Gravity Question: Calculating Orbit Time Around Spherical Rock
  • Thread starter Thread starter Poisonous
    Gravity
The problem involves calculating the orbital period of an object in a circular orbit around a spherical rock with a specified diameter and density. The context is rooted in gravitational physics and orbital mechanics.
  • Participants discuss the necessary steps to find the mass of the rock and how to apply Newton's laws to determine the orbital period. Questions arise regarding the assumptions about the radius of orbit and the nature of the object's motion.
There is ongoing exploration of the relationship between gravitational force and centripetal acceleration, with various participants suggesting different methods to express velocity and period. Some guidance has been provided on relating velocity to the period, but no consensus has been reached on the final calculations.
Participants note that the problem specifies not needing to perform arithmetic, which raises questions about the expected approach to the solution. There is also mention of the density of the rock being equal to that of Earth, which may influence the calculations.
Poisonous
The problem statement, all variables and known data:
You launch an object into a circular orbit around a spherical, smooth rock, 30 cm in diameter. The rock also has the same mass density as Earth, ρ. How long does it take the object to orbit the rock one time?
Attempt at a solution:
I know you should start by finding the mass of the rock, which turns out to be:
(4/3)pi*r3
I'm not sure what to do after that. Any help?
Apply Newton's 2nd law to solve for the period. What force acts on the object? What is its acceleration?
What radius of orbit are you mean to assume? Is the object supposed to be sliding along the surface of the rock?
Yeah, the problem says the object is in orbit just barely above the surface, so I think you can assume that it's the same as if it were sliding without friction.
The force that acts on the object is gravity. The acceleration due to gravity is given by the formula -GM/r2, where I can plug in the M from above.
I'm not sure how to relate that to F=ma.
Good. So we have the radius of the orbit.
Good.
That's true, but unhelpful.
Hint: What kind of motion does the object undergo? Write the generic formula for that sort of acceleration. Plug that into F=ma.
The object is moving in uniform circular motion. So, F=m*v2/r
You know r and the force is gravity, but do you know m? Or does that cancel out with the force of gravity formula?
I assume it does, so then v = [tex]\sqrt{GM/r}[/tex]
or
v = [tex]\sqrt{4/3*G*pi*rho*r^2}[/tex] which has me a little worried, since the problem has a note that says we shouldn't have to do any arithmetic at all to solve it.
Note that you are asked to find the period, so express v in terms of the period.
It's not obvious to me how you can get a numerical answer without doing any arithmetic. (Perhaps I just need more coffee.) You can certainly express the answer in terms of ρ.
Compare it with an object orbiting just above the surface of the Earth.
ehild
Doc Al: So I could do it with v*omega instead of v2/r
ehild: I was thinking something like that, but how..?
Don't be discouraged; keep going. How do you get the period from the speed? Remember that this is a circular orbit, so you can easily calculate the distance that the satellite travels. Once you get an expression for the period, you'll realize why you don't need any arithmetic to solve the problem.
What's v*omega? Anyhow, you don't need to bring omega into the picture.
Don't bother using ω²r, if that's what you're thinking. Just replace v with distance per period.
Just write out the equations acceleration due to gravity = centripetal acceleration , both for Earth and for the rock. Find out how the angular velocities ω are related. Do not forget that the densities are equal. And you know the minimum speed of a satellite which can orbit around the Earth .ehild
Since it's circular, the period is T = 2*pi*r/v, but that is not making it immediately obvious why I shouldn't have to do arithmetic.
ehild said:
Doc Al:
The angular velocities are the same. On the Earth, it is sqrt(g/R)
That's certainly true, but you still need some arithmetic to figure out the period.
Good. Express v in terms of T and use that in your early equation. Then you can solve for the period.
Unless they want you to express the answer symbolically, you'll need a little arithmetic.
You are almost there. Carry out the isolation for T in general terms and you will observe that the radius term cancels out. Thus it really doesn't matter how big the rock is at all. If the density of the rock is the same as the earth's, then the orbital period at the surface would also be the same. If you knew this orbital period for the earth, then you would not have to do any arithmetic (although I doubt anybody would know).
Actually, I do know the orbital period on Earth's surface, since it is in the packet this question is in. It is given as 5069 seconds. But, the problem is that the answer I'm getting is not 5069.
So, after the algebra, you get:
T^2 = (2pi)/(4/3*G*rho)
solving for T yields: 11709.99
Did I do something wrong?
Ah, so that's why you don't need any arithmetic! :wink:
That's not quite right. Redo your algebra.
But the main thing to realize is that the period is independent of the radius.
Hmm, I am supposed to be solving:
GMm/r2 = m * v2/r
plugging in and simplifying to:
G(4/3*π*r*ρ)= (2πr/T)2/r
right?
Because that simplifies all the way to: T^2 = (3pi)/(G*ρ) which doesn't give 5069.
GMm/r2 = m * v2/r
right?
Good.
What did you use for G and ρ? (Show how you calculated ρ.)
I hope you rooted whatever number you got. Not undermining your intelligence. Just checking all the possibilities.
Ah, I forgot to convert density to kg/m^3. Thanks for the help. I get about 5060 now.
A useful thing to remember: the Space Shuttle, which orbits only 300 km above the surface, orbits in 90 minutes. When I read the part about not needing any arithmetic, I thought you were expected to know this or something.
  • · Replies 19 ·
13K
