Grounding by touching a ground lead
  • Context: High School
  • Thread starter Thread starter rasen58
    Ground Grounding Lead
Grounding oneself by merely touching the negative lead of a power supply wire is insufficient for effective grounding. Continuous connection to an Earth ground is necessary to maintain a safe grounding state. Factors such as wearing a wool sweater can lead to a rapid build-up of static charge after initial grounding. It is recommended to use a large value resistor, such as 1 MegOhm, when grounding to minimize shock risk, as seen in ESD control wrist straps.
  • Understanding of electrical grounding principles
  • Knowledge of static electricity and its effects
  • Familiarity with ESD control measures
  • Basic concepts of power supply wiring
  • Research the principles of electrical grounding and safety
  • Learn about ESD control techniques and equipment
  • Study the effects of static electricity on electronic components
  • Explore the use of resistors in grounding applications
Electronics technicians, electrical engineers, and anyone involved in handling sensitive electronic components or working with power supplies.
rasen58
Is it possible to sufficiently ground yourself just by touching the negative lead of a wire coming from a power supply once?
No you need to stay connected to be grounded, and it needs to be to Earth ground.
If you are wearing a wool sweater on a dry day, you will charge back up within a few seconds of moving around after touching the ground lead. If you're not doing anything that charges you back up, it will take a while for any charge to build up on you again.
BTW, it's good practice to ground yourself though a large value resistor like 1 MegOhm. This reduces the possibility that you can get shocked badly if you happen to be connected to some other voltage. ESD control wriststraps, for example, contain such a current-limiting resistor.
Plus, the negative lead from the PSU may not be grounded ( ie. its " floating")
  • · Replies 18 ·
  • · Replies 58 ·
  • · Replies 17 ·
