Half-face traversal on general polyhedra
9 replies · 3K views · last reply
Estanho
Hi,
I'm developing a data structure to represent 3-D meshes for numeric simulation. I want those meshes to be able to handle any type of polyhedron (not only the classic tetra and hexahedron). The best data structure that I could find was one based on half-edges (or darts), such as this one: https://www.cse.msu.edu/~ytong/papers/halfFace.pdf
The problem is, I want to be able to traverse the faces that compose a given polyhedron, such that this path could be represented as a Hamiltonian cycle on a graph whose nodes are the faces of the polyhedron, and the edges are the face-face connectivity within the polyhedron.
The 2-D counterpart would be a half-edge, which is trivial to traverse as in a Hamiltonian cycle if the graph nodes and edges are the same as the original polygon. All you have to do is follow the half-edges:
Left: a hexagon with vertices labelled 1 to 6 in order. Right: the same hexagon with arrows on its edges showing a single cyclic traversal of the vertices, following the labelled order, with an arrow between the two shapes.
But this doesn't seem to be easy when dealing with faces (or half faces). I don't even know if there will be a hamiltonian path of the faces for every possible polyhedron. And determining those is not easy and hard to keep in memory pre-processed. Here's an example for a prism:
Left: a triangular prism with faces numbered 1 to 5. Arrow to right: a graph with nodes 1 to 5 and directed edges between them, representing face adjacency of the prism.
The paper presents a common half-edge, half-face structure to store topological information. This structure allows for some operations (combinatorial maps) on each half-edge: ##\beta_1##, ##\beta_2##, and ##\beta_3##. Those maps are depicted below:
Diagram of a prism-shaped polyhedron with grey edges and red and green curved arrows and blue straight arrows marking face and edge adjacency mappings on its half-edges, with red spheres at the vertices.
Here, ##\beta_1## is red, ##\beta_2## is green, and ##\beta_3## is blue. So, as you can see, if you apply ##\beta_1## you will get the adjacent half-edge within the same half-face, if you apply ##\beta_2## you will get the adjacent half-edge on an adjacent half-face within the same polyhedron, and if you apply ##\beta_3## you will get the adjacent half-edge on the opposite half-face, from a adjacent polyhedron.
In short, my question is, is there a fast (i.e. with linear complexity) algorithm to traverse all the faces of a given polyhedron using those three operations? It would be sufficient to get just one half-edge for each half-face within the polyhedron, since traversing it is trivial by repeatedly using ##\beta_1##.
Until now, it seems my best bet is a graph-search algorithm, which is way too heavy for my needs.
haruspex said:
Does Grinberg's Theorem help? https://en.wikipedia.org/wiki/Grinberg's_theorem
It could be interesting to proof if all polyhedra contain a hamiltonian cycle on its faces. This theorem can be applied to planar graphs, I'm not sure also if every possible polyhedron can have its faces connectivities mapped to a planar graph. I couldn't think of a counter example, though.
Clearly every polyhedron can be flattened out into a planar graph. Just pick one face to be the exterior.
Every 3-connected planar graph can be formed into a polyhedron.
Oh, of course. I guess I missed my geometry classes.
I will try to work this out. Thanks.
Hi, bit late, but couldn't resist commenting on this. I was interested to see Grinberg's theorem, which I wasn't aware of. The wikipedia page shows an example of a non-Hamiltonian graph, so I wondered what this would look like in 3D as a polyhedron. As it happens I wrote a program called Stella4D which can help with this sort of thing. Here's a picture of the model I came up with.
Translucent 3D polyhedron rendered with coloured faces (pentagons and hexagons) and gold-tipped edges against a blue background.
That's cool. If I understand correctly, you wrote a software to convert from a planar graph into a polyhedron? What language did you use?
I wrote a program called Stella4D (http://www.software3d.com/Stella.php) for investigating polyhedra and 4D polytopes (it's commercial software FYI). It has a little-known feature to build new polyhedra using a spring-relaxation system, from a description of its topology alone. I used it originally to generate many of Stella's built-in polyhedra, such as the Johnson solids and near misses. You specify all the faces, based on vertex indices (which you assign arbitrarily), which can be a bit tedious, but it's good for things that can't easily be made other ways. In fact I just created a better realisation of the above non-Hamiltonian graph. This one has all regular 9-gons and 8-gons. Only the pentagons remain irregular:
Rendered polyhedron with translucent multicolored faces and gold-tipped edges, mostly large regular nonagons and octagons with a few pentagons, on a blue background.
Here's the input I used for Stella4D:
h ~6 (0 1 2 3 4 5 6 7 8)
(9 26 41 42 43 44 27 10)
(21 20 35 36 37 38 39 22)
(15 14 29 30 31 32 33 16)
(0 8 25 26 9) (8 7 23 24 25) (7 6 21 22 23)
(6 5 19 20 21) (5 4 17 18 19) (4 3 15 16 17)
(3 2 13 14 15) (2 1 11 12 13) (1 0 9 10 11)
(25 24 40 41 26) (23 22 39 40 24)
(19 18 34 35 20) (17 16 33 34 18)
(13 12 28 29 14) (11 10 27 28 12)
(40 39 38 42 41) (34 33 32 36 35) (28 27 44 30 29)
(45 43 42 38 37) (45 37 36 32 31) (45 31 30 44 43)
The "h" means the model is convex, so an initial parse is done where extra springs are used to expand the graph like a balloon.
The "~6" means that all faces with 6 or less sides are irregular, so in this case the 8- and 9-gons are made regular.
Each face is define inside parentheses. The vertex indices can be seen below:
Planar graph with 46 numbered vertices arranged in concentric rings, outer ring of large faces labelled 0 to 7 around the rim, with inner vertices labelled 9 to 45.
Stella4D can also print out unfolded nets to cut out and glue together, so I might make one in paper. It's an interesting polyhedron.
Oh, and Stella4D was written in C++ using OpenGL for graphics.
Got it. Nice piece of software, congratulations. I don't have dollars to spare right now since I'm a mere MSc student but I might look forward to buying it in the future.
Also, your work reminds me of one other from a professor of my local University. He works with these so-called UNIVs, which are sculptures representing seven-dimensional spaces.
You can see his phd thesis here: https://arxiv.org/pdf/math/0305058.pdf
  • Polished stainless steel sculpture of interlocking faceted polyhedral shapes mounted on a clear glass disc inside a bright mall atrium with a curved ceiling.
