Gyromagnetic Ratio: Quarks, Gluons, Antiquarks
touqra
What is the gyromagnetic ratio of quarks and gluons ? Does the ratio differs between antiquarks and quarks ?
Gluons have no magnetic moment, so the gyromangetic ratio is zero.
The gyromagnetic mooment of quarks depends on the model of a quark, which is still open for speculation. For point, Dirac-like quarks the gyromagnetic ratio would equal 2, with the same type of small correction like that for an electron or muon. If quarks have a different anomalous moment (like protons do), then the GR depends on the particular model.
By the same token, Z boson and neutrino has GR = 0 since it's neutral, right ?
Not because they are neutral, but because they have no mag moment.
The neutron is neutral, but has a mag moment and a GR.
To see whether they would have the same or different gyromagnetic ration, you need to see if they obey the same or different symmetries.
What do you mean ?
Thread 'Why is there such a difference between the total cross-section data? (simulation vs. experiment)'
Well, I'm simulating a neutron-proton scattering phase shift. The equation that I solve numerically is the Phase function method and is $$ \frac{d}{dr}[\delta_{i+1}] = \frac{2\mu}{\hbar^2}\frac{V(r)}{k^2}\sin(kr + \delta_i)$$ ##\delta_i## is the phase shift for triplet and singlet state, ##\mu## is the reduced mass for neutron-proton, ##k=\sqrt{2\mu E_{cm}/\hbar^2}## is the wave number and ##V(r)## is the potential of interaction like Yukawa, Wood-Saxon, Square well potential, etc. I first...
Toponium is a hadron which is the bound state of a valance top quark and a valance antitop quark. Oversimplified presentations often state that top quarks don't form hadrons, because they decay to bottom quarks extremely rapidly after they are created, leaving no time to form a hadron. And, the vast majority of the time, this is true. But, the lifetime of a top quark is only an average lifetime. Sometimes it decays faster and sometimes it decays slower. In the highly improbable case that...
I'm following this paper by Kitaev on SL(2,R) representations and I'm having a problem in the normalization of the continuous eigenfunctions (eqs. (67)-(70)), which satisfy \langle f_s | f_{s'} \rangle = \int_{0}^{1} \frac{2}{(1-u)^2} f_s(u)^* f_{s'}(u) \, du. \tag{67} The singular contribution of the integral arises at the endpoint u=1 of the integral, and in the limit u \to 1, the function f_s(u) takes on the form f_s(u) \approx a_s (1-u)^{1/2 + i s} + a_s^* (1-u)^{1/2 - i s}. \tag{70}...
