more time for the train to move ##v\ d/c##. So the train is going slower and slower. Simply put, the time on the rocket is Lorentz dilated.
On the other hand, I am flying at constant speed ##v##. So the train is lagging behind.
This is not very mathematical but perhaps it qualifies as analysis?
Ah, ok. This is going beyond the analysis I did, which was restricted to a single local inertial frame--i.e., it was restricted to a time short enough that the train's motion can be idealized as constant speed in the ##Y## direction plus constant acceleration in the ##X## direction. I have not extended the analysis to cover a long period of time, since I was only concerned with explaining why the two light beams do not hit their respective ends of the train at the same heights.
Your comment does, however, bring up a point I was mistaken about. I had said this in a previous post, in response to SlowThinker:
When I posted this, I had forgotten the effect you refer to: that over a long period of time, if the rocket keeps accelerating in the ##X## direction, the speed of the train in the ##Y## direction, as seen in a fixed inertial frame, will have to decrease, in order to conserve momentum in the ##Y## direction. (Heuristically, this is because the relativistic mass of the rocket/train increases, as seen in a fixed inertial frame, and the train's momentum is relativistic mass times velocity, so if relativistic mass increases, velocity must decrease.) So in the limit, the rocket can indeed have its speed asymptote to ##c## in the ##X## direction, because the speed of the train in the ##Y## direction goes to zero in the limit.
  • · Replies 52 ·
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 57 ·
  • · Replies 28 ·
  • · Replies 58 ·
