Hall effect -- calculate carrier mobility and density
Kara386
A metallic film has length L=10mm, width W=1mm and thickness t=1##\mu m##. The current is parallel to the long edge and has magnitude ##I=0.7A##. Longitudinal voltage is ##V=1V## and it doesn't change with magnetic field. The Hall (transverse) voltage ##V_H## increases at ##0.3mV/T##. What is the carrier density and what is the carrier mobility?
I'd just like to check what I've done. Not sure whether I have to change something else if I want to infinitesimalise variables, but since all variables but the ones I'm changing are constant I think it's ok.
##V_H = \frac{IB}{tne}##
Where ##n## is charge carrier density. Then I think
##\frac{dV_H}{dB} = \frac{I}{ne}##
That's the step I'm not 100% sure about. If it's ok, then
##n = \frac{I}{e\frac{dV_H}{dB}} = \frac{0.7A}{1.6\times10^{-19} C \times 0.3\times 10^{-3}VT^{-1}}##
Is that right? After that I can just get the mobility ##\mu## from this equation:
##V = \frac{L}{W} \frac{I}{en\mu}##
Thanks for any help!
You forgot the thickness t.
I did. Thank you!
