Where does the temporal stretch come from in Group Velocity Dispersion?
The discussion focuses on the derivation of temporal stretch from Group Velocity Dispersion (GVD) in optical fibers. The GVD is defined by the equation $$ GVD = -\frac{\omega}{n}\frac{d^2n}{dk^2}=-\frac{\omega}{n}\frac{\lambda^4}{4\pi^2}\frac{d^2n}{d\lambda^2}$$. The temporal stretch is expressed as $$ \Delta\tau = -\frac{L}{c}(\lambda^2\frac{d^2n}{d\lambda^2}) \frac{\Delta\lambda}{\lambda} $$, indicating a direct relationship between GVD and pulse broadening in optical fibers. Additional references provided in the discussion suggest that the temporal stretch can also be defined using the dispersion D, which is related to GVD.
  • Understanding of Group Velocity Dispersion (GVD)
  • Familiarity with optical fiber principles
  • Knowledge of the relationship between wavelength and refractive index
  • Basic grasp of differential calculus as applied to optics
  • Study the derivation of Group Velocity Dispersion in optical fibers
  • Learn about the impact of dispersion on pulse propagation in optical systems
  • Explore the relationship between GVD and temporal stretch in detail
  • Investigate the dispersion equation D = –2πc(GVD)/λ² for practical applications
Students and professionals in optics, particularly those studying or working with optical fibers and pulse propagation, will benefit from this discussion.
chris_avfc
Our lecturer seemed to skip over how to get from the Group Velocity Dispersion to the actual temporal stretch of a pulse sent down an optical fibre, instead we were given just the two formula. I've been trying to work out where the temporal stretch comes from but can't work it out.
The GVD in this case is given by
$$ GVD = \frac{dv_g}{dk} = -\frac{\omega}{n}\frac{d^2n}{dk^2}=-\frac{\omega}{n}\frac{\lambda^4}{4\pi^2}\frac{d^2n}{d\lambda^2}$$
The temporal stretch is given by
Have made very little progress, only got as far as getting the same factors as in the temporal stretch.
$$ GVD = -(\lambda^2\frac{d^2n}{d\lambda^2})(\frac{\lambda^2}{4\pi^2}\frac{\omega}{n})$$
